Refrigerators
Problem for Refrigerators
Generic problem for all Refrigerators
Fridge not cold
By Uglybronco on Jan 15, 2008
My Fridge is not getting cold but the freezer is working great. It is one that my girlfriends dad has been using for quite some time & it worked well. When I got it here it worked great at first. When this started he said something about having to take a hair dryer to a hole in the back of the freezer? Help, my food is gonna waste quickly like this.
Comments:
Jan 15, 2008
- Its a GE TBX14SAXKRWH All I know is its probably a early to mid 90s model. Its 134a refrigerent... The defrosting thing sounds more likely because it worked great at first. But I need to figure out a way to fix it ASAP... & If I had the money to have a repairman come do something to it then I would just go buy a new one.
Jan 15, 2008
- No frost on the back... the fan on the back is running. I don't hear one inside if that is what you're meaning. Also it only has one temp control. Not seperate for fridge & freezer if that helps any.
Jan 15, 2008
- OK, so I pulled out some of the plastic, the fan inside is not turning... I can't tell if it may be the problem or what controls that. It turn with low effort but kinda has a magnetic type drag on it (VERY low drag) Also there is a styrofoam port leading downward that was full of ice. I poked a lot of that out with a knife. I'm thinkin of maybe hot wiring that fan to see if it works... but I guess I could try the volt meter 1st... Thank you in advance for the info...
Jan 15, 2008
- Ok, new discovery before I read the last one. I looked inside again & could see the fan trying to move but its not. So apparently that's the problem... & Yes the compressor & its fan are running & cycling fine. I could kinda see through the hole from fridge to freezer so I think I'll treat that to some hot water & maybe find a way to prop the hair dryer up in there on cold air mode so it'll blow into the fridge... should work for tonight..... Thanks a bunch.
Clarification Request
Posted by tech17 on Jan 15, 2008
sounds like a defrost problem respond to me with brand model number and age of unit
Best Solution
posted on Jan 15, 2008
Very Helpful)
tech17
Rank: Guru
Rating: 88%, 1535 votes
ok first do you see any frost on the back wall of the freezer section and with the door open do you hear the fan running is it an electronic control model (ill look it up) hi dark lord glad to have you on board dark lord is good at his job togeather we can get you fixed up and thats what we are all about
Comments:
Jan 15, 2008
- older top mount unit dark lord
Jan 15, 2008
- ok you don't hear a fan in the freezer section at all first the freezer does the whole cooling for the unit if the freezer fan isn't running it cant blow air down to cool the fridge now when you say the fan is running is it the one on the compressor or in the freezer compartment hey me and dark lord just want to get it right sorry for the questions and yes a discriptions always helps of the promblems the more info the better we can help
Jan 15, 2008
- hey if your compressor is running so should the evaporator fan right dark lord you may need a new fan and if those ports are stopped up then check to see if the drain is frozen or stopped up with algae where the silver honey comb metel thing under the back panel should be a tray under that with a drain hole hope you can see it pour hot water there and see if it drains if not you will need to clean it out let me know what you find ok just reamber the freezer cools every thing and if the drain is stop-ed up you may need to pull the freezer floor plate and clean the ice so air can circulate freely ill be standing by for more assistance should you need it me or dark lord will catch you
Jan 15, 2008
- there is no speed control for that fan on your model so save yourself some time it either runs full bozo or not ok
Was this helpful?
Yes
No
Solution #2
Somewhat Helpful)
DARKLORD1
Rank: Guru
Rating: 86%, 725 votes
Sounds like your fridge is running out of gas,, Call a Aircondition or Refrigation technician and let him re gas it for you...
It cant be frost cause it sould have affected your freezer not your refrigation unit.. Normall when gas is running low the first thing that is affedt is the refrifgation section ,, the freezer shows signs a few days / weeks later and eventualluy stops cooling all together... RE GAS IT FAST BEFORE IT BURNS YOUR COMPRESSOR OUT..
Was this helpful?
Yes
No
Popular Solutions for Refrigerators
Questions and Unsolved Problems for Refrigerators
Answer
Whirlpool model ET1CHEXVB or model W2RXEMMWB. Anyone have comments on either of these... (More)
Answer
Need a new refrigerator after only 8+ years from Kennmore -- have not been happy with this brand on... (More)
Answer
cant change my frigde bulb because i havnt a user manual samsung rl41wgi5
Answer
the low, medium or high lights are all blinking and some noise in the top
Answer
The internal light stays on and the fridge bleeps even when doors shut the problem seems... (More)
Describe your Refrigerators problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in , GA
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
