Question about Columbia All Sport Digi Watch l
Light The back light will just turn on like it has a mind of it's own. And somtimes a very small lightbulb will apperar below the time. I can't figure out what's wrong with it.
  • Mrflappy102 Jan 15, 2008
    well i don't know
  • 4 Answers
If you press and hold the light button it will make the very small light bulb disappear and then it will stop turning on and off. I had the same problem and had to figured it out by playing with the buttons. Hope that helps you.
Posted on Feb 01, 2009
Star Wars rebels led watch how to set time and date
Hi,I had the same problem. Look on the side of the watch on the right, in between the two pressable buttons. There is a small black button, size of a Byro tip. Press that in for 5 secs then the date display will start to flash. Set with the lower big button then press the small button again to cycle through month, day, hour, minute.
Phew. Takes a bit of spotting.
Mar 14, 2015 | Watches
I have a fmdco053 watch in 24 hour time mode. how do i change it to 12 hour mode? thanks
I have this same model, it's 4 buttons with MODE on bottom left and light on top left. I tried all below doesn't work, but I figured it out. First you have to get it to blink where you would change the hours. The next part is tricky, I can't remember exactly how, but it's either you press the light button together with the top right button, or just repeat pressing the top right button until it cycle to the AM/PM.
Nov 08, 2010 | Watches
Surface Watch Model 31819 How do you turn the alarm off?
I have a Surface Watch. Not sure if it's the same model number, but the button set up is the same. Here's what I did:
Hold down the bottom right button. While you're holding it down, press the top right button. My bottom right button doesn't seem to always work, so it made it rather difficult to figure out what has going on.
Dec 03, 2009 | Watches
Automatic light function.
There is a button below the face of the watch that has the atomic watch symbol on it. Hold this button down until you hear a beep and it will turn that function off. To turn it back on, press & hold the same button until you hear a beep.
Oct 15, 2009 | Casio G-Shock GW500A-1V Wrist Watch
I don't know how to turn off the automatic light feature on my watch
There is a button with an atomic time symbol below the face of the watch. Press and hold this button until you hear a beep and the light will go off. To turn it back on again, just press and hold that same button until you hear a beep and it will come back in automatically when you tilt your watch.
I don't know how to take some of the band off, to size the watch. It is a Mossimo AnaDigi Brace Watch. Please help!!
Holding the Watch in your hand facing you, turn it to it's left side. You'll see a succession of small holes in the links wherein lies a removable hinge-pin, locate the link(s) you need to remove, and remove the pin in that link, and then the pin below it to pull the link. To do this, you need either a jewelers punch, (like a small awl, to push the pins out) or fashion one from a pair of pliers (small vise-grips work great for this) and a piece of a safety pin (cut a shank out of the back side of a pin to get a straight stiff shaft.)
When you pull your first pin out, put the watch on and gauge the size you need to make it.
once you have pulled the pins, note that one end of the pin is larger, and when reassembling everything, just take mind to put everything back in the same fashion as the disassembly process.
you'll have to push the pin in flush with either the flat side of some pliers or the side of a table, just make sure they go flush...
hope this helps, thanks for reading!
-Ross "Tweek" Sheridan
Sep 13, 2008 | Watches
Replaceing battery for colibri pocket watch
Hi, replacing battery can be found on amazon, take a look here: Rayovac Batteries Lasts as Long Costs Less. Wish you best of luck.
Aug 26, 2008 | Colibri PWS-95877-N Pocket Watch
Vestal G5 Global Traveler watch
THE REAL SOLUTION:
1. Hold down (light/el/set--the top right button) for 2 seconds to enter real time setting mode. 2. Press Mode key (bottom left button) to skip around to the different setting items. 3. Press Reset (top left button) to lower a setting. 4. Press ST/SP (bottom right button) to advance a setting (like increasing the time). 5. The day of the week will show automatically if you were correct in setting the year, month, date, and local city.
Apr 19, 2008 | Watches
Time Change
Using a Sportline but I'm an hour off with daylight savings time. How do I change the time, I can't figure it out. Can
Mar 10, 2008 | Sportline Big Digit Watch
CASIO PAG-40 Keeps good time but buttons stopped working
open the backside.
probably the light switch contact at the six side of the watch (attached to the steel mainframe) may have contact with the electronic cirquit
Jan 13, 2008 | Casio PRG-40T-7 Pathfinder
Columbia All Sport Digi Watch l Logo
65 people viewed this question
Top Columbia Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Columbia Watch Expert? Answer questions, earn points and help others
