Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
PANASONIC PROJECTION MONITOR TV
I turn on my tv and within 3-5 seconds it turns back off. After i initially turn the power switch on, the power switch light flashes about 3 times and then kicks off. Can anyone give me advice on how to fix it?
  • Panasonic Master
  • 8,617 Answers
Usually 3 blinks means convergence,however it should continue to blink. Not shut off. You will probaly need a service manual you can get one through this link for 10.99 along with free unlimited support. If you choose to get your manual you will have to go back to the site and request that they email it to you instead of mailing it out. With your manual they will also email instructions on how to obtain your free support. . Youre probaly looking at a regulator that feeds the IC. I am one of the support techs at servicemanuals also. Heres there link,
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
LG CRT monitor continiously swith on & off, also no display on screen, CPU is fine & also not in power saving mode.
try unplugging the monitor and letting it rest for a couple minutes. If you have another computer please see if the problem is the same when the monitor is hooked up to that one.
Mar 27, 2013 | Computers & Internet
Turned on tv with remote (this turns on cable box and tv). TV came on for a few seconds and then went off, no picture, no sound. Remote would still change channels on cable box, so it is obviously the...
Most of these have a shutdown feature built in and if you unplug the set, plug it back in and turn it on manually look carefully at the power light on the front when you turn the set OFF.
It should blink a specific sequence: 3 blinks, a pause and 3 blinks etc.
3,3 and 5,5 are the most common and mean different things are wrong.
Let me know if you are able to see the error code.
SD TECH
May 11, 2010 | Panasonic PT-47WX53 47" Rear Projection...
My panasonic pt-56hx41 tv will not turn on. All it does when you press the power button the red light will come on for a few seconds and goes off. After that it will not do anything untill you unplug it...
projection TV`s have integrated protection circuits
built into the circuit design, these circuits turn the
power off automatically when a fault has bin detected this
is in order to prevent a more costly repair, these circuits monitor
power supply , vertical and horizontal deflection
over voltage, or x ray, and also faults with convergence circuits.
Diagnosing these faults require test equipment and a good knowledge of
electronic repair techniques, and also a repair manual.
Mar 07, 2010 | Panasonic PT-56HX41 56" Rear Projection...
Turns on and within a second goes out
Bad capacitors. They're cheap. Look for the ones closest to where the power cord comes in to the main pcb board. This will be your power supply circuit. Change them! They're probably dried out. If they're bubbled up, they're also bad. They're so cheap though, just replace them all.
May 21, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Changed battery in key now it doesnt work 2004 mini built in 11/03
1.) Close all doors
2.) Switch the ignition switch to KL-R (first turn), switch back off within 5 seconds and remove the key
3.) Within 30 seconds, press and hold the unlock button and at the same time, press and release the lock button (3) times. (Must be completed within 10 seconds)
4.) Release both buttons. The doors will lock/unlock to signal a successful initialization.
5.) If additional keys need to be initialized, repeat steps 3-4 within 30 seconds
6.) Switching the ignition to KL-R completes the initialization
May 17, 2009 | 2003 Mini Cooper
Need to be able to Unlock Parental Control and set new Password
Turn on the TV, put it on whatever channel you have when you watch a dvd....
While the unit's in STOP mode, hold down the unit's l<< (skip button)
and the STILL\PAUSE button down simultaneously and then the POWER button for longer than 3 seconds (until "Initialized" disappears from the TV monitor) The lock will be released and all initial settings will return to the Factory default values.
good luck to you....let me know if this worked!!!!
mtg
Apr 25, 2009 | Panasonic DVD-A310 DVD Player
Power problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-53TW53G
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Aug 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
