DVD Drive door will not open
DVD drive door won't open, lights light up but it won't open even with button.
  • 2 more comments
  • Milliann Johnson
    Milliann Johnson Jan 15, 2008
    Don't have a tiny hole. Relatively new computer as had very little usuage. Sony Vaio Digital Studio
  • Milliann Johnson
    I had already tried to eject button and a Sony repair agent. All drivers & software appear to be ok. This next part may sound stupid, but this computer has a CD Drive that is working fine. Can it be changed to a DVD drive, If so how. This PC is my parents that only use it in limited ways and since a CD can be played in A DVD drive then if I could convert the usuable drive to DVD that would work. Thanks ALot for everyone's imput
  • Milliann Johnson
    Milliann Johnson Jan 17, 2008
    that getat sounds great. i am not at that location currently, but when i return there i will repost with model thank you again and i don't get why the rating is locked but i am rating your response as
    top notched!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • sgrap Mar 03, 2008
    even when I use the paperclip it will notnopen. My Dad is getting frustrated.
    Genius:
  • 1,601 Answers
Unfold a paperclip and push it into the tiny hole, it will open up.
It may be wearing out..I see a lot of older ones do this.
Posted on Jan 15, 2008
  • 2 more comments
  • Thomas Christopher
    Thomas Christopher Jan 15, 2008
    Laptop?
    you listed under PC desktop
    If it is new take it back..for warranty.
    open the my computer icon and right click on the drive letter that wont open.. you should see an eject option. Worked for me a few times when certain proggies locked it from ejecting with the button.
    Thomas Christopher Jan 17, 2008
    It sure could be changed to a DVD drive. Just pull out the cd drive and replace it. Just make sure that the jumper is set in the same as the cd drive you pulled out...
    If you need more help post the model number and manufacturer of the computer.
    Please rerate this post.
    thanks.
    Thomas Christopher Jan 19, 2008
    Leftyet,
    thanks.
My disc is not playing nor can I eject it is there some way I can do this I have a Lenovo Think Centre M90z
The drive can be easily removed once removed you can then use the paper clip from the back and push the tray open
Jan 05, 2015 | Lenovo ThinkCentre Computers & Internet
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
I can not open the DVD drive.
Windows10?
Remove the cd drive through the hardware menu and restart the pc. It will reinstall the cddrive. Perhaps this will work
open the computer, take carefully out the cd player at the end is an hole to manually open the tray. At least you can get out the dvd.
Feb 04, 2018 | IBM Lenovo ThinkCentre® M55 PC Desktop
DVD Drive opens automatically when I start up the pc and won't recognize disc
I had the same problem and it was the sata cable, I would check this and change it for one you know is good. hope it solves your problem.
Jan 09, 2013 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Tray won't open and if you hit the button enough the light comes on thats it.
This DVD drive has a small processor in it. The button sends a signal to the processor to open the door. The processor then turns the light on and the door is supposed to open.
This unit is broken and needs to go to a shop as the IC that opens the door is probably bad.
Try this: get a paper clip and find the small hole in the door. This will manually open the door. Then use the button to close it. It could also be a mechanical failure..
Apr 04, 2010 | Lite On SHD-16P1S Internal DVD Drive
Disk door won't open , The light is on but the door won't open when the button is pressed
There is a little hole the size of a pin where you can push that in and the drive will slide out. Located in the front where the dvd drive pops open.
Jan 11, 2010 | Memorex DVD-RAM Burner
DVD Drive door will not always open. No obstructions. DVD Drive light flashes, but door will not open. Is ther some software conflict?
The door drive motor may be frozen.
  1. Shut down the computer and unplug it.
  2. Open the computer casing to access the DVD drive from inside.
  3. Disconnect the cable on the DVD drive leaving only the power supply connected to it.
  4. Turn on the computer.
  5. Push the OPEN/CLOSE button on the DVD drive. If it does not open, the drive is broken or the door drive motor is defective. If it opens, push the button repeatedly to open and close the door repeatedly to release any frozen part.
  6. If the door does not stuck anymore, shut down the computer.
  7. Reconnect the cable and turn on the computer.
Oct 30, 2009 | Sony Computers & Internet
Stuck DVD tray
Turn off the computer and then use the paper clip to open the DVD tray.
If this doesn't work, then something is jaming and stopping the tray from opening. In this case, remove the DVD drive and dismantle the drive (ie. remove the metal cover to reveal the internal components and remove the CD ot DVD disc.
If nothing works the the DVD drive is faulty and needs to be replaced, these drives are not expensive.
Jul 21, 2009 | HP Pavilion DV5234US Notebook Laptop
Computers & Internet Logo
525 people viewed this question
Alun Cox
David Payne
David Payne
