Question about Wharfedale Modus One-Six Speaker
Tweeters are not functioning on both of my speakers.. haven't attempted to disassemble yet.. located replacement NEW tweeters directly from Wharfedale, but before I purchase them.. wondering if its more likely that my crossovers are blown and how can I test that.. I assume I can just provide a signal to the tweeters to determine if the speakers are operational. Any direction or advice appreciated. Thanks JOHN
The tweeters are probably blown, i had the same problem.
You can test this by placing the cable on the dismanteled crossover at the back of the speaker. colour blue/yellow.
No high volume please.
See http://www.hometheatershack.com/forums/diy-speakers/4549-wharfedale-modus-one-six-crossover-pics.html
for pictures.
If the tweeter is blown it can be dismanteld with the aid of a screwdriver, horizontally.
Place it between the tweeterbowl and the ring which has the mark wharfedale on it. The tweeter comes loose. On second hand sites you can buy little speakers, like modus one or two's with the same tweeters for a good price and put them on your larger speakers.
This how i repaired 2 of my 4 modus eights.
good luck Danny Mol
the netherlands
Posted on Mar 11, 2008
I recently lost my tweeter on Modus One Six. During hi power play back, I hear occasional clicks and pops. I emailed the manufacture and got no response from IAG nor Wharfedale UK. So I managed to fix it myself. After switching the tweeters to the working speaker (turn the tweeter housing to align with wharfedale signature and insert a flat head screw driver with cloth wrapped around its head and pop it slowly.), I was able to determine the tweeter itself is not broken, so that leaves us the cross overs.
Modus One Six has the crossover right behind the back plate terminals. unscrew 4 wood crews, and there you have it.
the tweeter uses 335K/100V capacitor and 3 watt/1 Ohm resistor.
335K is EIA Coding The EIA code works on a very similar principle to the resistor colour code. The first two digits refer to the value with the third being the multiplier. The fourth character represents the tolerance.
When the EIA code is used, the value will always be in Pico-Farads (see Decimal Multipliers).
Example 103K
This expands to:
1 = 1
0 = 0
3 = x 1,000
K = 10% (sec Capacitor Tolerance for listings)
Then we combine these numbers together:
1 0 x 1 000 = 10 000pF = 0.01µF, = 10n ±10% tolerance
Example 335K
This expands to:
3 = 3
3 = 3
E = x100,000
K = ±10%
3 3 x100,000 = 3,300,000pF = 3,300nF = 3.3uF 10% tolerance.
so 3.3MFD(micro Farad)/ 100v elctrolytic, non-polarized capitor is what we need for the tweeter. That is 0.49 USD component in local Frys electronics.
The NTE brand capacitor appears a lot smaller compare to the original (see photo)
Cut off the original 335K 100V yellow capacitor and re-solder the new replacement, and voila!!
I get my sweet crisp tweeter sound back. pop in a "Lucia di Lammermoor" opera CD , and I am right back home!
Posted on Oct 23, 2009
  • WeCan ManCan Dec 15, 2014
    The photo shows a yellow normal capacitor but the replacement used is an Electrolytic Radial ?
I have the same problem
Posted on Feb 28, 2008
    New Friend:
I tried this and it didn't work. I wonder if I need to replace other components in the corssover.
Posted on Apr 06, 2016
Need to replace tweeters. Anyone have specific info on aftermarket tweeters that will work
Replace tweeters with units having the same impedance as originals so amplifier loading is the same.
If unable to get exact replacement for unit, then it is important that you also replace the corresponding tweeter(s) on other channel since all speakers sound different and have different efficiency. Result will be unbalanced sound.
Mar 12, 2015 | Audio Players & Recorders
Tweeters will not work
might be a problem with the crossovers inside the speaker box.take them to a technition
Nov 10, 2013 | Definitive BP7004 Main / Stereo Speaker
How do I open up an EV sx100+speaker to fix the diaphram?
I just replaced diaphragms in the tweeters in a pair of EV Sentry 200 speakers. The tweeters had 4 bolts holding them together. One of them was stuck. It's just a matter of gently but firmly twisting it back and forth until it starts coming apart. Make sure you take it apart evenly or it will bind.
Sep 12, 2012 | ElectroVoice . Speaker
I lost the treble on both Alesis Monitor 1 speakers. The treble is good on the amp output toward the speakers. I'm thinking they went out one at a time and I didn't realize it until I lost the...
It's probably blown tweeters. But if you want to spend the money on a hipshot guess, try to find the the crossovers somewhere first; then find the readily available tweeters if/when that doesn't work out. Google "alesis monitor one MK2 tweeter".
You could test the tweeters by just removing one non-functional tweeter and wiring it directly to the speaker leads and with REALLY LOW volume containing NO BASS see if it makes any sound, which would prove it does/does not work.
Going forward, if the speakers sound stressed at high volume - THEY ARE. Too much power or too much distortion (overdriven amplifier) will kill speakers.
Sep 16, 2011 | Alesis Monitor One Mk2 Speaker
Polk rti6 tweers blown...4 speakers.....can these tweeters be repaired
It may be possible to have the tweeters repaired by Polk however if you have the skills your least expensive route would be to replace the tweeters and install them your self. I would recommend using the internet to find replacement tweeters either through Polk or possibly Ebay, or Amazon. Each tweeter has 2 wires that must be removed before uninstalling. Note the polarity and where they connect. red is + POSITIVE , BLACK IS - NEGATIVE
Apr 15, 2011 | Polk Audio RTi6 Main / Stereo Speaker
Quite new speakers 9.1 but the sound is very dull - sounds like tweeters are not working can these be repaired
You didn't answer if they ever worked right.
One doesn't usually judge tweeter function visually. They don't actually move much.
Take a cylindrical tube (like from a paper towel) and place it over the tweeter to isolate it from the room sound and the woofer, then place your ear at the other end. Anything? Nothing?
What sort of signal are you feeding them? Let's look (or listen) to the source and how its audio gets to the speakers. Define the electronics, pathing and setup.
Maybe some history. Have you ever tried to blow them up in your enthusiasm for the new rig? If the tweeters are dead, that may have happened. Microphone use and feedback = dead tweeters.
Feb 20, 2010 | Wharfedale Diamond 7.1 Main / Stereo...
2001 cherokee front speakers not working
well your deck might be bad, you could have a lose connection in your wiring to your speakers, you might not have a connection to your speakers, or your speakers could be bad.
Jun 28, 2009 | 2000 Jeep Grand Cherokee
KLH tweeters stopped working
hi, have u first disconnected the tweeters and then checked, as if its on a cross over, the tweeter is in series with a capacitor,if u have a ohms meter or a continuety tester check the tweeter coil if its open,secondly you can have the coil replaced, check if u can get one before buying a new,let me know
Jan 11, 2008 | KLH HT-9930 System
Wharfedale Modus One-Six Speaker Logo
3,857 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
jason
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
