Question about Avanti 310SST Compact Refrigerator
Under counter beverage cooler
My Avanti under counter beverage cooler (model # BCA 5102 SS) is making a loud "grinding" noise. I have pulled it out and it appears to be coming from the component that houses the fan. When I turn it on, the fan starts, then the noise comes, and the fan stops. Is it possibly a replaceable part? My refrigerator is 2 years old, if it is replaceable, is it worth it?
It might be ice around the fan. Try defrosting it. This has been happening to mine, even through it is supposed to be 'frost free'
Posted on Feb 22, 2008
I have an older model Avanti Wine Chiller that began making a very loud almost-grinding noise last night. It continues to cool but I have turned it off due to the deafening sound. Any ideas?
first off determine where the noise is coming from what area? I suspect u may have a fan or condenser fan problem restricted , impeded or going out?
Feb 25, 2015 | Avanti Refrigerators
Avanti outdoor beverage cooler (new), should temperature lights go off? How do I know what the temp is, if the lights go off? It appears to go off for no reason. Owners manual mentions door gasket?? I
The temp lights might indicates the actual temp settings havent reach the programmed settings. If its on and off coz it try to recover the temp lose after it drop below prog. Temp. Monitor it first if its cooling must be normal only.
Sep 21, 2014 | Avanti Orc2519ss Steel Outdoor Beverage...
Beverage cooler making noise
There are small fans that they incorporate in those. If you can get to it put a drop of 3 in 1 oil on each end of the motor.Some of those little bottles of oil have a telescoping straw like piece that extends out a couple inches.
Feb 15, 2013 | Refrigerators
When the fan runs it sounds like something is
Replace the fan. Probably bearings in fan are failing.
Nov 15, 2017 | Avanti (BCA5105BG) Beverage Cooler
Avanti Beverage Cooler BCA5105SG running very loud.
Inside the cooler is the evaporator fan usually right in the middle behind a cover. As it slows down you have less circulation and ice forms quicker and cooling is diminished. Sounds like it is going out.
Sep 14, 2009 | Avanti (BCA5105SG) Beverage Cooler
My Avanti wine cooler is not cooling any more.
piece of junk, can not be fixed. Join all the other ones who have bought this unit.
Aug 01, 2009 | Avanti WC3201D Wine Cooler
Avanti N252BG beverage cooler does not get cold enough
Brand new installed avanti beverage cooler. In a basement undercounter so room temp. around 65 degrees. Only gets to around 45 degrees inside even though temp is set to 34 degrees. Most of the time it sits for days without being opened but still not cold. Any suggestions on how to fix this problem?
Mar 26, 2009 | Avanti N252BG Beverage Cooler
No longer cools.
This refrigeration system may be under extended warranty.
Otherwise check the compressor start relay for loose or burned contacts.
Mar 08, 2009 | Avanti WC494D Compact Wine Cooler Beverage...
Avanti Wine Refrigeraator
thanks for the question i think the problem is that its under the counter no air flow to cool the coils try it not under counter thanks the appliance doc
Sep 24, 2008 | Danby DWC283BLS Wine Cooler
Avanti 310SST Compact Refrigerator Logo
477 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
