Question about Lexmark X75 All-In-One InkJet Printer
Black cartridge not printing
Put new black cartridge in will not print, I reload it several time. will not print out black ink Color only Black ink will not print Changed cartridge Went htrough all the steps The cartridge was refilled and worked for a while and then stopped so I changed it again still no luck
  • jtkinlow Apr 08, 2009
    New black ink cartridge not printing.
    Problem Solver:
  • 35 Answers
If you are refilling cartridges.... They don't last for ever. You may have air in it. Don't let them run out before you refill them. Also, it may be poor contacts.
Posted on Jan 15, 2008
  • 12 Answers
This is what worked (so far) with my Dellblack cartridge not printing - 1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Posted on Feb 02, 2008
SOURCE:
I just put in a new black ink cartridge and it will not print black ink. The color ink prints, but the black will not.
Hello nicfurtaw, there are dried ink on the ink carousel, or cradle, you may need to soften the ink. Use cotton buds, dip into warm water and gently wipe the ink hole where the ink pass through, until the carousel is clean.
  1. remove the black ink cartridge
  2. find the spot where the ink pass through
  3. see dried ink on it.
  4. use cotton buds dipped in warm water to soften the ink.
  5. do this several times
  6. clean enough, test to see if the black ink will pass through
  7. replace the black ink cartridge
  8. test the printer.
Feb 10, 2011 | HP Photosmart C3180 All-In-One InkJet...
My printer is not printing out any black ink onto paper. Only the color is printing out onto paper. I put two brand new cartridges in for the black ink and color ink, and it says that the ink levels are...
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Sep 03, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Can't get printer to print in black
unfortunately some printers will not allow such and needs to have all the cartridges working for it to print. this is regardless if the black is still okay. i suggest to go to your nearest store and purchase one.
Jun 19, 2010 | Dell 926 All-In-One InkJet Printer
My black ink wont work.
refill of cartridge several times is not that advisable. time comes that ur cartridge will be damaged. possibility of damaged:
1. the circuit itself in the cartridge might be broken
2. overload of ink.
recommendation:
1. replace a new one or secure other cartridge w/ same spec of ur current cartridge.
Apr 08, 2010 | Dell 924 All-in-One InkJet Printer
Black won't print. Changed all ink cartridges,
It may need a new purge assembly, if it doesn't clean both sides properly either color or black will quit. You might try a new printhead first, QY6-0064-000 around $40.00
Jul 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Printer will not print black ink.
I had this problem recently with my IP90. Both the black and color heads were clogged. After running the "canned" routines several times to clean the heads and deep clean the heads...still didn't help...here's what I did:
1. open the top lid to have the cartridges that are inserted in the print head to the middle of the printer.
2. remove both cartridges
3. What is left there is the print head..slightly move it to the right and gently lift the print head lock.
4. Grasp the print head and lift it out.
5. Have severasl paper towels hand and know that you will have color and bw ink on your fingers
6. Put the print head on the paper towel
7. Pour rubbing alcohol on the blk and color heads and let them sit of about 10-15 minutes.
8. after that dry the heads and re-insert them in the printer
9. I put new cartridges in the printer and ran clean and deep clean a few times.
10. May color and black and white print is back!
Hope this helps.
cw
Feb 16, 2009 | Canon PIXMA iP90v InkJet Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Black ink does not print
I have a problem about my printer here. it doesnt print black color even if i replaced it with new cartridge...anyone have solution about this pls help....joy
Feb 16, 2008 | HP Photosmart C3150 Printer
Three things peggye: one you have bought a dud cartridge. It happens. Two: you did may not have removed all the protective tape or it is not a comapatable cartridge by mistake. If tow is not the issue, try 3 first before resorting to 1. Three: your printheads are blocked for black ink. Manually clean with proper cleaning solution, using cotton buds, right doen where cartrisge sits, and use a baby wipe (unscented to press firmly on bottom of cartridge where ink comes out. Put it back in. Print now. Post back if no good. Cheers, lilacgerry
Sep 02, 2007 | Lexmark X4270 All-In-One InkJet Printer
Printer will not print black, but will not let me replace black cartridge
The Epson FAQ lists several techniques for resolving this problem. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14374&infoType=Overview There is also an animation on how to replace the ink cartridges. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=HowTo&oid=14374&prodoid=11473
Oct 14, 2006 | Epson Stylus 880 InkJet Color Printer
Lexmark X75 All-In-One InkJet Printer Logo
322 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
