Did you drop your phone in water? or do you live in a humid area?
Your phone was exposed to moisture. That red dot is a moisture sensitive piece of tape that changes colors when it gets wet.
If your phone still works, but the battery won't charge when connected to a home charger, you might try charging it in your car. Its a different type of current and may work with a somewhat damaged battery.
If that fails to fix the problem you may need to get a new battery.
Clean the charger connector contacts with a stiff brush. If not then use an old toothbrush. Put drops on the bush with IPA but do not put IPA drops inside the charger connector or you may get white spots on the display, Does the power key click ok? if not then they domesheet needs to be readjusted. Under the batter in the rear case of the phone is the white dot on the case red? or the battery has a red dot and not white? if red possible liquid damaged.
Remove the battery!! Let the phone sit in a warm place for several days. Keep checking once a day or so to see if it will work. Always remove the battery while drying. If after a few days of drying it still is not fucntioning, it's wasted!
if the battery has got wet then it can be damaged usually there is a white dot on or near the battery if it is red its damaged or the battery has lost it power to hold a charge from normal use a new battery would solve the problem hope this was helpful:)
when that white dot is red it means moisture of some sort got to the battery and mean the battery the damaged the light means the battery is charging abnormally so the best thing is ti get a new battery try ebay they are cheap hope this was helpful:)
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone. Razr V3 external battery charger
Was the phone dropped? Did it incur any physical abuse? Water damage? If not, try pulling the battery out of the phone completely. Look in the battery bay to see if you can find a white or pinkish red sticker dot. If the dot is white, there is not moisture inside the device. Call your service provider and you may qualify for a free warranty replacement device.
Also try and letting the device charge overnight. It may be time to replace the battery.
Hope this helps, as you only gave me limited info.
ok, take out the battery and look and see you can see a white dot pice of circular paper, if it is red, your phone somehow got water in it, look at your battery(white dot paper) if it is red than you have water in you phone. now you need to dry it! leave it on your car dast board in the sun 24hrs or use a hair dryer ( use low heat) you must dry your phone and battery completely before the next step, Next step- find a good working battery and insert it in your phone, see if this will correct your problem, sometime the battery volt are very low or maybe the battery itself its bad, but make sure you put in a new battery to test this out, don't pay for the battery until you check you phone at the counter, ask for the right model for you phone.
