Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi Model No VS-5069
I have a mitsubishi Projection Tv Model No VS-5069 and the mirror in it was broke is there any way to get a new mirror for it
  • 3,130 Answers
You will need to contact a glass place to cut a new mirror that has the reflection paint on the outside of the glass instead of what most mirrors have them painted on the opposite side . Good luck
Posted on Jan 22, 2008
I have a Mitsubishi Model WD-6035 rear projection tv. I broke the "mirror" inside trying to get out 2 stink bugs. Where can I get a replacement?
Hello, I'm sorry but the original mirror is no longer available from Mitsubishi. you may make a cardboard template, and it will have to be exact, and take it to a glass shop and have a mirror cut, it won't be as thin or optical grade, but it will work but the may be some slight distortions in some areas.....tks
Dec 27, 2014 | Mitsubishi Televison & Video
Mitsubishi VS-50603 50 in. Rear Projection can i replace the mirror myself
First of all you need to check with the nearest service dealership for the availability of the mirror and the cost of the unit. Normally the cost from such dealerships will include to an extend the replacement cost and so it will be wise to have it done in the first case than to set it up and watch a distorted image if the aligment is not proper as the fall could also have shifted the alignment.
Nov 30, 2011 | Mitsubishi VS-50603 50" Rear Projection...
How do i clean the projectors and screens of my mitsubishi vs-50607 tv
Pull the Front Bottom panel off under screen will be screws that hol pn screen remove all of them then lift up on screen anf remove it Now you should be where Mirror and Tubes Clean all lenses and mirror with windex.
Sep 19, 2009 | Mitsubishi VS-50607 50" Rear Projection...
I don't know how to get to the mirror and projection guns
the front trim on the tv pops off...there are screws all the way around the screen that you have to take out to remove he screen to get to the tubes and the mirror. once you pop the trim off youll see how easy the rest of it is
Feb 21, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi Tv model VS-6021CA
Sonds like the Crts need the coolant changed. I would also recomend polishing the mirror and crt lenses dont use windex just a damp soft cloth for the mirror and lenses then dry. If that doesnt help you may need replacement crts thats expensive new. But if you need them I have a line on lots of mitsubishi projection CRTs as well as other brands.
Apr 03, 2008 | Televison & Video
How to remove the mirror casing
The mirror on this unit is fixed and there is not a method to drop the mirror.
Feb 23, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Where do I find a screen and mirror
Hello jeremyv,
I would suggest calling Mitsubishi Technical support, they might be able to help you in this ares.
Thank you,
Dec 21, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-60603 60 inch Projection TV
You would have to completely take the Mirror out or Mylar backing and being careful not to damage anything, trying to move and reassemble when you get at the new location.
Dec 05, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi tv parts
This mirror Mitsubishi part# 767D055020 is no longer available from them but JVC has one that will work- Andrews Electronics = $101.72
Sep 21, 2007 | Mitsubishi VS-50605 50" Rear Projection...
I need to replace the mirror, it broke during transport
Take the back bezel off. It should have many screws around it. then once open you should see the back of the mirror. Carefully take the screws out of the mirror, you may have to do some modifing with the new mirror if it does not come prefabed.
Aug 24, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
137 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
