Question about InFocus SP-LAMP-017 Projector Lamp for LP540, LP640, C16
LP 540 Every time I start my LP540 it will run for 3-5 seconds and then shut down. The display will read "Retrying...." and it will come on for another 3-5 seconds and then it will keep cycling this way. Why does this happen?
  • 1 more comment
  • grningbear Jan 18, 2008
    I did reset the lamp timer. When I push the start button the fan comes on and the display says "powering up" then the infocus screen will come up briefly the lamp will shut off (no LED blinks) and the display will say "Retrying...". Thanks so much for responding!
  • grningbear Jan 21, 2008
    Yes the fan comes on and I have good draw through the vents.
  • LibraryMama May 22, 2008
    How do you reset the lamp timer?
    Problem Solver:
  • 6 Answers
1. Have you recently changed a lamp and if so, Did you reset the lamp timer and is your filter (if it has one) clean?
2. can you hear a FAN start when you turn the unit on?
Posted on Jan 18, 2008
  • Steve Conaway Jan 21, 2008
    Back to the fan you hear a fan start when you turn the unit on? I suspect this may be the ultimate issue.
I don't here a fan come on
Posted on Jun 28, 2008
  • won one Jun 28, 2008
    I can't here a fan
    my infocus lp 540 is not working
ASK Proxima C420 shuts down after 30 seconds. No indication of overheating or lamp problem.
Might be a problem with the video input. Try a different cable. If HDMI, you will need a really good cable for HDTV or 3D, and they are very expensive. My 12 foot cable cost $180.
Sep 12, 2014 | ASK Proxima C420 Multimedia Projector
Treadmill starts at 2 mph runs for a second then shuts off
1)The walk belt lift 3-4"aprox, you must adjust the tension.
2) Read your user manual and proceed as indicated.Tense the drive belt.
3) if the problem persist you will have electronic+ electric problem with the main motor controller board + motor . Test it
Dec 13, 2011 | Treadmill Doctor PROFORM 540 TREADMILL...
InFocus LP 540 is extremely dim
Dim image is normally due to a defective lamp assembly. I'd recommend removing the lamp and inspect its condition. You'll notice a black corrosion build up around the filament of the bulb.
May 02, 2011 | InFocus LP540 LCD Projector
I have a hayward heatpro model hp2100. the heater will run and heat the pool for a while then shuts down displaying LP on the digital screen, after a period of time it will clear the LP and have running...
LP is an error message refering to the low pressure switch. For more information about it please refer to your owner's manual here. If you decide to persue attempting to repair it yourself and need further assistance, please reply to this post with a new comment or start a new post with your specific question(s).
Feb 01, 2011 | Hayward Hp2100 Digital Heat Pro Heater...
Where can I get the LP540 users manual ?? Thanks a lot Mario
You can download the user manual for this unit from this link,just click HERE.
Dec 10, 2010 | InFocus LP 540 Multimedia Projector
Showing a LP on display. What are the possible problems?
Here is the reason for that problem per the manufaturers web-site
The low-pressure switch senses the refrigerant pressure in the sealed refrigeration system to
protect against certain conditions that could be detrimental to compressor life. The switch shuts
the unit down in the event of loss of refrigerant, fan motor failure, evaporator freeze-up and
airflow blockage. The switch automatically resets when the pressure rises to normal operating
pressures. The display will show "LP" if this switch is tripped.
Evaporator Freezing
The low-pressure switch will shut the heat pump down when the evaporator starts to freeze.
When the unit starts to freeze the low-pressure switch will be tripped, causing the display to read
"LP" This will prevent the evaporator from becoming damaged or deformed.
If the air outside the heat pump is not warm enough to produce heat, the system will shut down.
The actual point at which your unit will shut down due to low temperature varies depending on
which model you purchased, current weather conditions, and the amount of sunlight reaching the
heat pump. The shutdown can occur anywhere within a wide range of temperatures, usually 45°F-
55°F. This is not a "fixed" range. We stress that climate conditions, sunlight, and various models
respond quite differently to low ambient temperature. A shutdown occurs because low
temperatures will activate the systems low-pressure safeguard switch (digital thermostats will
display a code "LP".) The unit will start up again when the temperature has raised enough to reset
this switch. Note: Low ambient temperature does not necessarily affect the Chiller models
or the cooling cycle of the heat/cool units.
If this post has helped you, please take the time to vote positively for me on this site. If you need additional help, I can be reached @:
Oct 23, 2010 | Hayward Heatpro 81k Btu Swimming Pool Heat...
I have replaced new lamp to InFocus LP540 projector, but it still indicating in the LED display "please replace lamp".. and LED is blinking two times as red.. Lamp door is closed properly and the safety...
To reset the lamp timer , press the increase volume button on the remote and the increase volume button within 3 seconds
The maintenance manual is on the infocus web site
Aug 19, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
InFocus LP540 Red Tint
first swap out the source cable. if the problem persists, reset the settings to factory default. if the problem still persists, your colorwheel may be bad.
Oct 29, 2009 | InFocus LP 540 Multimedia Projector
Projector shuts off within 30 seconds of power on
is the led lit on the top of the projector? what colors?
green is ok.
red flashing in sequence:
2 times- lamp hours exceed 200 hrs. replace lamp.
3 times- lamp failure. replace lamp.
4 times- fans not working. remove obstruction or replace fan.
5 times- temp too high. clean thoroughly.
solid red- undiagnosed error by projector. possible power supply or ballast.
also make sure the lamp door switch is working.
Aug 07, 2009 | InFocus LP 820 Multimedia Projector
Infocus lp 540
Also having this problem."Warming up" then "lamp didn't strike" then "retrying" stuck in a loop. It's at a school where I work and nobody has reported any messages regarding the lamp hours.
Jul 20, 2008 | InFocus LP 600 Multimedia Projector
InFocus SP-LAMP-017 Projector Lamp for LP540, LP640, C16 Logo
297 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
