Question about Radio Shack Cinego D-1000 Multimedia Projector
Its going off after between 30 and 45 minutes sometimes even 10.
Just need schematics am skilled in electrical troubleshooting
I think you have reached time for the lamp or yoou are having a temperature problem, you must clean all fans and filter to start.
Posted on Apr 16, 2013
  • 53 Answers
Posted on Apr 26, 2008
  • proaudiopr Dec 15, 2010
    thats an intermittent osram ballast, and can be fixed easily. i need a schematic to fix the main pcb.
2006 nissan xterra code p1000
Means it hasn't completed a driveability cycle. I ignore it. But I live in a non inspection state. If you need it cleared. Then you have to look at the readiness state of the sensors. See what failed. Takes a scanner. Also, you can get past the code with a scanner in about an hour. Otherwise it could take up to a month with regular driving. Part of the procedure is. Driving in stop and go traffic. Driving at 30,45, and 60 MPH for so many minutes. Scanner tells you what to do.
Aug 06, 2016 | 2006 Nissan Xterra S
Elonex tv keeps going on standby, take 10-15 times for it to work
It sounds that there is some short circuit with its SCL-SDA rail, at its main digital circuit board. It will be best to contact any service technician, as troubleshooting the main board is a skilled work.
Nov 25, 2013 | Televison & Video
Samsung pn50c490 loud pop and shut down
Very difficult to go on as little as this. Not sure you are technical enough, but if you know anything about electronics and a slodering iron, perhaps you could manage this one.
Often in power supplies a electrolytic capacitor will burst and can't work correct, shutting the power supply (and everything connected) down.
When you know how to open the flat screen, perhaps you can see what capacitor plopped.
If you don't have any electronic or electric skills, please don't open the machine. It can be very dangerous, even when you unplugged he flat screen. That is something you always must do before working on an electric or electronic device.
But even if you see a defective part and you don't know exactly what it is, you can't replace it.
I did find schematics and pictures of several flat screens on the net, just by googeling the right name. Helped me several times by repairs, and I did not need the full service manual, because of that.
PLEASE if you are not skilled in electric or electronics, don't open the thing and goto a repair store.
Oct 27, 2013 | Televison & Video
Amp turns on but no sound unless turned up to 9 or 10. switch to distortion and no sound at all.
Check C131 which should have 5 volts across it. This powers the analog switch chip that has to select the audio channel and routing. If 5 volts isn't there, check cap for a short. There are too many other possibilities to enumerate here. You need electronic test equipment to troubleshoot this problem and some skill at troubleshooting.
Here is your schematic:
Feb 06, 2011 | Marshall Mg50dfx 50-Watt Combo Guitar...
Roland KR-5500 digital piano When it warms up it begins to crackle and it smells like an electrical problem. I need a manual on the steps to properly remove the outer case to get inside to the electronics....
Unless you are skilled at electronics troubleshooting, you would probably be better off taking it in to be repaired. It might be the power transformer or a filter capacitor or a number of other things. The problem may not even be visible. You will definitely need a schematic and some test equipment. Try this site: or this site:
Oct 15, 2009 | Music
1996 Oldsmobile Achieva: Security light flashes upon startup
Here is what you do, but only when the SECURITY light flashes - if it is always ON or OFF it's no use.
Turn the key in the ignition to ON.
Wait for exactly 10 minutes ( SECURITY light will flash for 10 minutes and then stay on SOLID)
Turn the key to OFF
Wait 5 seconds.
Wait for exactly 10 minutes.
Turn the key to OFF
Wait 5 seconds.
Turn the ignition OFF.
Start the car normally.
It has relearnt the keycode and you're good to go.
NOTICE - it takes 30 minutes to relearn, that's THREE cycles of ON - 10 minutes - OFF.
Good luck.
Jul 11, 2009 | 1996 Oldsmobile Achieva
A p0340 trouble code and i changed the cam position sensor and all 4 o2 sensor's on a 01 ford mustang gt with a 4.6
Code P0340 is a camshaft position sensor CIRCUIT fault. This means it can be a bad sensor, wiring fault (loose connector, short, open), or even a bad PCM. Since you've already changed the camshaft position sensor you've eliminated that possibility. It's time to do some electrical troubleshooting. That, of course, depends upon your skill set for this type of work and equipment (mostly a good dmm and schematics). If you're not equipped for this then you'll likely have to seek assistance from a local shop.
If this reply answers your question then please take a moment to rate this post. - Thanks.
Jun 30, 2009 | 2001 Ford Mustang
Sanyo tv model dx32224
Ok you are going to need these items before we begin. digital multimeter, and the schematic of your set. These items are the bare necessities for troubleshooting this problem. If you are uncomfortable around electricity, don't even attempt troubleshooting the set. Ok the thing you need to do first is: 1) get the schematic of the TV set (Call the manufacture to get this) 2) get a digital multimeter (your local radio shack will have this) 3) take picture of the circuit board so as I can have a visual guide by which to help you locate components. 4) send me a copy of the scematic so as I can guide you through the troubleshooting procedure. Ok get these items and we can begin.
Sep 10, 2007 | Sanyo DS32224 TV
216 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
xxxxxx xxx
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
