Question about Philips TS2744C TV
Shuts off I found a capacitor with the number C506 on the board which is burned, and I need to know the electronic value of it to be able to buy it. I don't have schematics for this TV. I'll apreciate any help. Thanks
  • denambi Apr 17, 2009
    If anyone's still watching this thread, "The witch" says it's 680 pf; another place that it's 820 pf for the 27" & 680 pf for 20 - 25" sets:
    http://www.circuitwork.com/archive/TV/20...
    Any confirmation one way or the other? C506 just blew on my TS2744 C123.
    Thanks,
    Dennis R.
    Genius:
  • Philips Master
  • 1,550 Answers
The number are 680pf 2kv
Posted on Mar 17, 2008
Power clicks on then shuts off
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Feb 22, 2012 | LG 50PT350 50 in. Plasma TV
Philips 25ts54c122 capacitor C506 Trouble
check the horizontal output transistor, it may have gone belly up. good news is a replacement is only 6-7 bucks.
Nov 20, 2007 | Philips Smart 25TS54C 25" TV
Hi there i have a 50 inch plasma tv model ps-50q96hdx/xeu which seems to have a mind of it's own when i switch it on. sometimes it comes on, sometimes it won't! when it does turn on it has been found
You might wish to unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections. The safety circuitry shuts the TV set down or will keep it from turning on when it detects a problem. This model of TV has over 2,000 parts, which includes millions of transistors inside the integrated circuits.
The capacitors will change value, leak and become defective. Resistors will change value and burn. Diodes and IC can go bad. This may have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again if the parts that caused the failure to begin with are not replaced.
The only way to know for sure which parts that are no longer within factory specs and for a proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment specifically designed for TV service and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off.
This is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
You know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.
You still need to check for leakages...
Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck.
Nov 09, 2011 | Samsung HP-R4252 42 in. Plasma HDTV
On a Faema Due expresso machine: Viewing the circuit board from the component side, with the two 0.1 uf caps on the left. The two pins on the left of the eight pin connector are completely burned from the...
The descripion you have send is only for the board. We need to know also how is the machine.
Is the machine working good up today and you have descover this after a fault?
If there was a fault what was that?
We need some of this information in order to get the whole picture and history of the machine.
Jul 27, 2011 | Vacuums
Hi, my ikon 42' TV now has no picture or sound and the green light is flashing.
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
The safety circuitry shuts the TV set down or will keep it from turning on when it detects a problem. This model of TV has over 2,000 parts, which includes millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Diodes and IC can go bad.
Good luck in solving the problem..
Jul 12, 2011 | Televison & Video
Tv runs for about 3 minutes shuts off I can restart right away but 3 mins later it shuts itselfe off again
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Sep 19, 2010 | Toymax Magnavox 47MF437B 47 in. LCD TV
The tv shuts shuts off by itself and wont come back on until next day, do you know what causes this
Solutions?
Hope this helps
Aug 06, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Philips model HD2528-C122 value for capacitor C506?
I could still make out 68 over 2kv on the burnt capacitor. Replaced with a 680 pf 2kv that I bought at a local TV repair shop. works great.
May 27, 2008 | Televison & Video
Replacing Circuit Board Capacitor
820pf / 2KV capacitor Philips # 483512257004 Andrews
Or # 13-821U HB Electronics .......T.
Nov 08, 2007 | Philips Smart 25TS54C 25" TV
Phillips magnavox smokes
Replace the bad cap:
Capacitor C506 = 680pF 2kv = 483512247584 part number
Buy at tritronics by credit card: 800-638-3328
Oct 24, 2006 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
