FixYa.com
Tags:
Acer AOpen AX 6BC Pro  Motherboard
Help
posted by Mobaraki on Jan 15, 2008
Dear
My lap top is (Acer) Aspire 1640, and i have got this message during start (Resource Conflict- PCI Network controller on Motherboard Bus;06, Device;08, function;00.
Any help pls!
Comment by Mobaraki, posted on Jan 15, 2008
I have tried all your steps but did not work, errors persist.
i would like to reinstalt the OS, Do you have any instruction for that because i have reinstalted yeterday and did not work as well!
Thenk you for your istant reply
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 07, 2008
Helpful (85)
exon33
Rank:Guru Guru
Rating: 85%, 155 votes
Before going to the drastic last resort reinstallation,
find out exactly what motherboard you have by downloading Belarc Advisor (freeware), which will give you the info to get to the manufacturer's site to download the drivers. For example, this is what it says about mine:
Board: Acer Grapevine
Serial Number: LXAXY0X10172000A5E1601
Bus Clock: 166 megahertz
BIOS: Acer V3.50 02/13/2007
It will also tell you all your hardware s
with serial no's and codes for software. To remove the problems caused by your first try at the fix, try system restore to a time when your computer worked.
Acer support stinks, and will not tell you what is on your computer, and my list downloads which you already have installed.. If you try to use their automated troubleshootin program, you are aiming for the looney bin. Worse than useless.
After you determine your motherboard serial no and manufacturer, go to the manufacturer's website to find out how to download upgrades or reinsall drivers. Acer has a backup on your C drive in a hidden partition of all the programs whch came with your computer. if you didn't originally create backup disks, you still may do so, and just install the programs you need.
Acer sold a lot of cheapos with Vista loaded with only 512 MG ram. If that is the case, they also send out software wich conflicts with Vista. You are doomed to mayhem unless you inslall at least another GB of RAM. And dont buy it from Acer. Identify what you need with Belarc, then go online to identify a cheap source. Hope I didnt get to you too late. Aspire pretends they dont have live help, but they do. Call Acer customer support at 800 816-2237, 8 to 5:30 and if you get a rep who won't help you, demand to speak to a supervisor, If they tell you it is a Microsoft problem, not theirs, they lie--all preinstalled microsoft programs are serviced by the computer manufacturer, not microsoft.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
melnavz
Rank:Wiz Wiz
Rating: 85%, 447 votes
try goto bios setup and load " bios setup default' and press "F10" coputer will restart.
when same problem encountered. try to reinstall the utility driver of the system, the chipset, smbus and other related drivers.
by doing this you should provide CD/DVd utilities enclosed to your system.
Or you can download drivers at the www.acer.com in the support and download option.
if still errors persist.
you should reinstall the OS of your system. to fixed all errors pertaining therein.
(note: reinstalling will remove all important files so back up before continue.)
Can you Help with these Motherboards problems?
Motherboards
battery wire
my battery wire keeps fallin... Answer This...
Motherboards
urgente¡¡¡¡...
como puedo hacer para... Answer This...
Motherboards
retrouver pilote audio
Carte m?re ASV533MSD+ de... Answer This...
Motherboards
je veut des instrustion
instrustion pour le produit:... Answer This...
Motherboards
MOTHER BOARD
dear sir i have a qss-3300... Answer This...
Repair Service
Find Motherboard Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
