Reddy R70ET Utility Heater
Problem for Reddy R70ET Utility Heater
Replacing rotor on Readdy Heater
By bomcguire on Jan 15, 2008
how do i replace a rotor on a reddy heater model r55
Solution #1
posted on Feb 23, 2008
Not Rated)
tros1
Rank: Master
Rating: 92%, 9 votes
Remove top shell. Remove cover. Remove filters. Remove filter base. Then it should pull out. Check clearance on new rotor .003/.004 checked with feeler gage. Reinstall in reverse order. Reset air pressure. Good luck.
Was this helpful?
Yes
No
Popular Solutions for Reddy R70ET Utility Heater
Questions and Unsolved Problems for Reddy R70ET Utility Heater
Do you recommend Reddy R70ET Utility Heater?
Answer
Answer
won't stay running replaced optical sensor cleaned and checked pressure and cleaned
Answer
Have Reddy Heater Pro 10 Mod. R70CT Starts and lights fine, but shuts off and kicks breaker. can... (More)
Answer
i have a pr155000 reddy heater need to in install a new tank to se the burner on top what tools are... (More)
Answer
we have a gas wall heater, pilot is lit, but it won't ignight. How do we tell if the theromstadt is... (More)
Answer
Pilot is lit, but wont kick on when i raise the themostat, replaced the themostat and low voltage... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heater Experts
Top Heater Repairmen
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
