Question about Foxconn K7S741GXMG-6L Socket A/FSB333/DDR266/MATX MotherBoard (MOTFO62)
Post issue I just got a brand new K7S741GXMG mobo and i cannot get it to post. Everything powers on fine, yet my monitor acts like it can't detect anything. any help?
  • 42 Answers
I can't get Foxconn's website to pull up ATM, but I had this sort of issue once before, and felt completely stupid once I figured it out, and this is going to sound strange, but, remove your CPU fan and try to power up. If it does power up, then your CPU Fan is shorting out the system. If that doesn't fix it, then it is possible that your processor is not supported by the motherboard.
Hope this helps!
Posted on Jan 15, 2008
I have been tasked to fix an Acer M3802 just out of warranty. It will not post. I have pulled all perifrials, USB, SATA, WNIC, and Vid card. Fires up fans spin - no post. I reseated proc with new arctic...
Either a MoBo or CPU problem. Do you not have a post analyser that plugs into a spare PCI slot? You could then start from bare bones and progress through or at least know it was the CPU or MoBo quicker.
Jan 06, 2011 | Acer Computers & Internet
My power supply died (popped), so I replaced it (Antec SL350 with an Antec SL350S). However, when I turned on the switch on the back of the power supply, the motherboard powered up immediately (tower...
If you "popped" the power supply, I would check to see if the RAM might have taken a hit as well. Ram chips and CPU are sensitive when it comes to power surges. I would troubleshoot the system, unplug everything. you need monitor, power, cpu, and ram (1 at a time). Check to see if the system will POST. if you do get it to POST, start with 1 item at a time and see if the system will POST every time. If nothing happens, there is a chance you may have a damaged motherboard or cpu.
Mar 28, 2017 | ASUS A8V Motherboard
Installed new equipment, now monitor is blank
just dump everything and buy a branded new PC....
u will be increasing ur;s not worth this much effort....
the kind of work u have seems ur an expert so u urself work it out what's wrong...and where did u make a mistake...
i guess ur CPU and MB are not getting along....some issue with ur integration.....of all parts....
Dec 18, 2009 | Computers & Internet
ASUS P5N32-SLI Premium mobo w/ WinXP Pro (SP3). System dead
After doing all of that and nothing has changed, sounds to me like your mobo is bad
Jun 26, 2009 | ASUS AI Lifestyle P5N32-E SLI...
Fan running, HDD light solid, no display
I assume there are no post codes (beeps)?
Pull everything including the video card, leave only the RAM and CPU installed.
Try powering it on, You should hear a long beep, then some short ones to tell you the video card wasn't detected.
If you still don't get any post beeps, try resetting the BIOS, and re-seat your RAM.
If it still doesn't post it could be a system board mounting issue, bad system board, bad RAM, bad CPU, or bad Power Supply
Jun 24, 2009 | E-Machines T2240 PC Desktop
No beep,No Display on my monitor,only CPU heatsink fan is moving
You motherboard has onboard video. It's possible it needs to be disabled and the option changed to use the pci or pci-express slot for the Ati card you installed. Since you have no post error beeps this is the best place to start. Also I had built a system not to long ago and had a similar problem. Resetting the cmos on the motherboard (usually a pin combo) solved the issue.
Start by hooking up your vga cable to the onboard video.
Hope this helps.
Apr 07, 2009 | MSI P7N Diamond Core 2 Quad/ Nforce 780i...
I can't get this thing to POST
Hi just to double check are you using the correct processor and ram supported by your mobo . These mobos are designed to support only a few types of memory . Since you do not hear any audible beeps of POST progress check the processor and also have you plugged all the power connectors properly to the mobo from the PS.
May 25, 2008 | Intel DG31PR Motherboard
Got power, but no booting activity
Assuming you have compatable memory fitted to the mobo; if you cannot get as far as the power on self test (P.O.S.T) or into the bios to set it up, remove all components you have fitted apart from the memory and the hard drive and a graphics card if not on board graphics and see if you can get as far as the post screen. If nothing appears and you just get a flashing cursor, then either the bios chip is faulty, or you have possibly stressed the board when fitting components and accidently broke a soldered contact. If you do get the post try putting back one peice of hardware at a time until you come across the problem part.
Jul 10, 2007 | Abit SG-80 Motherboard
Computers & Internet Logo
54 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
