Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Red green lines
My tv has red green lines at the bottom looks like a rianbow half moon .
  • 395 Answers
Have the convergance amplifiers replaced, there also may be some resistors and pico fuses to replace. the amps are STK392-120 there are two of them and they should both be replaced. have a tech do this job.
Posted on Jan 15, 2008
Green half moon at bottom of screen, then no picture or sound
likely a convergence problem which has gotten worse
May 14, 2012 | Hitachi Televison & Video
Last night we got some multicolor, green, yellow etc horizontal, kind of half moon shapes coming across the screen, removed the front screen and cleaned the lens's and mirror,, no change. Any Ideas?...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
You can see some more examples and find a fix using this link on Fixya
Jan 01, 2011 | Hitachi 51SWX20B 51" Rear Projection...
Re: live chat at the bottom of page. What do the
Solid green means user is online and active. Half moon means they are logged in or idle. In order to send a chat message just type in message and hit enter that should send the message.
Feb 26, 2010 | Facebook Social Network
Blurry picture with green and red halos around
Ur convergence is dead.Must replaced 2 Convergence ICS,and some or all the resistors.Know how to solders?Buy a convergence kit Tv repair, to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 16, 2010 | Samsung HC-P4752W 47" Rear Projection...
Half moon shaped lines
your convergance board is about to go out. thats what happened to mine. it will cost about 300 dollars to get it fixed
Aug 09, 2008 | Sony KP-46WT500 46" Rear Projection...
Bad picture
Try to consider the following tips:
Smearing out of one or several colors, best seen in txt-mode, my 27CE4599/30R smeared out in red and green, not in blue, fully exchanging the drivers (input and output complete, otherwise the RGB driver will blank the crt) moved the fault to the other color
Replace the 180K feedback resistors in the amplifiers with normal 1/4W metal film instead of 1/8W, they can become open circuited (in mine both green and red were faulty in this way). Change all 3 and not just the defective ones, replace also all the paralleled 75K resistors per color (fe by 47K+27K) to prevent bright color raster (they can also become open circuit)
Nov 29, 2007 | Toshiba 55H70 55" Rear Projection...
Convergence Issue
You have a common occurring convergence problem = the
solution is: replace the convergence amp IC's ( both ).
Part # STK392-110 sub to upgrade STK394-160E.I use
Hitachi brand = no recalls.........................T.
Nov 21, 2007 | Philips 60PP9202 60" Rear Projection...
RCA Projection TV model #p61926
get an estimate to fix your convergence problem
Oct 08, 2007 | RCA P52937 52" Rear Projection Television
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
