Question about GE WBB4500EWW Top Load Washer
Wont spin When spin cycle starts, after 4-5 seconds thermal limiter on electric motor trips. New brgs on tub,new motor installed, when turning by hand, brake releases and tub spins freely
    President:
  • 1,314 Answers
Low voltage can cause this if you can use a meter do a voltage drop test plug the meter under where you have the washer plugged in read the meter then start the washer and and see how much the volts drop if falls 12 volts have an outlet promblem let me know i will hang with you
Posted on Jan 15, 2008
I have a maytag dryer mgd9206aww i push the start button and it has power but it wont spin and shuts down seconds later
Could be electrical motor could be bad thermal limiter on motor could be shutting it off
Feb 18, 2015 | Maytag Dryers
Dryer has power wont start
Hello Dom - Being that you have narrow down some possibilities, here are a few simple troubleshooting tips that may help you get to the root cause:
1. Make sure the dryer is plugged into outlet, and plugged in correctly.
2. Is house fuse blown or circuit breaker tripped? Replace fuse or re-set circuit breaker.
3. Make sure that electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. I would recommend reaching out to a Licensed Electrician check to make sure it is on a circuit by itself.
4. Thermal limiter tripped or an internal problem with the dryer. A thermal limiter automatically turns off the motor (electric dryers only) in the unlikely event of an overheated situation.A service technician must replace the thermal limiter after correcting the fault.
If these assessment measures prove to be ineffective, I would strongly suggest contacting an authorized service technician who would be better able to assist you in the diagnosis and repair of your unit. You can often locate an experienced technician in your area by going to the manufacturer website.
Jun 19, 2013 | Frigidaire Dryers
CA error is raised
Check for objects between tubs that would cause the motor to over-amp If a status signal comes back from the motor controller that a current limit has been breached,
the unit will return to standby mode and display either "CA" for average current limit trip or
"CI" for instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current draw greater than 5.55
Amps at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 Amps instantly at the motor windings.
This may signify problems with the drive motor, thermal protector or motor controller. Overloading
the unit may cause this problem.
Press STOP/CANCEL to clear the display. Page 51
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 04, 2012 | Washing Machines
Frigidaire electric dryer model gleq2152es1 lights wont turn on and wont do anything
Hi ana piedranayari05, this is AP! Thank you for your post
I understand you are having trouble with your Frigidaire electric dryer not turning on. Make sure the dryer is still plugged into the outlet, and plugged in correctly. Also check to see if the house fuse is blown or circuit breaker tripped? If so, Replace fuse or re-set circuit breaker. Check to make sure that electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. Have a licensed electrician check to make sure it is on a circuit by itself. Additionally, the thermal limiter could have tripped or possibly an internal problem with the dryer. A thermal limiter automatically turns off the motor in the unlikely event of an overheated situation. A service technician must replace the thermal limiter after correcting the fault. If you have check the plug, fuses, and circuit breaker and still no power I would recommend contacting a local technician to diagnose and service your electric dryer.
Jan 18, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Have been getting an error signal C1 during the final stage of the spin cycle
The C1 error is displayed when the motor tries to pull more than 26 amps to run.
This indicates a problem with the motor or motor controller.
Overloading or excessive suds can also cause this error.
If you like to make a few more checks then the image below contains the instructions for entering the diagnostic test mode.
Its a short cycle that runs all of the components so the operation of each can be checked.
I hope this helps but an intermittent C1 error can be hard to pin down.
http://media.fotki.com/1_p,wbrrkqqwkwbqsdgxgtqsskgwtqkq,vi/kdkftbfkwxkfsqdgqsg/1/1303472/5961857/image5668img-or.jpg
From the service manual....
"C1 = Average current limit Or Instantaneous current limit.
limit has been breached, the unit will return to standby mode and
display either CA for average current limit trip or Cl for
draw greater than 5.55 amps
Instantaneous current trip occurs if there is a spike of 26 amps
This may signify problems with the drive motor, thermal protector, or
motor controller. Over-loading the unit may cause this problem."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#%^
Jul 07, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Does everything else except the tub does not spin in spin cycle
needs new bushes for motor they are maybe at there limit when the bushes get to a certain lenght the motor will not pick up in spin cycle this stops the motor from being damaged.
suggest you try this first..
Jul 07, 2009 | Washing Machines
Error code c1 of ca
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jun 03, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
CA message, leaking water on floor, won't drain
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
May 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Mar 31, 2008 | GE WDSR2080D Top Load Washer
GE WBB4500EWW Top Load Washer Logo
78 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
