Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly. The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted. Mine, I just unplug it from the USB and plug it back in to reboot the software. If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN Click 'Open Menu' From 'Tools; navigate to, and click, 'Audio and Video setup' Set your speakers Click 'Test' - if OK, move on. Set your mic as default Use the slider to set volume and test. Click 'Next' This takes you to the video setup Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN Use 'Webcam Settings'to fine tune the picture. Click 'Finish'
Your webcam has to be configured to any chat program that you want to use it in WLM ( MSN) Open WLM Click 'Open Menu' Click 'Tools' Click 'Audio and Video set up' Set your mic as default and test Click 'Next' Set your webcam as default and trim picture quality using 'Settings' Click 'Finish'
I had many problems with MSN Messenger several years ago (10) - I went to Yahoo and have not been disappointed at all - except if you have missed a notification (not in your email) online with Yahoo that your Messenger/IM has a newer update available, then it will not allow certain webcam activities with your chat buddy until you update.
since the cam works fine during the video call problems might be in your network connections..try using a different service provider like gmail or yahoo for the same video call after checking your network connections.(if you dont know how to do it, then click on the browser's (internet explorer or firefox)tools, >options>restore to defaults in the first tab itself)..
first you need to know that if you used xp ...and upgraded to vista ...you need to find a compatible driver for your web cam too ...if your web cam used to work just fine on vista ...and its just the msn issue ...just reinstall the latest MSN messenger and it should be enough ...also verify the proxy servers on the messenger preferences..and set 'em to fit the kinda conexion you use... but I suspect a problem with the program settings ...so the easy way is just to install the latest messenger(MSN) available for vista ...and it will be ok
Hi, I am attempting to use the camera on ie as a video call problem is i can see a black screen. The camera is work as i can see myself on its software. I tried going to msn setting but have had no luck. it seems that the two the camera and ie
