Question about Acer Aspire 5100 Notebook
Internet connections I can connect to the Internet fine wireless, but as soon as the battery gets low and I plug in the power line, I lose Internet service immediately. No power cord, fine....plug in power cord, Internet lost.
  • JimatRainbow Jan 15, 2008
    Thanks for trying to help. I don't see an antenna anywhere on my pc, nor do I find one in the control panel. Where in the control panel would I find the antenna connection?
  • wsholds Sep 08, 2008
    My daughter's problem is the opposite...Our wireless internet works fine on her laptop so long as the laptop is plugged in. As soon as we unplug the laptop, we lose the wireless internet connection and cannot reconnect unless we plug the laptop back in...
    I hope this is something we can resolve on our own. She just started school last week and this happened. I didn't want to have to send it out if possible.
OMG! Thanks! It worked! It was the little switch on the left of the PC. I feel like such a jerk! Thanks again for all your help. :)
Posted on Jan 15, 2008
    Sergeant:
  • 239 Answers
Hello I am sorry you r having this problem, I need to know a little bit more info, Now when you plug in your computer to power cord you loose everything with you internet connection. Do you see the active monitor in the lower right hand side, it would look like a monitor blinking or it may not be blinking. Have you also tried to activate the antenna after you plug in your power cord. There should be a button with an antenna on it the upper part of the pc, You may also go into your control panel and turn it on there, It sounds like its set to shut down the wireless connection when plugged in, its just to opposite as what it should be, usually its when you unplug your computer that the internet connection is lost for power saving reasons, you can also right click the connection monitor in the lower right and properties and repair after the power is plugged in of course give that a try and see if that works for you, I hope it help you out with your problems
  • bear001 Jan 15, 2008
    Ok does you laptop have the camera and jacks on front, If so on the left of the input jacks on the front of the notebook, You see two sliders switches, The switch located nearest the input jacks I not sure but I think you should see Yellow and green on each side, That switch is the one you want to use just click it after you plug in, If your 5100 still is not working, Like I said before I need more info what OS you have Is It Vista H,P XP H,P Amd 2.2 core 2, more important is the Operating System, If you need more help I can Help you sometimes its just difficult doing by leaving messages for one, I don't mind I love to help people as much as I can and Most of the time it just takes time doing it in this matter, I wish folks wouldn't leave feedback until we are done that lowers my rating on Fix ya, Like I said communication is the key not every computer is the same along with people, LOL I sure hope we can get you up and running
    Try the slide switch and if not working just write back with the info and I will help you if ya haven't fixed it yet :)
Losing internet connection
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Aug 29, 2012 | Zyxel Prestige 100MH Router
When using my laptop with the SMC 8014WG router I can receive internet connection. As soon as I connect a wireless printer (I have tried 2 types) I lose the connection. I have had an outside expert change...
roberta_crai
If you are losing connection as soon as you connect another device it is possible that you have the routers host connections set to low. I would try to increase the number of connection that can connnect to the router to see if this makes a difference.
Let me know if you have any more problems or questions.
Issken
Feb 19, 2010 | SMC (SMC7004AWBR) Router
Suddenly no connectivity after months of service
change your internet connection, or may be the modem is faulty due to some reason
Jan 08, 2010 | Belkin F5D7234-4 Router
Lose Internet connection on wireless network
Go to the router configuration and change the options so you could use both of them, there is an option says only one type of connection or both of them, change it to both, and everything will be fine.
Regards
Aug 02, 2009 | Zyxel Prestige 660HW Wireless Router...
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
DSL line disconnects on WRT54GS only
Try to change the LAN IP address of your router to 192.168.2.1 by accessing the router's Setup page. You also need to set your Westell modem to "full-bridge mode". You need to ask assistance from your ISP to bridge the modem. After that, set-up the Linksys router to PPPoE then power cycle it.
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Connecting my sony vaio laptop through my linksys router with dsl
Try this:
Connect the modem to the router, and the router to the computer.
Pull the power cord out of the Modem.
Pull the power cord out of the Router.
Wait 10 seconds.
Plug in the modem, and wait untill all the lights go steady (ususally a minute or two)
Plug in the router.
Check your connection. Ask for more help if this doesn't work.
Jan 09, 2009 | D-Link DI 514 Wireless Router (DI-514)
Losing internet connection when enabling ICS on the wireless network connection
Do not enable ICS on any of the computers that are connected to a router regardless if it's wired or wireless, you only need to enable ICS is if you don't have a router/server on your network(the purpose of a router is to share a single internet connection from your ISP). To connect your computer wirelessly to the router(on a Windows XP computer given that you do not have a 3rd party Wi-fi application installed) is to right click on wireless network connection on the System Tray(lower right hand side of the computer's Desktop near where the clock is) or you can do it the hard way by going to Control Panel then Network Connections and choose view available wireless network and under the list of available network that your computer can detect, select the network name(also called SSID) of your wireless router and try to connect(of course if you enabled Wi-fi security you also need to key-in the security key(WEP/WPA) you configured on your router and that's it both wired and wireless computer/devices connected to the router should work at the same time.
Nov 05, 2008 | Belkin (F5D7230-4) Router (587009)
Acer Aspire 5100 Notebook Logo
112 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
