Question about Dell Precision Workstation 670 PC Desktop
Dell Workstation 670 video
What kind of video card does Dell worstation 670 uses or do they use any kind of video cards?
  • 4 Answers
Support for ISV-certified PCI Express graphics cards up to 150 watts and with up to 512MB graphics memory including: nVIDIA® Quadro® FX 4500;
nVIDIA Quadro FX 3450; Quadro FX 1400; ATI™ FireGL™ V3100; nVIDIA Quadro NVS 280; All graphics cards support dual monitor configurations
All the info for your pc can be found here..... http://www.dell.com/downloads/global/products/precn/en/spec_precn_670_en.pdf
Posted on Jan 15, 2008
6ya staff
SOURCE:
Upgrade hard drives on 670
There is a 2TB limit with MBR (Master Boot Record), but even a larger drive can be partitioned. So a single 4TB (biggest on the market) drive will look like several drives.
External drives that are bigger than 4TB are really several physical drives combined by an array.
RAID 1 requires optional SCSI drives, cables, and even software?
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/before.htm
Add on SATA 3 cards to PCI are not a good idea if you are looking for speed. They just bottlenecks the throughput.
Oct 22, 2012 | Dell Precision Workstation 670 PC Desktop
Chipset heatsink workstation 670
Open your computer and I bet you will find a piece of metal that is a heat-sink just rolling around inside. Probably fell of of the video chip.
Apr 08, 2012 | Dell Precision Workstation 670 PC Desktop
I need a replacement PSU for DELL Precision WorkStation 670. Where can I buy one?
Access the manufacturer's web-site: http://support.dell.com
and enter '670' and do the search.
Find the part-number, and order the part.
Sep 22, 2010 | Dell Precision Workstation 670 PC Desktop
DELL Precision Workstation 670 second processor not working
Did you change BIOS settings or does your BIOS supports dual processors?
Jul 19, 2010 | Dell 3.8 GHz Second Processor for...
Try different memory modules ( RAM ) and see if it is just the RAM.
Also take anything else out you dont need - including dedicated graphics card assuming it has onboard graphics card ( if so then enable the onboard graphics card before taking out the dedicated one )
If its still the same then yes it is the motherboard in which case you need the motherboard replacing.
If you did the diagnostics that they walk you through and they still tell you its the motherboard then it will be the motherboard as there diagnostic software is accurate.
May 06, 2009 | Dell Precision Workstation 670 PC Desktop
The 3 beeps is an indicator of, most likely, a memory fault. This could be caused by incorrect memory configuration (unsupported RAM type or speed), not fully seated RAM, or the RAM itself has been damaged in some way. Best advice I can give to you is to open your case and verify that all Memory Modules are fully seated and locked into position. If they are, next step would be to remove all but 1 chip, and try turning it on. If it turns on, then one that you removed is the culprit, if not, that particular module may be the culprit and change it for another. If, after all memory modules tried has not allowed the computer to start, I would recommend taking it to a service center to be checked, as they would be able to verify the MB has not gone bad with using a module they know to be good.
Hope this helps!
-Backu
Jan 15, 2008 | Dell Precision Workstation 670 PC Desktop
Dell Precision Workstation 670 has no video on screen.
Although it may not be your video card thats the problem. when youre computers posts, it beeps once. If it is beeping more then once youll want to check with the board manufacturer to see what the code its giving means.
DELL PRECISION WORKSTATION 670
Have you tried a differnt video card?  Also disconnect everything including the hard drive to see if the system will POST.  If it does, them start connecting 1 item at a time.
Oct 25, 2007 | Dell Precision Workstation 670 PC Desktop
Dell Precision Workstation 670 PC Desktop Logo
384 people viewed this question
Ekse
Clive
Clive
Alun Cox
