Question about Dryers
Kenmore dryer Hi I have a kenmore 67832 model number that just stopped working and was wondering if you had any advice what to start looking at? It was running fine then the last couple of days it would just shut off in the middle of the cycle. Now It won't restart.
  • twinmama Jan 17, 2008
    We have the same problem. Would the switch affect the light at all? The light is working, just nothing happens when I hit the button. Should I check the Operating Thermal Switch? (And how the heck do I check that???). I'd love to fix it and not shell out money just yet for a new one.
    thanks!
  • nwakkary Dec 16, 2008
    We have the same problem. The dryer would start for about 30 seconds then stops.
    Scholar:
  • 146 Answers
Check the outside circuit breakers also check the door switch. Check to see if the switch holds with the door closed when you push it in.
Posted on Jan 15, 2008
6ya staff
SOURCE:
How do I stop my kenmore dryer, model 970-c87172, from beeping? Drying, cool down, wrinkle rid and clean lint filter lights flash 3 times. Start light doesn't flash at all. It does this even
Hi Brenda
First off It seems that you model is not correct. Kenmore model numbers start with 3 number followed by a . and then some more numbers. Most Kenmore laundry numbers start with 110.xxxxxxxx. The number you have looks like a serial number which is no help.
Oct 19, 2014 | Kenmore Dryers
I need owners manual to kenmore dryer model/stock 67832791 67832, SN MG2720493
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kenmore model by clicking the link below.
11067832791 KENMORE ELECTRIC DRYER Manual Sears PartsDirect
You can purchase a wide variety of high quality appliances replacement parts direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/appliances
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jul 31, 2012 | Kenmore Dryers
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Kenmore Dryers
I have a Kenmore 67832 model number that is drying but takes twice as long as it use to. The air vent is open & lint filter clean. Could it be one of the thermostats not working properly &...
It might be but do this first:Unplug the dryer. Remove the rear dust cover and then remove the filter chute and wash it out, check the blower, and wash out the filter.
6daed05.jpgfa87463.jpg1408cac.jpgThe thermostat is right next to the fuse. 477aa6b.jpgThe large wires carry the heater element current. The smaller wires come from the control. They power up a small heater that changes the rate at which the control shuts off power to the heater for knit and permapress. The newer dryers have a thermister which controls the temp.d7dd490.jpg The thermister could be bad. Rate it or hate it 36dc1dd.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 13, 2010 | Kenmore Dryers
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
Fabric looking belt came out of dryer. when i try to dry clothes it makes a loud noise and smells like something is burning and my clothes get twisted. how do i fix it? I have a kenmore 70 series dryer
Stop using your dryer in its current condition. That fabric looking felt is probably your drum seal. They commonly wear out. I will need your dryer model number in order to confirm how your dryer is configured and give you accurate advice on part numbers and directions on how to replace. The model number should be listed on a name plate around the door opening.
Apr 22, 2009 | Kenmore 63942 Dryer
Kenmore Electric Dryer Heating Problem
Most heat related problems with dryers are attributed to poor air flow. I would start there first in determining if you have a ventilation problem BEFORE replacing any components. If you don't, and you have a clog somewhere, you will end up with the same problem and repeated failed components. The following link gives some useful advice on how to troubleshoot a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention the first major paragraph that discusses the ventilation. Follow the advice and attempt to run the dryer without the exhaust vent attached, first. If the dryer begins to heat, you may have gotten lucky and avoided any failed components. However, if the dryer still does not produce heat, you probably have blown a component in the heating circuit. More commonly, the thermal cut-out (TCO) blows. Make sure you check ALL heating circuit components before taking my word for it, just to be sure. Reminder: If the TCO is blown, it is highly recommended that you replace the hi-limit thermostat at the same time. In many cases, these components are sold as a set.
Go to searspartsdirect.com and type in your model number as "110.62972100". Look under the "Bulkhead" heading for item number 47 (This is the TCO/thermostat set I am referring to). Refer to this drawing as a reference for your component identification (the Heating Element is listed as item 14). I hope this information helps you. Let me know if you require additional assistance.
Oct 27, 2008 | Kenmore 63942 Dryer
Kenmore Dryer
check also,
  • the other ends of all cables connected to the relay,
    if the other end of any part of the latching circuit has loosened, the relay will not latch closed when the start button is pressed.
  • Door Switch, it is part of the latching circuit
Sep 21, 2008 | Kenmore 62872 Electric Dryer
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
cutiepie, I've seen this many times on these dryers. You need to replace the door hinge. Not really a hard job to do. Post a model number (inside door) and we'll get you a part number...Catriver..post back.
Feb 18, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
216 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
