Question about ASUS P4S333-VM Motherboard
Motherboard trouble shooting
When first switch on the power button,the power was just operate within a small period of time,then after another try,there's no power at all. when i remove the power switch jumper on the motherboard there is a sound created when i put the power cord on the power supply .
  • Anonymous Feb 21, 2008
    i have asus ps333, the problem is when i turn on there is no power
    but the led in board is on but there is no power..
    what is the main problem of these board? i try to replace the bios and clear cmos, change the power suply, same problem no power... pls help me
  • Cisf May 11, 2010
    ... give more details
    ..... mother bord type, power supply type ... etc
    and what exactly is the "power switch jumper on the motherboard" for u !? Is there a special switch ?! or u're talking about the normal on/off button ?!
Hi
Please send the motherboard Troubleshooting report
Please send to This email address
vinod_snkumar@yahoo.co.in
Posted on Jan 30, 2008
    President:
  • 2,351 Answers
Double check all your case connectors to the motherboard. Use a strong flash light so you can see the markings on the board. All connectors, connect left to right. Check the back of the power supply make sure the red switch is set to 115V. Clear the cmos. Use your manual & find the bios jumper. If you haven't a clue than just remove the battery. Make sure you unplug the power cord from the power supply first. Replace the battery & boot the system. Pay attention to the fan on the cpu, case lights & CD/DVD lights. If you put this system together your self & it is your 1st time please let me know. There could be many other items that will need to be checked before you make too big of a boo boo & kill the board.....
Posted on Jan 16, 2008
I have a Sony digital camera, a DSC-W100 and it has an error code E91-01 with the flash symbol flashing continually. The flash does not operate when taking a photo, and I have initialised the camera as per...
Hello i ill tell you how to fix your camera
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
If this helped please download the service manual for the camera from the below link it will help with future problems:
http://goo.gl/3PPN7o
Thank you
Sep 04, 2013 | Sony Cyber-shot DSC-W100 Digital Camera
System shuts off within seconds of turning on and fan starts
Motherboards are designed so that holding in the power button for 4-5 seconds shuts the system off. The On/Off key getting stuck or something shorting the pins on the motherboard that the On/Off switch is connected to can cause this behavior.
Open the case and remove the little two wire connector (usually one red and one black wire) that runs from the motherboard to the front panel switch. Then carefully touch both the pins on the motherboard at the same time with something made of metal such as a paperclip or small screwdriver, remove it as soon as the computer starts to power up. If it still shuts off, you probably have a motherboard malfunction. If it starts normally, the switch needs to be replaced/repaired.
Aug 21, 2011 | Audio Players & Recorders
Machine displaying code 3451 what does it need
The Fusing Roller Thermistor does not detect the required temperature within 30 sec. after a warmup cycle has begun; therefore, the copier does not complete the warm-up cycle.
The temperature of the Fusing Rollers does not reach the required level even after the set period of time has elapsed during a warm-up cycle.
You may have a bad fuser section. Another reset method is a small button located on the right side of the machine under on the scanner section. Locate your network port, then to the left of the port is a small cover that can be removed, behind that cover on the left is a small black button, use a paper clip or ball point pen and press the button, this will do a machine reset. When the operation panel abort starts to load hit the number 3 button, you should see a small back circle in the top right of the operation panel. This will give you the option to do a trouble reset.
If this does not work you will need a technician to come out and replace the fuser section, make sure they bring one with them so they don't have to reschedule and come back.
Nov 04, 2010 | Office Equipment & Supplies
My computer will not turn on anymore
Try connecting the power-cord to a different wall-plug.
Look on the back for a "rocker" switch.
Flip it to the other side, and try the ON/OFF button.
If nothing, flip it back.
Open the case, and look for any small lamp on the motherboard.
If it is not lit, then the motherboard is not getting any power from the power-supply. Try a different power-supply.
Open the case, and look at the wires coming from the back of the front-panel to the motherboard. Look for any loose or non-connected wires. If one pair of "loose" wires is labelled 'POWER SW(itch)', then reconnect it to the appropriately-labelled pins on the motherboard.
If all else fails, take the computer to a qualified technician, for "hands-on" trouble-shooting.
Oct 14, 2010 | Computers & Internet
Bizhub 250 All-In-One Laser Printer: Error code C3451 wont reset using Utility key at s...
• The Fusing Roller Thermistor does not detect
• The temperature of the Fusing Rollers does not
May 16, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Need a service manual for a Ricoh fax 4700. It squeeks upon startup and I need to know where to lube it.
YOU CAN GET IT AT WWW.GETMANUAL.COM FOR A SMALL FEE PAID VIA CREDIT CARD THEN YOU CAN DOWNLOAD USER GUIDE/SERVICE MANUAL EVEN TROUBLE SHOOTING MANUAL BY DOWNLOAD IT WITHIN 1 WEEK WINDOW PERIOD
Apr 16, 2010 | Office Equipment & Supplies
I'm connecting everything but the motherboard does want to start
Some power-supplies have a rocker-switch, with a '|' and an 'O' icon, which acts as a "master" power-switch. Be sure that you have pushed down on the '|' side of the rocker. As you do so, look at the motherboard -- it may have a small green lamp on it, to indicate that the motherboard is receiving power from the power-supply. Also, look at the fans -- they may slightly "rock" (twist back and forth) for a moment as you move the switch.
Most of the connections to the front-panel can be ignored while "trouble-shooting" your problem. As long as the two "power" pins on the motherboard are connected to the "power" button on the front panel, pressing the "power" button should work as expected.
Oct 26, 2009 | Asrock AM2NF6G-VSTA Motherboard
Minolta Di3510F indicated malfunction error with code COBAO. Can anyone help?
COBAo = Elevate mechanism malfunction.
The exit tray home position sensor is not blocked even after the lapse of a given period of time after the tray has started moving up.
An encoder clock input is not detected within a given period of time during operation of the tray.Check the sensors,motors and his connectors.
How to reset:
1. Press the trouble reset switch on the Tech.Rep.Setting Switches Board to reset the following malfunctions:scanner,fusing,exposure related malfunctions and C3FF.
2. For any other malfunctions open and close the front door or turn OFF and ON the power switch.
Aug 07, 2009 | Minolta Di3510f Bizhub Copier
Power On trouble with Computer
If don't you have any beeps check maybe the power button stack.
If the power button pressed for four seconds then the computer normaly shut down.
Jan 11, 2008 | Abit KV7-V Motherboard
Is the auto power save function employed?
Yes, this camera has an auto power save function to save power.The camera turns off the displays and unnecessary functions if an operation is not made within a minute. (Power Save Function).To restore the power, press any button or key, or turn the exposure mode dial to another position.The length of this period is selectable from 1 min., 3 min., 5 min., or 10 min. in the section 1 of the setup menu.The LCD monitor always turns off if any operation is not made in a minute, and this period cannot be changed.If no operation is done within 30 minutes, the camera shuts itself off. Pressing the power button resumes the camera operation from this condition.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
ASUS P4S333-VM Motherboard Logo
79 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
