Question about Dell Precision Workstation 670 PC Desktop
Dell Precision Workstation 670 has no video on screen.
I plug my power and everything and it powers on and it beeps but i can't get no video on my screen. Is it my video card? I use an asus video for my workstation. Is it a wrong video card to use? Do i need a nvidia quadro fx in order to get video on my screen?
Do a visual inspection on the capcitors on motherboard. Then make sure you have ECC registered ddr2 ram installed with matching "R" rating on them. matched in size also. (mb)
Posted on May 18, 2009
Find the owner's manual:
There you will find a table of beep codes and what they mean.
Posted on Aug 17, 2008
  • 1,226 Answers
If your system has a builtin video use that to configure the add-on video card.
You should go to bios setup then then find there the "primary video adaptor" (something like that) then select PCI express/PCI.
save and exit. uplug the system then connect the monitor to the add on card. your own way.
good luck.
Posted on Jan 15, 2008
  • 4 Answers
Support for ISV-certified PCI Express graphics cards up to 150 watts and with up to 512MB graphics memory including: nVIDIA® Quadro® FX 4500;
nVIDIA Quadro FX 3450; Quadro FX 1400; ATI™ FireGL™ V3100; nVIDIA Quadro NVS 280; All graphics cards support dual monitor configurations
Although it may not be your video card thats the problem. when youre computers posts, it beeps once. If it is beeping more then once youll want to check with the board manufacturer to see what the code its giving means.
What causes a Dell Precision one beep then shuts down?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Bios beep codes to many popular systems are given.
Aug 08, 2014 | Dell Precision Workstation 670 PC Desktop
I need a replacement PSU for DELL Precision WorkStation 670. Where can I buy one?
Access the manufacturer's web-site:
and enter '670' and do the search.
Find the part-number, and order the part.
Sep 22, 2010 | Dell Precision Workstation 670 PC Desktop
Precision 670 crash during bios upgrade from dell site, now when i start the computer it beeps and nothing happens. I need solutions! Thanks, Pablo
How many beeps? Any pattern? (e.g., short, short, long, long, low, high) ?
Contact Dell, and purchase a replacement motherboard.
Sep 02, 2010 | Dell Precision Workstation 670 PC Desktop
DELL Precision Workstation 670 second processor not working
Did you change BIOS settings or does your BIOS supports dual processors?
Jul 19, 2010 | Dell 3.8 GHz Second Processor for...
My Dell 670 had a blue screen when the c drive
try to remove or detach any newly hardware.and check the Ram
Feb 03, 2010 | Dell Precision Workstation 670 PC Desktop
I have a dell precision 670 that beeps on start up and then I get no video. In some case if I were to pull the plug, walk away and then come back in a few mintues to do a startup I can get it all back but...
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Sep 23, 2009 | Dell Precision Workstation 670 PC Desktop
Dell precision 670
Ok go to bios setup and then "load bios default" and press "F10" to save and exit. i will tell you in case this not work just tell me.
Jan 18, 2008 | Dell Precision Workstation 670 PC Desktop
The 3 beeps is an indicator of, most likely, a memory fault. This could be caused by incorrect memory configuration (unsupported RAM type or speed), not fully seated RAM, or the RAM itself has been damaged in some way. Best advice I can give to you is to open your case and verify that all Memory Modules are fully seated and locked into position. If they are, next step would be to remove all but 1 chip, and try turning it on. If it turns on, then one that you removed is the culprit, if not, that particular module may be the culprit and change it for another. If, after all memory modules tried has not allowed the computer to start, I would recommend taking it to a service center to be checked, as they would be able to verify the MB has not gone bad with using a module they know to be good.
Hope this helps!
Jan 15, 2008 | Dell Precision Workstation 670 PC Desktop
Have you tried a differnt video card?  Also disconnect everything including the hard drive to see if the system will POST.  If it does, them start connecting 1 item at a time.
Oct 25, 2007 | Dell Precision Workstation 670 PC Desktop
Dell Precision Workstation 670 PC Desktop Logo
1,213 people viewed this question
Alun Cox
