High pitch frequency comming from the cpu
HI AND THANKS FOR YOUR TIME,
THE CPU IS ETOWER 433I, WITH XP. THE POWER SUPPLY WAS REPLACED AND TEST OUT GOOD.
THE SOUND (HIGH PITCH-METTALIC), IS NOT COMMING FROM THE PSU, ANY FAN OR THE MONITOR, BUT APPEARS ALL OVER THE AREA....
ALSO, ATTEMPTS: CHANGES IN THE REFRESHING RATES, REMOVING DRIVES AND FANS FROM THE RUNNING CPU DOESN'T CHANGE OR ALTER THE SOUND.
THANKS FOR YOUR ASSISTANCE,
STEPHEN MICHAEL
  • 91 Answers
Might be the fan on the processor or in your actual hardrive there are actual discs that spin ,this is most likely to be the problem, and sorry no solution 2 that except gettin a new hardrive.
Posted on Jan 18, 2008
Computer had a high pitched noise now wont load up only the mouse is on screen
hi
check your CPU fan if its OK
its may be your hard disk sound
sometime power supply fans
May 29, 2010 | Computers & Internet
478 PENTIUM 4 MOTHERBOARD (intell) d845ebg2
The green led light on the motherboard mean the board has stand- by power to it. (This is normal).
You stated you installed a new CPU.
The high pitch you heard could mean you did not add thermal grease or thermal tap between the processor & the heat-sink assembly. (A must have product). When you press the power on button on the case & nothing seems to run, Re check your memory & as Smithbrother suggested insert one stick of memory at a time & try powering up the system. If you have an AGP card already installed, re-move it & re-seat it.
Intel list a bios update. This update is for - B-0014.
Fixed the issue with booting using 2.0Ghz processor.
Your new CPU of 1.7 is close. (Not sure if this will fix your problem. Save flashing the bios as a last ditch effort).
Here is the Intel link for your motherboard;
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=823&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go%21
Just in case I'll include a YouTube video on how to install a CPU;
http://www.youtube.com/watch?v=FyK-roVdx7c
Mike
May 09, 2009 | Computers & Internet
Emachine W2047 No BIOS Start Screen
You can test the power button. Remove the wires from the power on pins on the motherboard. Momentarily jump the two pins with a small screwdriver. If the computer starts the power button is bad. If it still doesn't start then something else is wrong. Did you test the memory? Also do all of the fans work, especially the CPU fan? It can't hurt to test with the other PSU. You know the HDD is good. Test one piece of hardware at a time and hopefully you will find the problem.
Jan 07, 2009 | E-Machines eMachines Desktop PC
Installing Pentium III processor on etower 433i
windows 2000 is good for pentium 4 not 3 you can not upgrade the prossesor without the mothboard and ram
Sep 28, 2008 | E-Machines etower 433i PC Desktop
Singlle long beep on booting up my Biostar M7NCDPro motherboard with nothing on screen
If you get one continuous beep (Long and Non-Stop)
This could happen if:
1. The Power supply is damaged or bad.
2. The BIOS is corrupted. Try resetting the CMOS using JCMOS1 jumper on the motherboard or remove the battery from the motherboard for 20 minutes. At this point the first thing to try is a different Power Supply to see if the result is better. If the same problem happens with the new power supply, you may need to send the BIOS Chip to local dealer for reprogramming.
If you get one long High Pitched tone that does not stop until you disconnect the power supply:
1. Check if the CPU fan is connected to the JCFAN1 connector.
2. The CPU might be overheated. Change the CPU FAN or check if the CPU fan has proper contact with the CPU. Refer to your manual for CPU installation.
3. Clear CMOS battery (JCMOS1), be sure to set JCMOS1 back to 1-2 position. (See Quick start guide/ user manual for more info on how to clear the CMOS)
4. Make sure the power supply you have on your system supports the M/B specification. Example. If you have a P4 M/B, you need to use an ATX v2.03 specification power supply. (power supply that has an extra 4-pin square connector)
Sep 15, 2008 | Computers & Internet
Computer
Can think of only three possibilities:
1. CPU fan motor, bearings needs lubrication or replacement;
2. Power Supply fan motor, same as above or any of the other fans;
3. Hard disk spindle motor (though unlikely).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 24, 2008 | Computers & Internet
Processor Upgrade
Your pc is very old, I would suggest buying a new pc instead of trying to upgrade!!!!!!
Will not perform well!! will still be slow even if upgraded!!
no use!!!
Buy a new pc.
Mar 20, 2008 | E-Machines eMachines Desktop PC
Continuous Beeping, new PC
Hi.
Continues short beeps... means a short OR no power OR loose card OR system board.
Test it without the keyboard and mouse too. Just the Processor with heatsink, motherboard, memory and Video card.
Now add the keyboard, no mouse yet.
Check also the voltage of the CMOS Battery it should be 3V.
keep me posted for the result... count also the beeps.
Feb 09, 2008 | Intel Motherboard
Computers & Internet Logo
121 people viewed this question
Alun Cox
David Payne
David Payne
