Question about JVC HX-Z10 CD Shelf System
System seems to operate fine but no sound
The unit (JVC HX-Z10) powers up fine and seems to operate normally but doesn't produce any sound. I have tried all the differen't functions cd player, tuner etc and all seem to operate normally but there is no sound output from the speakers. Have also tried plugging in headphones but no sound from them either. Any help appreciated
  • Nathan
    Nathan Mar 05, 2009
    The unit powers up fine, but sometimes there is no sound, and when there is sound, if i touch anything on the whole unit, i will hear a loud static noise. is there any way that can be fixed? if so, where can i buy the part? how much will it cost?
    Problem Solver:
  • 5 Answers
There is something that is called a relay in side of the set when u open it u will see it were u put the speaker wires behind that two black boxes those are the relay look between them n see if any thing had burn if so u need to change that part of reach me at 742-2520 if u want
Posted on Jul 14, 2009
  • 67 Answers
Sounds to me like you may have a channel blown. If one of the channels is blown you will have your dc protection relays activate so none of the channels will operate and audio may be muted explaining the headphones not operating. Definetly sounds like it needs to be serviced. Sub woofer poweramp prt # stk412-420 or left /right poweramp prt# stk432-070 most likely suspects with the sub amp being the most common of the two to fail. Could also be broken solder at poweramp ic's seen that also Just a couple possibilities
Posted on Jan 15, 2008
Subwoofers arent working
Try looking in the FIXYA section for electronics.
Mar 06, 2014 | JVC HX-Z10 CD Shelf System
Unit powers up, cd and radio seem to be operating properly, but no sound is heard, unit worked fine a few days before, all wires are conected, everything seems unchanged you said...the unit powers you don't have a "dead set".I don't know if the speaker can be disconnected from the unit.As a rule of is very rare that both channels (left and right )fail at the same is usually one channel while the other speaker still operates.This is what I want you to do...In a quiet room..get really close to the unit...Switch it on and listen for any sound from the speakers...get really should hear a slight hum from the woofers and a high frequency "hiss" from the tweeters....If no sound is heard..switch the unit off..You should hear a "plip" sound...If not...switch it on should hear a slight "bump" sound from the woofers...If you hear no sound from the speakers at all..there is a problem with the output stages of the amplifier section.If you do hear sounds fron the speakers,,Turn up the volume and watch for an increase visually on the display (such as ascending numbers).If there is no indication of a volume increase...The "mute" may be stuck on..Try switching it off and on...please let me know what happens after you do all the tests....Looking to hear from you......PEACE!!!
Jul 11, 2011 | JVC HX-Z3 CD Shelf System
My JVC CA-HX-Z10 works just fine but the speakers tend to turn off. I unplug it for a couple of hrs and then plug it back in and it works just fine for a couple of minutes and then the sound just goes off....
This is a semiconductor or capacitor thermal problem. You will have to be able to get to the circuit boards. With a can of Electronic Cold Spray (freon), you turn the unit on until it heats up and the sound goes out. Then, try spraying transistors and components once at a time, until the sounds comes back on. This will be the bad part. You will have to unsolder it and take it to Radio Shack or electronic parts store, or possibly order one online (google the part number, or value on the capacitor, etc.). Problems like these are usually transistors, and they usually only cost a few dollars (maybe $25 at the most). Inspect solder joints to see if they're cracked, or discolored (indicating a "cold-solder" joint, which you can resolder with fresh solder applied. The hardest part of fixing this type of problem, is that you have to sometimes take it all apart to get at the back of the circuit board to unsolder the bad part. Take pictures as you take it apart- they will help you putting it back together. Good luck!
Apr 22, 2010 | JVC HX-Z10 CD Shelf System
Jvc hx-z1 will not output sound to speakers
if you have old speakers laying around the house try to see what happens, if you connected the good speaker and still has no sound then the internal amp maybe is bad. Make sure it is not muted also.LOL
Aug 12, 2009 | JVC HX-Z1 CD Shelf System
No sound will come out of my jvc hx-z1 stereo.
Dec 29, 2008 | JVC HX-Z1 CD Shelf System
PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
How do i fix that i get the message on my cd play (JVC HX-D7) and it says PROTECT and shuts off by its self what do i do to fix the problem ?
Sep 27, 2008 | JVC HX-C6 Shelf System
JVC HX-C6 goes directly into "Protect Mode".
I received a reply promptly from JVC to check power connections for shorts. O course I had already done that. So as a last resort, I pushed the power switch on and held it for maybe 10 seconds. It seems to have reset the unit, and it's playing fine. Best of luck, hope you all read this and it works for y'all. AJ
Sep 26, 2008 | JVC HX-C6 Shelf System
Dec 25, 2007 | JVC HX-D77 Shelf System
Cd shelf
The hx-z10 mini stereo system is giving me the same problems again.
Aug 31, 2007 | JVC HX-Z10 CD Shelf System
Turn on Daily On Alarm Clock
The instruction manuals are on this link; Hope this helps :)
Jul 24, 2007 | JVC HX-Z10 CD Shelf System
JVC HX-Z10 CD Shelf System Logo
353 people viewed this question
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
