Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Order in drain pan
There is an order and liquid in drain pan of refridge. There is no way to remove drain pan. and really no room to stick my hand to clean it, what do you suggest?
  • wbarbara05 Sep 30, 2008
    We were hit by hurricane Ike and have been w/o power for over 2 weeks. I don't know how to remove the drain pan to clean and it stinks to high heaven!! How do I clean this? How do I get rid of the oder? The rest of the fridg has been cleaned so it's not coming from there?
    PLEASE HELP SOON.
    Thank you
    Barbara Walker
    wbarbara05@sbcglobal.net
    President:
  • 1,314 Answers
Its supposed to have water in it heat from the compressor evaps the water you may poor a little bleach in it to kill the algae or bacteria to help with oder
Posted on Jan 15, 2008
How do I fix a leaking transmission pan gasket on a 2002 Isuzu Rodeo and how much fluid will I need to put back in?
First thing is to get a new filter and pan gasket and a tube of black RTV sealer. Always change the filter wile the pan is down, it's a good idea to. Block and jack the vehicle and rest it on stands so you've room to work and for safety. You don't want it dropping off a jack on you while you're laying under it. Place a large enough drain pan under the trans to catch the draining fluid and pull the drain plug if it has one. If no drain plug, take all the pan bolts out except for the corner ones, and back them out to near the end of their length and wit a screwdriver, break the gasket seal loose and let the corner bolts catch the pan from falling. Now, push the pan up by hand and remove two of the same side corner bolts and allow the pan down from the one side slowly over the catch pan to let the fluid go into the catch pan from the loose side. Let it drain off for a moment till it stops, push the pan back up and remove the other 2 corner bolts and lower the pan and dump the remainder of fluid into the drain pan. Now you can change the filter and clean everything up. Clean and wipe the gasket surfaces on the trans and pan. Place a few dabs of the black RTV on the pan gasket surface of the pan and place the gasket on the pan. That will hold the gasket in place while you put it back up. Stick couple of corner blots in thru the pan and gasket to help you stick it in place and then place the rest of the pan bolts. Snug them all up then torque them to specs and that part is done. Jack and remove the stands, put the vehicle back on it's tires and then the fluid . ONLY replace the same amount you drained out. You can even strain the fluid in the drain pan and put it back in or measure the amount and replace it with that amount. NOW your done. Warm the vehicle up, and check the fluid level in trans with the dipstick to check for proper level while the engine is running and on flat ground.
Nov 11, 2017 | Cars & Trucks
I have a Kenmore upright freezer model# 2539287414 the drain pan is attached to the compressor. There are no screws or fasteners that I can see holding it in place. We had a power outage and contents...
No, there is no other problem, you cant remove the pan but you can place heaps of paper towel in it to soak up all feral liquid, be VERY CAREFUL, it is toxic and will make you sick, wash hands or wear gloves, once most of this is removed, pour neat bleach in the pan, about 2 cups and do your best to get it around the pan, leave it in there and it will evaporate off on its own. Nice smell once again. Russ
Please Vote for my solution
Jun 28, 2011 | Freezers
Won.t shift into grear, how do i replace the tansmission filter?
TO DO A TRANSMISSION FLUID CHANGE YOU NEED HAVE TRANSMISSION FLUID ON HAND YOU NEED TRANSMISSION FILTER AND GASKET.YOU NEED 3/8 WRENCH THE RATCHET TYPE WITH METRIC SOCKETS. YOU NEED JACK TO RAISE VECHICLE SUPPORT VECHICLE ON JACK STANDS.YOU NEED A DRAIN PAN. ONCE YOU GET VECHICLE OFF GROUND.PLACE DRAIN PAN UNDER TRANSMISSION OIL PAN REMOVE OIL PAN DRAIN BOLT.LET FLUID DRAIN OUT IN DRAIN PAN THEN SCREW DRAIN PLUG BACK IN PLACE DONT OVER TIGHTEN.REMOVE OIL PAN AND GASKET. BESURE TO HAVE PAPER TOWEL ON HAND.MAKE SURE TRANSMISSION OIL PAN GASKET SURFACE CLEAN BEFORE INSTALLING NEW PAN GASKET. ONCE TRANSMISSION OIL PAN REMOVED. REMOVE THE OLD TRANSMISSION FILTER INSTALL THE NEW FILTER.THEN WITH NEW GASKET ON OIL PAN IN PLACE.OIL PAN NEED TO BE CLEAN SO THE GASKET ADHESIVE WILL HOLD PAN GASKET IN PLACE WHILE INSTALLING PAN AND GASKET TO TRANSMISSION.INSTALL OIL PAN BOLTS INSTALL THEM CRISS CROSS TORQUE PAN BOLTS TO 7 TO 10 FT LBS. LOOK IN OWNERS MANUAL FOR TRANSMISSION FLUID CAPACITY.BUY 10 QUARTS .TO BE ON SAFE SIDE SO YOU WILL HAVE ENOUGH FLUID ON HAND. IF YOU DONT HAVE NO TRANSMISSION FLUID CAPACITY. ADD 7.5 QUARTS FLUID.WAIT FOR 2 MINUTES.CHECK TRANSMISSION FLUID LEVEL ON DIP STICK. SHOULD BE ON THE FULL MARK.CRANK VECHICLE UP.LET IDLE FEW MINUTES CHECK TRANSMISSION DIP FLUID LEVEL IF DROPPED ADD LITTLE MORE.WHILE ENGINE IDLING GETTING WARM UP. KEEP EYE ON FLUID LEVEL.WHEN FLUID LEVEL STOP DROPPING. APPLY BRAKES HOLD FOOT ON BRAKES SHIFT THROUGH ALL GEARS TWO TIMES. THEN CHECK FLUID LEVEL SHOULD BE ON FULL MARK.CHECK FOR LEAKS WHILE ENGINE RUNNING.
Nov 19, 2010 | 1996 Ford F250 Crew Cab
How do I change the oil filter on the 2004 pontiac grand am ?
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
May 03, 2010 | 2004 Pontiac Grand Am
Freezer drain line and upper drain pan freezes up regularly.
sounds like your fill tube is leaking
you should be able to pull it out from the back of the machine
to inspect it
if the fill tab on the tube is facing in any other direction than down it should be straight down
Oct 09, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
How to change engine oil?
You can't see it from the top because the oil pan and drain plug are on the bottom of the engine. You will probably have to jack up the car in order to crawl underneathand reach the drain plug.
You should change the oil when the car is cold, otherwise you'll end up with hot oil spilling onto your hands. You'll also need a pan that holds 2 gal of liquid and place it under the car beneath the drain plug.
Remove the plug, drain the oil, replace the plug. Remove and replace trhe filter. then refill with oil. Do not over fill
May 24, 2009 | 1988 Toyota Corolla 4 Door
Our GE TFX22PPDA started oozing a sticky brown substance from the bottom left corner of the freezer door. We defrosted the freezer and cleaned out the drain. Next we checked the drip pan under the frig,...
I have a GE refridg. and a light, brown sticky liquid periodically drips from the water dispencer panel area. This started after we lost power for 5 days. What to do??
Apr 19, 2009 | GE Refrigerators
Water in refridgerator interior
You have a plugged drain in the freezer. Unplug and remove back panel in freezer. Under the evaporator there will be ice, thaw with hairdryer or steamer. There is a hole under the ice, that is the drain. Flush with hot water until it drains into outer pan. It may take awhile to get drain cleared.
Mar 20, 2009 | Frigidaire FRT21G3CW Top Freezer...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
73 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
