Question about Dell 924 All-in-One InkJet Printer
Printer prints later after a shut down
I try to print something, but it won't activate the printer, until I've shut the laptop Vista down & when I reboot; the previous print jobs start printing at that time...help.
  • 4 Answers
Printer keeps saying claer paper jam
Posted on Jan 29, 2008
6ya staff
SOURCE:
In Windows 7, items put in the print queue at home won't print when I get to the office.
I don't see how this can be done, because there are 2 different print queues in question. Not to mention the lag and buffer required by the printer. So when you disconnect communication the job hangs.
Besides the spooler at work my lie on a dedicated print server, especially if the printer is on a network and and not attached directly to you PC.
Feb 26, 2013 | Microsoft Windows 7 Professional for PC
Hp pavilion dv8000 wireless printer does not work
Do you have more than one instance of the printer installed. If that happens the computer gets confused and don't know which one to print to. Also only one can be active if you have two instances of the same printer and you could be printing to the inactive one. Click Start/Control Panel and check your printers to insure that there is not more than one instance of the same printer installed.
Also check down at the bottom right near the time and if you see the printer icon open it and clear out the queue. If you've printed to an inactive printer the queue will block you so just delete or cancel the items in the queue.
Also check your printer properties to make sure it is printing to a TCPIP wireless connection and not a usb connection.
May 01, 2012 | HP Pavilion dv8000t Notebook
I've installed color cartridge but it won't print in color
Try to re-insert the color cartridge into the printer and make sure it is properly seated in the cartridge carrier.
If that doesn't help, try to clean the print nozzles. Please follow the steps below:
1. Press Copy. 2. Press Options until Maintenance appears on the display. 3. Press the right arrow until Clean Cartridges appears on the display. 4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles. 5. Print your document again to verify that your print quality has improved.
Oct 22, 2011 | Lexmark X6170 All-In-One InkJet Printer
Aswell as my daughter I've installed the drivers (Vista and 7) of the Lexmark x4550 wireless, but she can only print when my laptop is 'on'. How can she print without the use of my laptop.
All you need to do is to remove the printer currently added on your daughter's laptop(most likely it is the printer installed on your laptop)and then add the lexmark printer manually on your daughters laptop. Make sure when you do this your laptop is turned off. If this won't work, that means that the laptop of your daughter does not detect the wireless printer.
hope this helps...
Sep 11, 2011 | Lexmark X4550 Multifunction Wireless Color...
My epson DX8400 won't print yellow at all, green prints as blue, red prints pink on certain documents i've created. I have printed an email off today which printed all the colours perfectly??
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
Aug 22, 2011 | Office Equipment & Supplies
My Lc61 will not print black--on the test page, the colors are fine. I've replaced the ink cartridge and it says it's full but won't print
Most likely this is a print head issue. The print head is what the cartridges sit in inside of the printer. To attempt to resolve it, do the following:
(1) Open the printer
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water to thoroughly clean the print head and each ink cartridge.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
May 26, 2011 | Brother Office Equipment & Supplies
My computer doesn't send picture to be printed to my hp photosmart 8450. I have Windows Vista and it worked before. Now why does it show an error in the printer info and also, this printer is set as...
If there is something wrong with the printer, you should get a error message describing the error.
Does the printer have a blinking orange light after you give the print command? Then there is an error in the printer. If you have documents in the print queue, delete them. Remove the printer cable. Shut the printer down, shut the computer down. Reconnect the cable and turn everything on again.
If there is still a problem there might be something wrong with your printer.
If you don't have a blinking light after the print command on the printer, then try changing the printer cable. If not working, try another USB port. If still not working, reinstall the printer.
Sep 21, 2010 | Dell Office Equipment & Supplies
HP Laserjet 1018 won't delete a printing job
to delete the print job.
shut off the printer, disconnect the printer cable to the computer.
go to strat>>printer and faxes.
open the pirnter queue. stop the print job then delete. you may have to restrat the computer.
once the job is deleted, connect the printer cable back to the computer and turn on the printer.
Jan 09, 2009 | HP LaserJet 1018 Printer
Vista Drivers
When you click on File and print - ensure the selectionis in Active sheets (this will ensure that it only prints pages with texts in excel
Aug 31, 2008 | HP OfficeJet D125xi InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
87 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
