Question about Canon PowerShot A520 Digital Camera
What battery to put in the camera
I keep putting fresh battery in and it keep saying low battery
    Problem Solver:
  • 12 Answers
It sounds like you need a new battery and/or battery charger. I had the same problem with a simular camera before and just replaced both the charger and the battery because I wasn't sure which one of them was faulty. I haven't had a problem since then. I bought them from the website www.needbattery.com the company guaranteed thier batteries for a year and thier price was the cheapest on and off the internet that I could find. They have both batteries and chargers for your specific camera. This should take care of your problem. Hope this helps
Angie
Posted on Mar 26, 2008
I've had exactly the same problem, the camera does not seem to notice the new batteries/rechargeables even though they fresh and recharged.
Posted on Jan 30, 2008
  • 22 Answers
You have a couple options. First you can buy lithium batteries, which are a little pricey, but they last a great deal longer in high tech devices such as digital cameras.
Second, you can buy rechargable batteries, which also last alot longer in cameras, and are worth the price because they can be reused!
Posted on Jan 15, 2008
Change the batteries message keeps appearing even with fresh batteries. The camera turns on then immediately turns off What's up?
This actually a really common problem among Canon point and shoot cameras. There are a couple of methods that have worked well for others.
1. Open the battery compartment and remove the batteries. Then take a regular wooden pencil and place the eraser end down onto the battery contacts. Rotate the pencil to remove any corrosion. Sometimes a lack of proper battery contact will result in the low battery indicator.
2. Take a toothpick and wedge the tip under the battery contact and break it off. This will put more pressure between battery and contacts.
You can also try installing 3rd party firmware at http://chdk.wikia.com/wiki/CHDK_in_Brief
This is a bit technical and will probably void your warranty, but might be worth the try.
May 08, 2011 | Canon PowerShot A460 Digital Camera
Camera always says low battery even when you put in fresh batteries..will not allow me to take any pictures
Hello. Remove the batteries and use the eraser on the end of a common pencil to clean the contacts. Then replace the batteries and turn it on. J.
Jul 10, 2010 | Samsung Digimax A7 Digital Camera
I put new batteries in and it still says battery dead. is there a battery within the camera also
silly question, but have you tried different fresh batteries? sometimes batteries go dead in the store, especially if they are cheap batteries. try another fresh set.
Mar 21, 2010 | Canon PowerShot S2 IS Digital Camera
Keep putting new batteries in Nikon Coolpix L11 but keep saying low battery???
Check if the charger is working. If yes Firstly, make absolutely sure that you have a pair of fresh HIGH QUALITY batteries, in fact go and buy a couple of duracells. Digital cameras are notoriously power hungry and it is very possible that a pair of cheap standard batteries will not be able to run it for more than a few minutes. Check that the terminals of the batteries and the camera are clean. If none of this works, and you did have fresh alkalines or equiv. then it will have to be returned for repair.
Thanks.
Jun 18, 2009 | Nikon Coolpix L11 Digital Camera
My camera's stupid
you need a better batteries, ones with higher amber rate.
Feb 28, 2009 | Polaroid I533P Digital Camera
My Samsung Digimax 420 keeps saying low battery!
Check that you are using the correct type of batteries and that they are rechageable as i found i had a similer problem when using just normal non recargeable
Dec 22, 2008 | Samsung Digimax 420 Digital Camera
Wont switch on
Some cameras have a bettery setting in the menu. You need to make sure this setting is set to the type of batteries you are using. Usually when you use akaline batteries and even if you put in fresh batteries but still get the low battery indication then your camera is set to rechargable (Ni-Mh). Ni-Mh has more power to it then alkaline so this is why you get the low indication.
Feb 11, 2008 | Samsung S1030 Digital Camera
Fuji FinePix E550 Digital Camera stopped working after fresh batteries inserted
due to very low temprature some malfunction may have occured. keep it in normal temprature for few hours and then try switching it ON. even if this not solves take it to some service centre.
Dec 07, 2007 | Fuji FinePix E550 Digital Camera
Battery Low with NiMH (won't turn on) OK with Alkaline
Not the camera obviously - works OK Replace the NiMah batteries- get several sets and keep one set in the bag charged with one set in the camera. You may be able to 'refresh' the original batteries by putting them into a small flashlight and running them until the bulb goes out. This discharges them completely- then recharge. It is said batteries have a 'memory' so that a battery that is down say 50% and recharged will only recharge that 50% and the other 50% is lost for use. So you have to flatten the batteries completely
May 29, 2007 | Samsung Digimax A7 Digital Camera
Canon PowerShot A520 Digital Camera Logo
50 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
