Question about Proscan 32LA30Q Television
Hooking up dvd player
Where do the red white and yellow plugs go into the back of the proscan model 32la25q and if I have them in the right spots( 14,15,16 ) why can't I watch the dvd. How do I get the regular picture off the tv and the dvd on????
  • Anonymous Jan 15, 2009
    I don't know how to hold up DVD player to tv through a direct tv channel box
You have wires hooked properly.
On your remote, hit input button, press down arrow once to AV then press right arrow button.
Then watch a DVD.
It worked for me.
Good Luck
Posted on Feb 02, 2008
How do I connect a WII to this TV?
plug the red and white and yellow plugs into the AV input on the back of the TV rather than the component in on the TV. (they look very similar easy to confuse)
Jan 20, 2015 | Proscan 32LA25Q 32 in. LCD TV
Trying to hookup a dvd player model #DX-DVD2
You need 3 RCA plugs... generally colored red, white, and yellow. on the back of the DVD player plug the yellow to video out, the red to audio out (stereo), and the white to audio out (mono). The other side of them goes to the back of the TV... the yellow video input 1, the red audio (R) input 1, the white Audio (L) input 1. Then take the cable service round coax cable and screw it into the back of the DVD unit where it says Coax. Get another short coax cable and hook to back of the DVD unit on Cable out, and the other side to the back of the TV under cable/vhs. And that"s it! Hope that helps you!
Chuck
Jun 23, 2012 | Dynex DXDVD2 Player
How do I hook-up a dvd/vcr.
Hello dgrant13,
All you need to do is use a composite cable, or known as RCA cable (the red, white, and yellow cable). Both ends of the cable should have red, white and yellow. You just need to find the red, white, and yellow on the back of the dvd/vcr where it says audio/video out (AV out). Then match the colors and plug one end to the back of the dvd/vcr and the other then (matching the colors) to the Proscan tv where it says audio/video in (AV in). Good luck.
Joe
Aug 28, 2011 | Proscan 32LA30Q Television
How do I hook up a DVD player to a proscan 32 inch flat screen tv?
to connect your TV to your DVD, you will be needing a RCA wire (Yellow, white and Red wire). The yellow stands for video (visual/display), while the read and white stands for audio (sound).
Look at the back of your DVD, look out for Video Out, connect the yellow wire there. Also look out for Audio Out L & R, connect the white and red wire there.
Then turn the back of your TV, you will find Video, and Audio IN, Connect the other part of the wires from the DVD to the DVD, that is, Video for video and audio for audio.
Once you have connected the wires, turn on your TV, and your DVD player, press source on your TV remote to AV, and you will see your DVD displaying on your TV.
That's to hook up your DVD to your TV. Follow instructions carefully and you won't have any problem.
Good luck.
Apr 17, 2010 | Proscan 32LA30Q Television
Need to connect dvd player have yellow, red and white connectors
Red is right channel, White is Left Channel, and Yellow is video.  If you just got the TV and DVD player its a pretty simple setup.  Just look on the back of the DVD player and hook the yellow cord to video and hook the other end to video on your TV.  Now just plug in the red and white cords to the audio on the back of the DVD player and connect the other ends to audio on the back of the TV.  You can bypass these connections and just get a HDMI cable which has video and sound all in one convenient cord, but they cost more.  You just connect the cord on the back of the DVD player where it says HDMI and then plug the other end to the TV where it says HDMI.
Nov 05, 2009 | Televison & Video
I have a proscan tv model #PS27108, I do not know how to hook up the dvd player in regards to the cords and what channel to put it on? I would appreciate any help with this! Thanks in advance?
The ProScan will accept input on input 90/91/92 using the connectors on the backside. You can use S-video[the little round black connector] or the composite video [yellow connector] for the video in and use the red / white pair for audio in.
90 selects S-video and audio 1 in
91 selects composite and audio 1 in
92 selects composite in 2 and audio 2 in
Connect these cords to the S-video or composite yellow output, and the Red-right White- left audio outputs on the DVD.
If you don't want to do this, get a RF modulator ~$15, and connect the yellow/red/white from the DVD output to the inputs on the modulator, and then connect the RF [cable] output of the modulator to the antenna input on the ProScan, and tune channel 3 or 4.
tom
Oct 22, 2009 | Proscan PS27108 TV
How do i hook my dvd player to my tv? i have no manual to show me where to plug the wires into the back of my tv.i have a proscan 32LB30Q LCD
Hello pebbles12137,
This depends on what you want to do SD or HD
First if you just want to connect for SD only
Here are Three ways:
1) connect the coaxial cable to the DVD player F-connector (sliver screw connector) and the to the TV's Antenna in F-connector.
2) connect the yellow, red and white RCA connector end wires to the yellow, red, and white RCA Jacks of the TV Yellow (video in), Red (Right Audio in), White (Left Audio in) do the same for the other end into the DVD player (Best SD Method)
3) connect the svideo cable into the s-video socket of the TV and the other end to the s-video socket of the DVD player
For HD, Here are the connection methods:
1) Connect the HDMI cable to the HDMI in of the TV (HDMI1)and the other end of the HDMI cable into the DVD player. (best HD method)
2) connect the Component video cable (RGB) into the RGB sockets of the TV (should be marked as Component 1) and connect the other end to the DVD player (using this method you will have to connect the Red and White audio cables to the audio input jacks of the TV from the audio out of the DVD player)
These are the SD and HD methods.
I would suggest using the HDMI cables only, its the best choice and the simplest.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 21, 2009 | Proscan 32LB30QD 32 in. LCD TV
DVD Hook up to Proscan TV
if using RCA connector cables, connect the left and right audio cables to D and D1, then connect the Video cable to the video connector right above the S Video port.
Jun 20, 2009 | Proscan 32LA30Q Television
No signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Feb 03, 2009 | Proscan 32LA25Q 32 in. LCD TV
Hook up portable dvd to tv
Connect the phone jack sized end of the wire to the portable DVD player and then connect the 3 RCA's to your tv in the color coded spots. Yellow for Video, Red and White for Sound.
Dec 18, 2008 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
Proscan 32LA30Q Television Logo
200 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
