Panasonic Lumix DMC-TZ2 Digital Camera Logo
Posted on Nov 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pictures will not goto memory card. They only store to camera, therefore i can only take about 5-6 pictures?
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Nov 29, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2200865
Points
38521
Are the pictures stored in the memory important? Then go into the menu , scroll to "copy" and follow the instructions for copying from internal memory to card. Then, remove your card, bring up a picture from the internal memory and push the delete button...choose to delete all. Then, download any pics on your memory card to your computer using a card reader. Then, insert your card back into the camera, go into the menu, scroll to "format" and follow the on-screen instructions. After all this, you should be ok.
Card not initialized?
The error can be caused by:
1. The xD-Picture Card or internal memory is not formatted.
2. The xD-Picture Card contact area is soiled.
3. a camera fault
for 1.:
Format the xD-Picture Card or internal memory on the camera (p.130)
To format the internal memory or xD card goto format in the setup menu and chose the correct memory.
for 2.:
Wipe the contact area on the xD-Picture Card with a soft, dry cloth. It may be necessary to format the xD-Picture Card
(p.130).
If the message still appears, replace the xD-Picture Card
for 3.: You won't like this one:
Contact your FUJIFILM dealer.
1helpful
I keep getting an, "internal
Usually, an 'internal memory full' message means that you do not have an external memory where the camera can store its pictures and that it is currently using the internal memory of the camera that can store around 5-10 pictures only. So, the best option is to buy an external memory fcard for your camera. Bring your camera when you will be buying one so that the store clerk can provide you the right memory card.
Mar 26, 2011 • Cameras
Can card be reformatted
Use Setup to customize your camera settings.
1 In any mode, press the Menu button.
2 Press to highlight Setup , then press the OK button.
3 Press to highlight the setting you wish to change, then press the OK button.
4 Choose an option, then press the OK button.
5 Press the Menu button to exit.
goto the setting named format,
This will reformat your card.
Regards
GeWiz.
How do i transfer pic from the internal memory to the memory card
www.kodak.com/global/en/service
FOR MANUAL DOW[section title] Choosing Internal Memory or SD/MMCCard
The camera offers two options for storing pictures and videos:
Internal Memory —Store pictures and videos in 16 MB internal
memory.
SD/MMC Card —Store pictures and videos on a card. The number/length
of pictures/videos depends on the size of the card. Purchase accessories at
a
dealer of Kodak products or visit www.kodak.com/go/dx6490accessories. For
storage capacities, see page 114.
Managing Your Storage Location Setting (after inserting the card with power
OFF)
1 Turn on the camera.
2 In any still or video mode, press the Menu button.
3 Press to highlight Image Storage , then press the OK button.
4 Press to highlight an option, then press the OK button:
Auto (default)—the camera uses the card
if one is in the camera. If not, the camera
uses internal memory.
Internal Memory—the camera always
uses internal memory, even if a card is
installed.
5 Highlight Continue, then press the OK button again.
The setting remains until you change it and applies to all camera
functions.
6 Press the Menu button to exit the menu.
NLOAD.
1helpful
Can not transfer pictures from memory card to computer
Goto any radio shack and get a external memory card reader this will allow you to get your pictures if the camera or cable is defective.
18helpful
Getting pictures off internal memory
1....put your SD card in the slot...
2...turn cam on and go to playback menu
3....go to MENU/OK option
4...scroll down to COPY select ok
5....Then choose option INTERNAL memory to card and hit ok
How do I transfer pictures onto the memory card?
You should be able to transfer the pictures if it has built in memory. then transfer it to memory card the same way you'd take them off
9helpful
3answers
Go to the camera's "setup menu" and scroll down to the last option, "move images to card" That should put the images onto the memory card.
ERROR MESSAGE: Corrupted CompactFlash card.
Storing digital picture information to a CompactFlash card (as when a digital image is taken) is similar to storing data on the hard drive of a computer -- if the process is stopped or interrupted, the information stored is not complete and, therefore, "corrupts" the storage media. A computer will display a warning message indicating that the hard drive has errors, while a camera will display a message indicating the memory card is corrupted. The CompactFlash card corruption can be caused by: * Turning off the camera power before the photo information is completely stored on the card. * Removing the card before the photo information is completely stored on it. * Taking a second picture before the camera has finished storing the previous picture. * Camera batteries that are near the end of their life and need to be replaced. Once a CompactFlash card is corrupted, it can be used again only by performing a Format procedure. IMPORTANT! When a CompactFlash card is re-formatted, any pictures stored on it will be lost forever and cannot be recovered.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
