Question about Certance (CL400LWF-SE) (CL400LWFSE) Ultrium Tape Drive
Certance LTO3 POST failure error code
I have a Certance/Quantum LTO3 400/800GB stand-alone drive. The Power light is on, the Error light is flashing quickly, and the Status light is on solid.
The drive has been power cycled, as has the server it is attached to. The other tape drive in the case works fine. I have a feeling that I am completely hosed. Is my best bet to get Quantum on the phone first thing in the morning and see about a replacement (as the drive is still under warranty)?
Thanks,
Chris
  • 1 more comment
  • BoginMunns Aug 13, 2008
    Certance CL1101 LTO-3 Tape Drive (Full Height) - Backup Failed last night. Tape never popped out. BE says Device is offline, even after I place Online. Restarted Server and 2U Rack Mount Box that holds Tape Drive. Tape Drive, after power cycle displays Power Light as Solid Green, Activity Light Off, Error Light Rapid Flashing Red, Status Light Solid Amber. Please help?!?!?
  • j-post Sep 19, 2008
    Our tape drive also refuses to eject and has the flashing error light with an amber status light. We are ready to return based on a week of testing with another issue, now this!
    Did  you have any luck?
  • Cmn32480 Nov 24, 2008
    The drive has a 3 year warranty (I think) with Quantum. Return for warranty replacement.
5 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: 40 GB Data backup cartridge keeps ejecting
Been a long time since using one of these, but you more than likely need a head cleaner and solution. They are mentioned on this site if you read down http://www.taperesources.com/HARDWARE/ETRA-40-I-AT-Q.html
Posted on Apr 23, 2007
  • 30 Answers
SOURCE: Certance tape drive (Ultriulm 3) won't work
can you upload a little more info please
Posted on Jul 24, 2009
JaxPlanet
  • 922 Answers
SOURCE: ultrium tape stuck
I highly recommend that you contact Certance for assistance. Tape drives are expensive and you don't want to risk damaging it.
If you are feeling brave you could see if you can manually eject the tape.
Remove the tape drive from the chassis and look for a manual rewind screw on the bottom or back of the drive. This is provided on some drives to allow you to manually wind the tape back into the cartrige and eject it.
I hope this helps.
Posted on Aug 11, 2009
SOURCE: Certance Ultrium 2 tape drive
Bet if you check, it is not overwritting the tape (appending) on the first tape, but will overwrite the second. Check the media properties to see. If it is this, it has probably had an update when it started going south....
Same problem here, on with Symantec about it...
Posted on Jan 13, 2010
IBM LTO3 error code 5
Hi Ray
Error 5 on the front panel usually refers to a read write error of some description.
First of all try a (not expired) cleaning tape and then try a backup on a BRAND NEW LTO tape.
If this does not solve the issue then your drive probably needs a repair and service due to a worn or badly calibrated head.
LTO Repair service UK Based All manufacturers of LTO drives repaired
Mar 14, 2014 | Computers & Internet
Tip
Ejecting magazines from the LTO3
If you need to remove a magazine or both, you can always stick a credit card or hotel room card between the slot on either the left or right of the LTO3 display, this will disengage the lock allowing for one or both magazines to open. Normally you can only remove one magazine at a time.
on Jul 20, 2009 | Quantum SuperLoader 3 LTO-3 Tape Drive
Just want the error code lights on front.
They're both status and error indicators.
Certance was formerly known as Seagate. Using that as the make the Installation Manual popped right up on a web search.
http://support.gateway.com/s/Manuals/servers/seagate_scorpion_8-24_install_guide.pdf
Page 17 lists the various combinations of the two LED's (flash codes).
Sep 23, 2011 | Certance STD224000N-SS (662676607077) DAT...
NEED DRIVERS FOR STD224000N
The driver for this Archive > Seagate > Certance > and finally Quantum drive was included in Windows. Try Window Device Manager > select the drive > properties > update driver > Can Windows Update select No not at this time > Install from a list... > Don't Search...> Tape Drive > try either the Standard tape drives DAT driver or a Compaq DAT. If none of those work you are probably out of luck.
Jan 07, 2011 | Certance Seagate® Scorpion 24...
I am getting a DRV PREV REMOVAL TYPE (46) message on display, every time I try and Inventory a tape or run Lable Media.
I have two of these Quantum SuperLoader 3 (with LTO3 drives) and one does keep giving me the same hassle. I haven't figured out how to fix this, but I've gotten past the error: disconnect the autoloader from the host computer (i.e. or stop rsm, mtx, or whatever controlling sofware you use), reboot the autoloader, get the tape out of the drive (e.g. move command from the autoloader's console or web interface), insert a cleaning tape (a few times), reconnect everything (i.e. start back up your controlling service).
I’m happy to assist further over the phone at https://www.6ya.com/expert/shunter_ccf54e0913bd0501
Nov 29, 2010 | Quantum SuperLoader 3 LTO-3 Tape Drive
Hp error code help
check out this site
http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp
Jul 31, 2009 | HP Photosmart 3210 All-In-One InkJet...
Panasonic Viera TH-42PV30 No picture & Stand-by light flashes 4 t
I would guess a power board failure. The blinking light is an error code.
Nov 17, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Quantum superloader not showing in windows device manager
First off, I have to say that I have had nightmares with Quantum tape libraries. It is possible that they are still manufacturing lemons. I had one replaced 4-times and it still did not work!
Start troubleshooting by making sure that it is identified by the controller card it is connected to. You should see this during the server POST before Windows starts. If you don't see it there then Windows definitely won't see it. Send it to Quantum for service.
If the controller sees it then make sure that you are using the Backup Exec drivers. Never use the manufacturer's drivers with Backup Exec. Veritas, now Symantec, has a downloadable utility called the Device Driver Installation Wizard that will make sure you have the correct driver loaded.
I hope this helps.
Nov 13, 2008 | Quantum SuperLoader 3 LTO 2 Tape Drive
Certance (CL400LWF-SE) (CL400LWFSE) Ultrium Tape Drive Logo
643 people viewed this question
Top Certance Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Certance Computer and Internet Expert? Answer questions, earn points and help others
