Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
Kenmore 911.30464, 30465, 30469.....Wont ignite at all
What do I need to do to get the oven to heat up. Used it one day the next it wont work. You can set the temp and hit start, but it just reads 100 degrees and makes the fan sound, but there is no heat or gas smell at all. Is it an ignitor issue or what?? Many Thanks!!
  • 18 more comments
  • dee320 Feb 13, 2008
    same problem
  • deb1050 Feb 28, 2008
    I have the same problem, even thought the broil works just fine, so I know the ignitor works. I reset the circuit breaker to see if it would reset, like a computer, but it didn't work.
  • j_harriss_9 Jun 25, 2008
    Mine too will broil, but not bake... temperature setting just sits at 100 degrees. Does the bake feature have a different igniter?? Help!!!!!
  • Anonymous Jul 26, 2008
    EXACT PROBLEM!!!!!!!!! HELP!!!!!!!!!!!!
  • Anonymous Aug 16, 2008
    SAME PROBLEM
  • barbsgem Sep 12, 2008
    I have the same problem... oven was baking then quit -- broiler works
    how do you fix this problem...........
  • Anonymous Oct 02, 2008
    exact same problem too... every thing i have read says replace the igniter...
  • huntertore Oct 07, 2008
    My oven won't lite either. Renewed the Gas Valve and Thermostat, and the HSI Glow Igniter looks fine and glowing.
    However gas won't ignite unless we bang the oven, and since replacing the Gas Valve, the gas will not stay on at all for more than 3 seconds.Any suggestions.
  • Anonymous Nov 18, 2008
    Same problem as described by others at this web site.
  • Anonymous Nov 26, 2008
    same problem will broil but noy bake. I replaced the igniter but still won't start up
    same problem broil but no bake stays at 100 degrees
  • trecelboy23 Nov 26, 2008
    same problem
  • Anonymous Dec 21, 2008
    I hve the same trouble and I need a fix.....
  • Anonymous Dec 27, 2008
    30469 mod.-Electric oven broiler works fine oven won't light, temp stays at 100 dgree reading w/o any heat.
  • Anonymous Jan 03, 2009
    Does the oven need to be removed to access the back for the wire connectors?
  • diane461 Jan 05, 2009
    I have no error code showing. I turn the oven on and it will not go above 100 degrees. I do not see the flame that I usually do and I do not smell the gas.
  • Anonymous Jan 29, 2009
    turn oven on wont heat our lite
  • gman1967 Feb 01, 2009
    The broiler works but the oven does not. Please help.
  • Anonymous Feb 28, 2009
    My oven will not ignite, no gas smell at all but top burners work fine.
  • raldo Apr 12, 2009
    Broiler works but oven won't lite.Worked fine until now
There is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
Posted on Oct 06, 2008
I have a Model 911.30465, 30469 Kenmore Single 24" Self cleaning Built-in Gas wall Oven. The problem is when I press "start" it won't start. Thank you.
Posted on Jul 21, 2008
6ya staff
SOURCE:
Westinghouse px 650 gas wall oven wont re ignite once initial heat is met
what you should be doing next is to get a gas fitter out to determine why the pilot light is going out or the sparker is not lighting the gas
gas is not a diy operation as a mistake from you could destroy the building and yourself
Dec 15, 2016 | Ovens
Model number 3627361192 oven wont work but broiler does the oven starts but then flame goes out
replace the igniter. Even though you see it glowing, it's failing.
Jul 17, 2014 | Kenmore Ovens
Kenmore duel fuel oven wont heat
I take it this will be an electric oven. If so the likely hood is that the oven element has blown and will need replacing. Normally when elements short they will trip the houses RCD (once only normally)
Apr 10, 2014 | Ovens
Kenmore gas oven model 36275578690 oven wont light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 20, 2011 | Kenmore Ovens
My oven wont light up
heatman101
Dec 27, 2010 | Kenmore Ovens
How to relight a kenmore oven it wont relight
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 13, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
I have a triple task Kenmore stove with the self cleaning feature, my oven worked fine till I cleaned it one day and now it wont heat up. I have taken the elements out and had the tested and they are fine...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 11, 2010 | Ovens
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Nov 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 24" built-in oven wont heat
HI THANKS FOR THE QUESTION oN SOME MODELS THERES A FEATURE THAT IF YOU USED THE TIMER OR THE TIMER SETTINGS MAY HAVE BEEN ACCIDENTLY BEEN CHANGED CHECK TO SEE IF YOU HAVE THE KEEP WARM SETTING ON THE TIMER OR A BURNT OUT BAKE ELEMENT THANKS THEAPPLIANCE DOC
Sep 12, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
OVEN WONT WORK!! WE HAD A BRIEF POWER OUTAGE AND THEN WENT TO USE THE OVEN AND NOW IT WONT WARM. YOU CAN HEAR THE SPARK IGNITE BUT THE OVEN DOESNT GET AFTER THAT!! HELP!!
The igniter needs to be replaced. I had the exact same thing happen to my oven. The igniter would glow, but after tested, it did not have enough amperage to actually ignite the gas, so the gas kept running with no ignition
May 23, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
721 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
