Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Automatic Garage door reverses and automatically opens after closing
When we close our automatic garage door in cold weather it will close, pause for a second and then open the door as if it has hit something. This only happens when the temperature is below 30-35 degrees outside. There is no ice build up on the door or on the garage/driveway floor and the 'eye' sensors are aligned properly. There is no evidence of any driveway or concrete heaving. Also, is it possible that the cold temperature is causing a tension problem on the tension springs so the door thinks it hit something and reverses direction? The problem goes away when the temperature goes up.
Anyways help is appreciated.
  • 1 more comment
  • dandret Oct 23, 2008
    Same problem, when temp dips into the 30's, no problems anyother time, sears screw drive opener almost 2 years old. -Tom
  • Anonymous Jan 16, 2009
    MINE DOES THE SAME THING. IF I HOLD THE BUTTON DOWN, IT WILL STAY SHUT. I AM A SINGLE MOM AND HAVE NO IDEA WHERE THE ELECTRIC EYE OR TRANSMITTER ARE. ALSO, I CANNOT GET THIS SYSTEM TO PROGRAM TO MY HOMELINK SYSTEM ON MY NISSAN PATHFINDER. I JUST MOVED TO THIS HOUSE AND AM ONLY RENTING, BUT I COULD PROGRAM IT TO MY OLD OPENER. I HAVE MASTERED THE CODE AND THE REMOTE PROGRAMMING, BUT NOT THIS. THANKS FOR ANY ADVICE.
  • david-bann May 23, 2009
    I have a similar problem - I have not yet linked it to temperature though... My door also closes all the way and then opens again as if it hit something. I have tried to see what is causing the problem, but have not been succesful - I don't know how the sensors work, and how to adjust or play around with them...
I can't believe it! My opener works fine a 10 degrees and above but below 10 degrees it would go down a little ways stop and go back with the light flashing. I checked the electric eye and found it would go out of alignment when the temp drop. Who knew!
I made the adjustment and it now works fine.
Posted on Jan 24, 2008
I had a similar problem and traced it back to the electric eye that makes sure there is nothing in the way of the door that would be crushed by it when it closes. Somehow, the receiving end was moved slightly. It was receiving enough light to start the door moving, but the shaking of the door as it came down, diminished the light enough that the door thought something was in the way and went back up. Once I aligned both the light transmitter and receiver, it started working again. Good luck to the rest of you.
Posted on Jan 19, 2008
Our automatic garage door opener does not fucntion well in very cold temperatures (below 32 F). It will not close all of the way and will stop or will stop about half way down and return to the up position...
There is no adjustment for temperature. Make sure the tracks have not been greased. This sometimes causes a problem when it congeals from cold weather. There is no reason to ever lubricate the rails. You can try increasing the down force. It is a control on the rear of the motor unit near where all those white wires go. Increase it a 1/4 turn and try.
Jan 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door not opening properly.
Check the springs on your garage door. If one is broken, the opener will not have enough power to raise up and it will stop like that.Or the up and down limit settings have gone off or bad.
Dec 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opening when hitting close button
If the main light is flashing 10 times when the door reverses to the open position it is a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit. Tweak them a little if necessary.
Sep 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
How to switch back to automatic after manually close the garage d
mikey-moore's advice helped me figure out what to do but it's not exactly what I had to do. Manually open the garage door all the way. Then hit the automatic button you normally would use to open and close your garage door. The bracket slides back and locks into place. Hit the automatic button again and the garage door should automatically close.
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
After opening, my automatic garage door creeps back down a bit
There is a sensitivity switch for both directions, open and close. If you access the garage door opener in the ceiling, you will see two adjustment screws for calibrating these. I would highly recommend following the instructions in your manual, as these are life safety adjustments! Your sensitivity for closing the door is adjusted to the positive. You just need to back it off a little. Place a 2x4 on the floor of the garage where the door comes down. and when the door hits the 2x4, it should automatically come back up. If not, you adjusted it too far. Hope this helps. and remember, check the manual for your specific adjustment procedures.
Mar 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears auto garage door opener not opening and closing properly
there are little knobs on the back for adjusting up and down turn them up and you should take care of your problem.
Feb 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not close in cold weather
The are two knobs on the back of the opener. They are force settings. One is the upforce and the other is downforce. Turn both knobs to "5" and try. This should take care of the problem. They come from the factory at 1 or 2 and when it gets cold it takes a little more force to cloce the door.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont close in cold weather
find force adjustment on logic board and turn clockwise A LITTLE to increase down force. Try to stop door. You do not want TOO MUCH FORCE as that is a SAFETY HAZARD.
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Automatic garage door
There should be 2 sensors on the bottom of your door on the inside, 1 on the right side and 1 on the left side.
These sensors serve 1 purpose to send a beam or reflection to each other.
If something is blocking this reflection or is in front of the sensor the door will always come back up.
It is a safety feature so nothing or no one gets hurt when the door is closing!
Sep 22, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
4,833 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
