Question about Xerox Phaser 8500/DN Printer
Maintenance kit for Xerox 8500
I am using a remanufactured maintenance kit for my Xerox 8500, I have reset the chip on the kit, but the firmware installed on the printer can tell the chip has been reset and a error msg comes up saying non-xerox maintenance kit.
Question, Does any body know a solution to reset the chip so the printer will think its a xerox maintenance kit?
  • 2 more comments
  • garolgarel Oct 03, 2008
    Hi, i'm trying to reset the chip on te maintenance kit of phaser 8500 but i don´t have the software to do this. Can you help me? can i download this software from some site? Thank you from Argentina.
  • Anonymous Mar 13, 2014
    maintenance kit reset
  • Anonymous Mar 27, 2014
    I installed a non xerox Maintenance kit counter chip to extend the life of my kit back in 2012. A few weeks later in 2012 I became unhappy with me choice to do this, so I installed a brand new Xerox kit. The new kit never reset the "remaining life". I know I need a new one now but I would like to find out how to reset the machine so it will warn me in the future to order the next kit.
  • Anonymous Mar 31, 2014
    I replaced a maintenance kit, and the printer is telling me that it's ready. But it is not accepting my file to be printed. What have I done wrong?
  • 2,072 Answers
Contact the company that you purchased the maintenance kit from.
They should have the solution or send you a replacement.
I know of no way to change the Xerox printer to match up with a non Xerox maintenance kit. They would not set the machine up to accept non Xerox products since that voids warranties.
Posted on Jan 15, 2008
  • HamburgerMan Jan 13, 2011
    I've used this to reset my 8500 maintenance counter to 30K pages, it works on 8500/8550/8560/8580/90 8860 or all 108R00676 maintenance kits. Not sure but I think it would work for you situation. The link is:
Xerox phaser 8550 - does a bad print head make a noise like the gears are bad or missing??
No, the noise is made when the printhead cannot tilt back and forth which is caused by either a bad camshaft or process drive motor, they are available in a kit, the part number is 8500-Z2. See link below:
Mar 29, 2016 | Xerox Office Equipment & Supplies
Xerox 8560 Maintenance Kit remaining life
You're probably lucky that your machine still works after using non-xerox products, in any event, I'd suggest a new Xerox Extended kit, it's possible the non-xerox product didn't work as intended and your replacement kit wore out faster because of it.
The kit contains a micro chip which "resets' the counter in your machine, as the count comes from the kit, not the machine itself, however, the machine is capable of sensing when the maintenance kit has reached end of life regardless of count.
Additionally, you should check the wiper blade (you can see it when you remove the maintenance kit) for excessive wax buildup which generally means the machine needs service.
These are great printers, very fast for the quality. They can be quite a nightmare to service due to so many systems which have to be exact!
My #1 advice on this product is if you own one, never ever move it while it's hot! or you could face a very expensive repair!
Mar 27, 2014 | Xerox Phaser 8560N Laser Printer
I have a Xerox 8500 DN and it is not recognizing the maintainence kit, have tried compatible and OEM Xerox kits but can not get to identify. on troubleshooting Test: 57 Drum Maint. Kit :Ck DM contact...
The maintenance kit needs to touch contacts to reset it.
There is a camshaft 020K14800 which may be cracked and therefore doesn't position these contacts. I suggest replacing this.
Item, Inc.
Nov 16, 2009 | Xerox Phaser 8500/DN Printer
Need to print but the maintenance kit is late
No. That maintenance kit has a chip attached to it. That will reset the machine, It is just a white roll impregnated with silicon to clean and maintain the surface on the drum.
It will take replacement of the kit to reset the machine.
Oct 06, 2009 | Xerox Phaser 8500/DN Printer
Phaser 8560 warns to replace the maintenance kit
Call Xerox. If they can't reset it, They will sent you a new Mtc kit. Thay will want that count sheet. Plus, They will not warrenty any kits over 6 months.
Sep 26, 2009 | Xerox Phaser 8560MFP Laser Printer
8560 DN Replace Maintenance Kit
the maintenance kit keeps your melted crayons from sticking to the roller. You know the smell... and no you need a new one.
Sep 15, 2009 | Xerox Phaser 8500/DN Printer
The printer makes a terrible noise during warming up
for a start: these machines are quite noisy at startup, so this may be normal. do you have problems printing? because if you don't, it's not worth trying to fix something that isn't broken. if the printer tells you the maintenance kit needs replacement, you can open the side panel, and feel a little lever at the bottom side of the maintenance kit (yellow-ish drawer). you need to push this lever upwards, while pulling out the maintenance kit.
Jun 22, 2009 | Xerox Phaser 8500/DN Printer
There is no reset. Xerox never designed a supply reset for this machine.
If you installed a new one, either 1) you've got a bad one (get it replaced under warranty) 2)
the chip is not being read (due to drum maintenance camshaft cracked and out of position
Jun 03, 2009 | Xerox Phaser 8560MFP Laser Printer
Phaser 8400/8500/8560 maintenance kit
No, it will not work because the chip (CRUM) is not compatable.
Jan 13, 2009 | Xerox Phaser 8400 Laser Printer
Reset counter on Xerox Phaser 8200
I think the maintanance kit runs out based on time and usage, which ever comes first, roll back your printers clock a few months or more and see if that fix's the problem.
Oct 05, 2008 | Xerox Phaser 8200DP Thermal Printer
Xerox Phaser  8500/DN Printer Logo
2,011 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
