Question about Frigidaire ATF6000ES Front Load Washer
Frigidair affinity front load washer
My new frigidair affinity washer just makes a humming noise when I turn it on. I won't spin or fill with water. It's brand new I haven't even got to use it yet. My husband took off the bolts on the back that he was suppose to but I don't know what could be the problem.
  • 5 more comments
  • jules4209 Jan 15, 2008
    The water isn 't turned off. The water is on we checked it.
  • jowasher Mar 25, 2008
    I have removed the bolts and spacers from the back of the machine, both the hot and cold water lines are hooked up and turned on, there are no kinks or obstructions in the water lines.
    I can select any cylce, door lock activates, the machine turns on ie. starts humming and the timer starts, but water will not enter the drum or the drun won't spin. Even when the spin only cycle is selected, same thing - humming noise, but no movement.
  • Anonymous Mar 29, 2008
    door want lock so washer want turn on
  • Anonymous Apr 07, 2008
    Same problem here as well. Please let me know if you were able to diagnose yours. Thanks!
  • Anonymous Oct 29, 2008
    my new washer did the saime thing,repairman replaced the motor control board it runs fine now
  • usrgirls2 Jan 02, 2009
    help! i have the same problem with my Kelvinator (Frigidaire).
  • stacyseabrig Jan 22, 2009
    Just bought our new Frididaire Front load washer. Will not fill with water. never used whats wrong
  • 447 Answers
The water is turned off!!!!!!!!!!!!!!!!!
Posted on Jan 15, 2008
I had the same problum with my new washer , it was a bad motor control board
Posted on Oct 29, 2008
Me too. Anyone know more about this?
Posted on Apr 04, 2008
Hi, We also have the same problem. Was the machine repaired?
Posted on Mar 21, 2008
6ya staff
SOURCE:
Why my frigidaire affinity wont spin
Good Afternoon Iliana, thank you for allowing me to assist you!
If your washer does not spin, often it is because your washer cannot properly drain and dispose of the water and detergent solution. Does your washer make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Dec 14, 2013 | Frigidaire Affinity ATF7000E Front Load...
Error code 20 on an affinity frigidaire
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Oct 23, 2012 | Frigidaire Affinity ATF6000F Front Load...
How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin Read more: How to Troubleshoot a Frigidaire Front Load Washer That Doesn't Spin | eHow.com http://www.ehow.com/how_6496482
Hello - Does the unit make a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned, or you have another issue with the door lock assembly or the timer and control board not communicating correctly. Contact a professional to move forward accurately.
Oct 21, 2012 | Frigidaire Affinity ATF7000E Front Load...
Affinity washer will not spin and throw out water
Hello Susana - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Oct 03, 2012 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire Affinity washer stopped working. When i start the cycle it makes a loud humming noise, but no water goes in, and it starts spinning for a few minutes, then the time goes from 1hr, to 3 m
Possible that the inlet valve is faulty. please measure the voltage on the inlet when the washer is switched on , if there is no voltage then the controller is faulty. If voltage is present then the inlet valve has failed.
Jun 05, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fridgidaire Affinity AFT6500GG won't spin or fill up.
Check the hose from the drum area to a fill control valve. It will be a small hose. If it is clogged with lint, the control valve can't work. Try to undo it at both ends and rinse it out.
Apr 27, 2009 | Frigidaire ATF6000ES Front Load Washer
Affinity front load washer
my front load washer won't spin water out
Jan 21, 2008 | Frigidaire ATF6000ES Front Load Washer
My new Frigidair front loader
Wow it sure sounded like the water was turned off. There should be no problem getting a tech out soon to see whats going on why it wont bring the water in. It sounds like maybe the door lock isnt working?? Is the strike broken on the door?? I take it it wont spin on its spin only cycle??just return it to place of purchase. If you need any other assistance let me know, reply to your old posts so i can be notified you wouls like more assistance.
Jan 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
643 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
