Question about HP PhotoSmart 7760 InkJet Printer
Hp 7760 won't print comes up with error
Paper is too small. choose a larger paper size. job was cancelled. press OK
I have tried printing from ms word from email .... but this message keeps coming up I went through all the button but none seem to make a larger paper size
  • 2 more comments
  • Stamps123 Jan 27, 2008
    Trying to feed envelope, get same error.
  • Cooldog Feb 10, 2008
    Had to reinstall windows xp pro, printer was working great, but not now.
    printer error....not connected......but later would just come up and say printer could not print.....
    Downloaded latest driver package and installed, but still have problem....
  • hennessyw Apr 25, 2008
    Trying to print on precut 5.5 x 8.5 blank invitations.
    Printer keeps stating the paper is too small even though I changed the size in the properties of the print job.
    HELP! I need to print 65 of these!!
  • Anonymous May 03, 2008
    I had trouble printing 5.5 by 8.5 invitations on my hp 7760 as well. I fixed it by creating the document on the pre-set "label" of 5x8. When you are ready to print--go to file and select "print". The next to the window that designates the printer you are using, you will find a "properties" button. Click it and go to the paper/quality tab and select label 5x8. (This will obviously make your document size and paper size the same--I think the printer has issues with "custom" sizes.) You will have to adjust your margins on your document to center your text on the invitation (I think mine were 1.15 on rght and .65 on left) but I stopped getting the "paper too small" error-- the printer read my invitations and they look beautiful.
Http://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=946530
The solution is here, in step 8:
"NOTE: If none of the options resembles the paper being used, select Plain paper. Do not leave the type is box set as automatic."
Who'd have guessed?
Posted on Jan 27, 2009
Printer says paper jam on calibration
If you check closely, you may find there is a small piece of paper trapped between the rollers?
Feb 21, 2013 | HP PhotoSmart 7760 InkJet Printer
Papaer empty
it first detects that no paper in the selected paper supply and it cause an error to your computer memory and printer memory so you must reset the job to clear the error on its memory to the two units.
May 15, 2010 | Xerox Phaser 7760/YDX Laser Printer
How do I tell the printer to take from the top tray?
Page 63 of your HP LaserJet 4600dn printer manual:
Controlling print jobs: (condensed version) MS Windows
Three settings affect how the printer driver tries to pull paper when you send a print job. The "Source," "Type," and "Size" settings appear in the Page Setup, Print, or Print Properties dialog boxes in most software programs.
Your question indicates that you wish to configure your printer to take from the top tray. That is a "Source" setting. So in the print Setup or Print Properties dialog box, change the "Source" to Tray 1.
Printing by Source means you choose a specific tray
from which you want the printer to pull paper. The printer tries to print from this tray, no matter what type or size is loaded in it. If you choose a tray that is configured from the embedded Web server for a type or size that does not match your print job, the
printer does not print automatically. Instead, it waits for you to load the tray you chose with the type or size of print media for your print job. If you load the tray, the printer begins printing. If you press the printer tries to print from another tray that has the correct type or size.
Kindly vote for my solution if this info was helpful.
Dec 30, 2009 | HP LaserJet 4600dn Color Printer
'Printer out of paper' message
on note pad or word you should select the paper size first because it might set to a different size. when you click file click print click properties or printing preference and choose what size of paper you have in your tray and then click ok. print ok.
check the printer paper tray setting to make sure the paper tray side guide is right agains the paper. I hope this will solve your problem.
HH
Aug 12, 2009 | HP LaserJet 5p Printer
HP COLOR LASREJET 3500 41.3 ERROR
hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
RK2-0247-000CN
chris
May 27, 2009 | HP Color LaserJet 3500 Printer
Printing from the photo tray
I have found that when you put the photo paper in to the photo tray you have to slide the photo paper in to the printer gently as far as it will go, then slide the side and rear guides to the photo paper. If you just put the photo paper in to photo tray without doing this, the printer will not take up the photo paper at all.
Nov 01, 2008 | HP PhotoSmart 7760 InkJet Printer
HP Photosmart 7760 printer won't print on colored paper??????
hi icymay,
on photosmart machines you have different trays for different sized media. try placing it on the one for envelops tray or on the regular tray towards the left corner. try copying first if that works try printing from the pc. you may need to change the paper type if it fails to start the print job.
cheers
Oct 10, 2008 | Gateway (4000635) Motherboard
Have canon mf5700 says check paper size and only prints one page of several page job
go to control panel> printers> and make sure in preferences its set to LTR (letter)
Hope this helps
Dec 21, 2007 | Office Equipment & Supplies
HP PhotoSmart 7760 InkJet Printer Logo
999 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
