Question about Whirlpool GGQ8831L Gas Dryer
Whrilpool gas dryer
Our gas dryer runs off propane and has an adaptor to do so. However, once the tank ran dry the dryer stopped working. ( of Course) However, once the tank was refueled the dryer operates but does not get hot. I smell no gas and have checked all the electric connections. I see there is a very small veiwing hole up front but how do you access the burner area? I see no outside panel for cleaning or service? DH in Cabo
  • robert samples May 11, 2010
    the first thing i would check is to see the gas line for the drier is on then i would pull the gas line off the pressure regulator to see if when you ran out of propane trash stopped up the screen in the regulator ok if all that's cool then slightly crack the line and bleed the air ok if that don't work respond to me with model number and age of unit we will go from there ok we can fix it just hang with me oh on the regulator clean where the gas line comes in and is attached there is a catch screen there
  • 283 Answers
Let it run. If nothing has changed, the dryer will go through several relight cycles and should eventually purge the lines of air.
Posted on Jan 16, 2008
My fire place elecric starter won't work after running out of propane
Most likely, you need to "bleed the line". The new propane needs to travel to your fireplace, but you have a huge air pocket in there now since it ran dry. It takes forever for the air to "bleed" out through the tiny orifice of a pilot light, especially if the distance from the fireplace to the tank is far.
Jan 28, 2013 | Skytech 3301 Thermostatic Gas Fireplace &...
I have a Kenmore Elite He3 dryer that runs on propane. The dryer worked fine until i ran the propane tank empty. When I filled the tank the dryer worked but did not heat up. I bleed the propane line...
To check the igniter ya need to use multimeter set to ac voltage and check for 120 vac coming into the igniter if ya have 120 volts ac and the igniter does not glow the igniter is the problem. This tip i wrote covers what to check when a gas dryer does not heat
Sep 24, 2011 | Dryers
My Maytag Alliance gas dryer won't heat up at all. The dryer keeps running due to the temperature not changing. There is no heat at all. I ran out of propane - the dryer stopped during the cycle, the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
Sep 05, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
A friend gave me one kitchenaid dryer , i don't understand. canI use eletric power and propane, or only propane. I don't have the propane pipes conections, can you please help me understand it?
Your propane dryer only dries with propanr. The electrical cord is for the motor that turns the dryer and for the controls. If you don't have gas piped into your house then your gas dryer is useless. Either get an electric dryer or pipe gas into the house. If you have Natural gas in your home, then you need to get a conversion kit to make your dryer run on Natural gas.
Jun 17, 2010 | KitchenAid KHEV01RSS Dryer
Gas dryer on, won't heat, just had propane delivery,tanks were em
I hope you didnt blow up by now, but your to hold a pilot valve down while igniting it
and keep down for 1 minute then release then turn valve to keep the pilot to operate the valve
Jun 18, 2009 | GE DBXR463GB Gas Dryer
Whrilpool gas dryer lgn2000jqd stops heating half way
u have a maf coil the dryer has a prim/ second coil remove and replaced come in a kit
May 12, 2009 | Dryers
I moved and after hooking up my gas dryer to gas tank it will not heat up....
were you on propane b4 the move or natural gas? A natural gas dryer will not run on propane nor a propane one run on natural gas
Jan 14, 2009 | Kenmore 73932 Gas Dryer
Bosch dryer not heating
make sure you try it a couple of times. gas takes a long time to travel to the pipes. no way to purge the lines.
check if there is propane in the new tank, check if the valve is open, check if the propane is at the hose going to the dryer already.
tnx 4 using fixya,
Oct 11, 2008 | Bosch Nexxt WTMC 6500 Gas Dryer
Dryer LG 6DTD3120
You should change it back to regular gas the problem is in pressure reg gas come to your home at much greater pressure then propane that's why it takes longer to dry the other thing is to keep your lint trap clean because it can affect drying once in while blow out lint hose as well
Jul 26, 2008 | Dryers
Whirlpool GGQ8831L Gas Dryer Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
