Question about SanDisk Sansa c200 MP3 Player
Sansa®c200 Series MP3 Players is frozen
My sansa is frozen. Does anyone know how to fix this problem? Help ASAS please!!
  • 3 more comments
  • zupko Jan 19, 2008
    Mine is frozen also. I havent been able to use it so it has not been charged in a while. I hooked it up to the computer and now when I turn it on it is frozen on the screen with the alligator looking thing and will not do anything. I can not turn off the power or anything. I tried uninstalling the battery and then putting it back in and still have the same issue.
  • Sheryl Yarosevich
    Sheryl Yarosevich Jan 27, 2008
    Yes an having the same problem with the Sansa Express 1GB stuck on BAD TRACK
  • aldo hndz Feb 08, 2008
    I do and the computer doesn't detect it
  • Mimi17 Feb 10, 2008
    Same problem with Sansa c200 (2 GB):
    -it is frozen
    -the computer does not recognize it as being connected (so cannot try the formating advice)
    -only the dog/ dragon screen comes up (tried pushing all the buttons)
    -can only turn it off if holding down the on/off button for longer than 10 seconds
    Any help is greatly appreciated!
  • Anonymous Feb 11, 2008
    I have the same problem! It froze after playing an album. The screen was blk but the pad lights stayed on. I held the power button down for 10 sec and it shut off. I hooked it up to the computer and the screen came on and said connected. This is the 3rd or 4th time this has happened to me and I have noticed that it only happens when I use the HOLD button..?..Haven't tried to use it yet since it froze ( still recharging) Would appreciate any help or ideas with this thing.
    Sergeant:
  • 226 Answers
Reformat
Posted on Jan 29, 2008
  • earl llanera
    earl llanera Feb 05, 2008
    connect mp3 player to computer
    go to my computer select removable disc/drive
    right click select format.
    note: all of the files will be delete during reformating process.
PLEASE Help with my sansa c200 mp3 player!
The Sansa c200 has 2 versions, version 1 and 2.
Check the version of the player:
Go to Settings > System Info.
Information for the firmware version and SD cards support:
For 01.xx.xx firmware (c200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (c200 version 2) - up to 4GB microSDHC cards
Note: Firmware is not interchangeable.
Manual for c200 series:
http://mp3support.sandisk.com/downloads/um/c200-ug-eng.pdf
Manual for c200v2 series:
http://mp3support.sandisk.com/downloads/um/c200v2-um-eng.pdf
For deleting files connect your player with the computer.
When running Windows Media Player 11:
1. Check the automatic SYNC routine for your player.
How to get to the SET UP SYNC
When viewing WMP11 in full mode select SYNC or LIBRARY in the top of WMP11, seeing the Sansa player listed on the left.
Right click on the player and select SET UP SYNC... to go to the SYNC options.
When "Sync this device automatically" is selected, all playlist in the computers' Library will be transferred to the player again, even the previous deleted files. Disable this function to prevent unwanted SYNC.
2. Remove playlists from the library in set up sync, to get the playlists you would like to keep on the player.
Need more help ? Just post a comment.
Dec 10, 2009 | SanDisk Sansa c200 MP3 Player
Tip
For Version 2 Sansa E200 Series and Version 2 Sansa C200 Series
As you have notice, these version of player will not have the USB Mode / Mode ( FOr Rhapsody Players ) and / USB for sansa C200 series. If you want to have your player detected by the computer as a removable disc drive or as a MSC drive you can perform this easy steps.
For Sansa E200 Players and C200 version 2 Players.
1. Enable the Hold Switched for it to show a red color.
2. Press and Hold the Rewind button the " << " then connect to the computer.
3. Connect the player to the computer and dont let go of the Rewind Button " << " , you will notice that the player would be detected as a removable drsc drive in the My Computer Window.
*For Load Main Image Failed Problems and player Freezing on the Refresh Database Screen will be post later*
on Dec 08, 2007 | SanDisk Sansa e250 MP3 Player
No software for my sandisk sansa c250
This will give you the links to the Sansa Firmware Updater and Sansa Media Converter for your c200 series:
http://www.sansa.com/support/sansa_c200/faqs
-Tha Mp3 Doctor
Feb 28, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Free memory
Format
This will format your Sansa c200 player’s internal memory
1) Select Settings from the Main Menu.
2) Select Format
3) Select Yes to format the internal memory or No to cancel.
-Tha Mp3 Doctor
Sansa c200 series – Computer/OS Not Recognizing
Connect the device to the PC in MSC Mode
View/c200: Turn on then press and hold the rewind button while plugging to the PC
If that fails, unplug the Sansa from the computer. Uninstall all the Sansa software in the add/remove programs section of Control Panel. Reinstall the clean version of the software from Sandisk’s website – make sure you get the files for the c200 series. Then replug the Sansa and try again. The root of the problem is that Sansa has one set of drivers and Windows has another. If you plug the mp3 player into the computer before installing the Sansa drivers, the Windows drivers will trump the Sansa’s.
Here is a helpful link from Sandisk on the problem with extra information on Vista operating systems:
http://kb.sandisk.com/cgi-bin/sandisk_en.cfg/php/enduser/std_adp.php?p_faqid=42&p_created=1221328944&p_sid=8VPwlRmj&p_brand=sansa&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzQsNzQmcF9wcm9kcz00JnBfY2F0cz0mcF9wdj0xLjQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jMjAw&p_li=&p_topview=1
-Tha Mp3 Doctor
Aug 03, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Please free memory
-Tha Mp3 Doctor
Sansa c200 frozen
Have you tried to reset the device by holding the power button?
Jan 05, 2008 | SanDisk Sansa c200 MP3 Player
Sansa c200 mp3 player
Sandisk provides "how-to" videos for everything Sansa related
You should check out the sansa community forums and post your issue, those folks know about EVERYTHING sansa and should be able to help you
Very helpful Sansa user Forum
Offical Sandisk Sansa user Forum
Nov 02, 2007 | SanDisk Sansa c200 MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
363 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
