Question about ViewSonic NextVision N3260W 32 in. HD-Ready LCD Television
Strange smear in image and subtle vertical lines.
Do you have any idea what might cause a smear under the screen that looks like the one in the picture? How about the subtle vertical lines that you can see to the left of the smear? This appears regardless of selected input. The smear is not noticeable on a white background but different shades will show it more or less intensely.
Also, the smear showed up out of the blue and not after pressing hard while cleaning or anything like that. Being a former high end home theater installer/designer, I know better then to press on the screen as i clean it.
I have seen this before in a pharmacy on their 32" lcd which was mounted off the ceiling and away from hands.
Here is a pic of the problems.
  • 3 more comments
  • McFaulTech Jan 23, 2008
    I just saw this same thing on yet another lcd which was posting stock info at my bank. The one at the bank was an nec and it had several of these dark smear patches and more prominant vertical lines every 4-5 inches. Noone has any clue what this is?
  • McFaulTech Mar 07, 2008
    awsome, thanks....ill check on a price for an inverter board. I thought these things were rated for 80k hours....any idea what might cause an inverter board to do this? heat or dust?
  • Anonymous Feb 23, 2009
    black smear onthe bottom of my tv screen i have no idea getting off
  • FanceeNance May 25, 2009
    Strange and faint black smear running vertically along my LCD T.V.
  • glvoros Nov 28, 2010
    I have a similar "smear" on my monitor. Did you find a solution?
  • 7 Answers
SOURCE: Black line in my Sharp TV
yes 100% is ur lcd panel fail-- what u can do open the unit follow the lcd panel video cable,from the videoboard to the lcd panel input,,take ur time remove ,it shouln"t be to hard to removed,,after stand up the unit clear around it, the turn it on,if u see the line still there,that means ur lcd panel is finish it should be replace , if no line it could be ur cable faulty,,trust me i"m a service tech for 12years,& i still do ,thatks good luck
Posted on Jan 08, 2008
  • 286 Answers
SOURCE: Picture full of lines and flicker
Zdenko did an excellent job. Voltage regulators and the capacitors on the main boards and in the power supplies are always suspect. Some times you can narrow down the culprit buy purchasing a can of freeze spray. Let the TV warm up and try freezing suspect components to see if this causes a reaction. Thermal problems can often be found in this way.
Of course, if you're not able or willing to replace components on the circuit boards, you can always replace the main board or power supply board after determining which is causing the problem. These parts should be available at your local Viewsonic service provider at a reasonable price.
Posted on Feb 14, 2008
SOURCE: ViewSonic N3250W Locked
Yeah, my 19 year old daughter did the same thing. I found a solution on the 2750W thread
Solution - just press Menu, Enter and Power buttons at once.
Posted on Mar 12, 2008
  • 192 Answers
SOURCE: Help me please - Gateway FPD2185W
Ok, I have some news on this that I know you will not like, but the whole point of this site is to try and help you fix the problem, or at least, try and point you in the right direction.
The news:
I have done some extensive searching on this problem over the last month, as I have also had a friend with a similar problem that you are describing. There is a manufacturer's fault on the main power board, this has been recognised by Gateway, but as it happens inconsistantly (it may happen after a few months or a few years), they are not prepared to recall the product.
Obviously this doesn't help us as consumers that buy their products. The blue screen that you describe happens with alot of visual hardware inc. graphics cards that affects the whole market, and has now become affectionately known as The Blue Screen Of Death (BSOD).
If you are one of the lucky one's, and it is still under the manufacturer's warranty, get it sent back asap, and ask for a replacement to a similar model. If not, the only thing you can do is get it repaired or get a new/2nd-hand one.
Like I said, I'm sorry this isn't the news you wanted, but I didn't think it was fair for you to hang on.
Posted on Dec 09, 2008
  • 271 Answers
SOURCE: viewsonic n2750w 27" turn on the tv it gets 4 different colors
if you have a reset button (might be hidden)...hit dat
Posted on Dec 17, 2008
How to fix Multi Vertical Lines on a Vizio E470i-AO TV.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 12, 2016 | Vizio Televison & Video
How do I fix vertical lines and no picture.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 20, 2015 | Vizio E320VP 32" LCD TV
Vertical scan lines
It sounds that there is a loose contact to some connection wires, the flat wires that comes in, and go out the T'Con board. Re-seat all the flat cables and check. Check this link too. It has screen shots to different faulty displays. Pull up older posts and compare with these images to your TVs screen, and make confirm. Remember, vertical lines can be due to a faulty LCD display screen too.
Jun 06, 2013 | Vizio SV320XVT 32 in. TV
Started out vertical lines and smear on the left side of the screen but will disappear after 10mins but got longer and longer. Now 2/3 of the screen is permanently dark I had Samsung TV repair guy check...
If you wish to get some details; visit the site linked here. Pull up older posts.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 19, 2017 | Samsung LN52A850 52 in. LCD HDTV
TV screen doesn't light up for 20 minutes
sounds like caps in the powersupply are bad they take a long time to value up
Mar 01, 2010 | Sansui HDLCD-2600 26 in. LCD Television
Samsung DLP TV; Green Lines
If you get green vertical bars or green dots in the picture but not in the menu screen (Digital board symptom)
Feb 28, 2010 | Samsung DLP HL-P5663W 56" TV
Pictures are smears of color.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Oct 05, 2009 | Canon PowerShot A75 Digital Camera
Red vertical smears on LCD display and on playback
Your camcorder is on a list with potentially defect CCD light sensors. Sony is replacing them free of charge. Go here for the link and free mailing label:
Dec 13, 2006 | Sony Handycam DCR-VX2100 Mini DV Digital...
Why are there vertical lines or bars on the monitor screen when I record a movie?
Recording a movie of a subject that is brightly lit by the sun or some other very bright light source can cause vertical lines or bars to appear in the image during playback. This is due to a CCD phenomenon called "smearing." Note that lines or bars appear in movie images only, but not in snapshots. Smearing does not indicate malfunction of the camera.
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
ViewSonic NextVision N3260W 32 in. HD-Ready LCD Television Logo
388 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
