Question about Creative Labs Live! Cam Notebook Pro Webcam
Web cam shows images in black and white
Why won't my webcam show images in color. I think it a windows setting problem. Can anyone help.
5 Suggested Answers
SOURCE: only black and white!
I have the same problem. I instaled the driver with lot of problems but I made it work. Only in (black and red).
Who can help us
Posted on Jun 30, 2008
SOURCE: my webcam is all blacks images but the others webcam i can see
Uninstall and redownload latest drivers here>
Posted on Dec 13, 2008
SOURCE: Having issues with web cam
im looking for driver creative vf-0040
Posted on Dec 21, 2008
  • 67 Answers
SOURCE: my webcam has no color
I would try un-installing the driver, then shutdown your PC, leave the webcam unpplugged and after you login to your operating system, re-install the driver, following its instruction when to connect the webcam to the USB port... Hope that helps!!
Posted on Apr 05, 2009
  • 2602 Answers
SOURCE: enet webcam not working with messengers
Download the manufacturer's software ( by using the CD or from their website )
Once your webcam is working on your computer,you can configure it to Yahoo Messenger.
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the Yahoo software may have difficulty in locating it. Mine, I just unplug it from the USB and plug it back in, if yours is integral with the computer you will have to re-start the computer, unless the software has a feature for this.
Of all the chat programs, Yahoo is the most painful software to set up but if you follow these instructions you should be ok.
Webcam connected
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
> Messenger > My webcam - the warning panel will launch, click 'OK' and your webcam will start. You should be rewarded at this stage with your happy smiling face.
With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK
Take a note of any additional software, if you have multiple choice for Camera Source, you may wish to uninstall any redundant webcam software later to prevent conflicts
> Messenger > Preferences > Webcam - make your selections ( who you will allow to view you) > Apply > OK
When you are both on line and wish to show your webcam > Actions > 'Invite to view my webcam'. This will launch an invitation on your contacts screen when they 'Accept' your webcam broadcast will start- There can be considerable time lag ( 1 minute) before they see you, so dont be too impatient ( You can check the status on the bottom left of your webcam panel. You can 'drag and drop' the frame to a convenient location by grabbing the top border.
There is a shortcut ( webcam icon ) down by your pic as well
Your contacts needs to configure their connection the same as above or they may get a "webcam not connected" message
If you complete the above and still have problems - check to see if your cam is compatible with Yahoo
To find out what the requirements are for messenger webcams, check out the following.;_ylt=AghoQIvxhmhcugo.AOaNKaokPCV4
Posted on Sep 09, 2009
0 characters
1 Points
My web cam a4tech (pk 635) was perfectly working on windows xp. now i install windows 7 web cam shows white screen and on yahoo it shows black screen.
May be an incompatibility with codecs. Trying to install other video codecs.
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
Feb 27, 2011 | A4tech PK-635 Webcam
Cant get colour, only Black and White video
probably on the cam settings it ha a case where it said black and white ...this case must free in order to see colored ..take a look it is placed somewhere in the right ( low) ...I hope you know how to get on camera settings...if not try this..
there are two ways:
one its to open the AM cap and select from the window...options /video capture filter...and than uncheck the B/W case..
the other is to access the preferences in yahoo messenger the same ..uncheck the BW...
Good luck ..and hopefully its from there ...if it isnt this one ...must be something wrong with the web cam ....let me know how it worked out..!
May 28, 2009 | MSI Starcam 370i Webcam
I am not getting any image or video from my web cam.
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Mar 15, 2009 | Zonet ZVC7100 Webcam
Divided screen
reinstall it should solve the problem ...if the problem persist after the reinstallation is something wrong with the web cam
Mar 02, 2009 | Logitech QuickCam Communicate STX Webcam
Logitech webcam
Are you trying to use more than one application with the cam at one time?
Dec 29, 2007 | Logitech QuickCam Express Web Camera
Video Downloads and Webcam do not show in color...Only Black and white
There is an option in the Webcam properties for black and white.
1. Open the Webcam program.
2. Top right corner of the window click the "down arrow" button next to the minimize and maximize button.
3. Select "Properties"
4. On the right side of the window, under the heading "Extra Control", make sure there is no check in the box.
Hope this helps.
Dec 11, 2007 | Microsoft LifeCam VX-3000 Web Camera
Only black and white!
Who can help us
Dec 09, 2007 | Logitech QuickCam Pro 5000 Webcam
Its recongizes the cam, but its a black image
if your cam is reognised it just may be a faulty driver, or the image display settings are too high for the cameras pixels so check the options. Other than that uninstal the cam software from add/remove programmes and remove cam from usb port, reinstall software and plug in cam again. Also check that the software being used is not being stoped by your firewall or internet security programme, as the software may have an updater running in the background and causing the software to run incorectly.
Jun 14, 2007 | GE EasyCam Webcam
Creative Labs Live! Cam Notebook Pro Webcam Logo
380 people viewed this question
Top Creative Labs Webcams Experts
micky dee
Are you a Creative Labs Webcam Expert? Answer questions, earn points and help others
