Question about Compaq Presario R3000 Notebook
Compaq R4000 Power Issue
Hi. Appreciate any advice. The past 2-3 days I wake up to an "off" computer when I know I left it on. When I try to boot up the laptop the computer appears to be dead, no lights, nothing. I cannot start it up.
I started doing some tests. I have found when I start playing w/the cord I can get a front charge light. then I quickly push the on button and it boots up. So, when I move the computer, it can quickly just die. Totally off. I thought it was the power cord, but now I'm thinking it's not. So, I ran a test. I checked the battery and it said 100%. I moved my laptop (which includes the cord) and it died. I think it's a power problem, some where near the power cord inlet. Anyway to fix myself. Thank you all.
  • 7 more comments
  • Poor Deb Jan 15, 2008
    Thank you very much for helping me. I will see if someone will fix today. Unfortunately it's not under warranty with HP :(
  • trid2bnrml Jan 16, 2008
    I have an R3000, and as I understand it, a design flaw in the power inlet will loosen the solder from the board. I found this to be true with mine, and after removing many screws and small parts, I was able to clean up and resolder the inlet to the board which solved the problem (for how long?)
    now all I have to do is get the audio working...
  • Poor Deb Jan 16, 2008
    Thank you trid2bnrml. Ironically my husband and I took the sucker apart last night. We did pretty good. Got a lot of dust out! However, when we came to that area, there was this off white housing overtop of the jack and we could not figure out to save our lives have to detach that. We are fairly intelligent people and got out all of the screws. We were going to buy a new DC jack, they are cheap. But we cannot physically get to it. How did you get the white housing off? Thanks so much for your help.
    Hi Ken, thank you also, I called HP. They want $298 to fix the laptop. Yikes. The laptop is not worth that after a year and a half. And my model the R4000 is not covered under the lawsuit, but that was a good try. Thanks!!!
  • Poor Deb Jan 18, 2008
    man, you are awesome. Thank you so much. I'm not sure if it was part of the fan assembly or not, I will check w/hubby. Thanks for the instruction reference, I will check it out on line! I was looking for instructions, I googled them, but had no luck. This should really help. I appreciate it.
    You are very nice!
  • Poor Deb Jan 19, 2008
    Hi
    trid2bnrml,
    I found the manual, thanks!! I think it shows that housing. I'm going to show hubby tomorrow. I'm very excited. Thank you!!!!!
  • Poor Deb Feb 01, 2008
    Well, back to square one. I thank all for the tips. Very helpful. We bought a DC Jack. We used the tips from above to remove it, thank you and put the new one in. Still did not work. So then I bought a power cord on line thinking maybe that was the problem. Nope, still doesn't work. My husband said maybe replace the whole motherboard, but man, they are like $200 on ebay. This whole situation is so depressing. Any other thougths or ideas?
  • texansince84 Feb 07, 2008
    Hi, I have a Compaq Presario R4000 too and I'm having the same problem with the power cord...
    -If I move the computer, or the cord at all, the computer instantly turns off.
    -If I wiggle the cord while it's plugged into the computer, it turns off.
    -If I'm sitting on my bed with the computer plugged in and turned on, and I move at all- it turns off.
    -If I have my computer unplugged, it WILL turn on- however, if I plug the cord back in while it's turned on, the computer will shut off.
    The computer does fully charge when the cord is plugged in just right and very still.
  • tintin_8375 May 04, 2008
    Hello, I have the same problem, when I run the presario r3000 on the batterie there's no prob...whenever I plug the power cord, I intermitenly hear the fan reving really high and then the laptop shuts down. I have just formated and installed win xp corp and all drivers. Unfortunately I don't see any solution on the page I was reading, would it be possible to post a link to the solution please. Thx for your time, Marty
I have a r4010US. I was having the same exact problem with my laptop. It would only charge if I the power cord in just the right angle, it would turn off if moved, and it was driving me nuts. I bought a new power supply off eBay and it didn't work at all. I then figured it was the power jack, so I took apart the laptop and started looking at the jack. It seemed to be fine so I put the laptop back together and th same thing happened. This time just for the heck of it, I cut the end off of the old power supply. I was shocked, all of the little wires were frayed away and broke from where the cord and tip of the connector joined. I took off the plastic barrier from the power supply i bought from ebay and took a bunch of the wires from it and wrapped them around the tip of my old power supply and then wrapped it with electrical tape then duct tape. Walla my computer works like a charm again! don't know if I was sold a **** power supply off ebay, or if the r400 is just picky, but my jerry rigged power supply works great and solved th problem.
Posted on May 12, 2008
    Problem Solver:
  • 13 Answers
Poor deb---
are you referring to the fan assemblies that go all the way across the back , including over the jack? It comes out in one piece, there are screws at the forward and kind of hidden and hard to get to without completely disassembling the entire thing. I think you'll see that the little piece that comes up and over the jack is part of the fan assembly.
The hp website has a service/hardware manual that has blow-apart illustrations in it...that's how I found it, and you will too.
it's called---
HP maintenance and service guide
part no 33540402-003
Posted on Jan 18, 2008
  • trid2bnrml Feb 03, 2008
    To Ken--- yes, the interface had indeed loosened, must have happened because I didn't check everything for integrity before closing after fixing the power problem...thanks, I needed that!
Great, will do, you are very nice, thank you!!!
Posted on Jan 15, 2008
    Scholar:
  • 163 Answers
Actually you can basically get this repaired free From HP or send it out for a 3rd party repair and get reimbursed from HP for the repair. Weve repaired way too many of these to list and the Schottkey rectifier in the supply line as well as the DC jack should both be replaced. Go to www.hpnotebooksettlement.com and see if your SKU and serial fall into the paramiters. If you want to do yourself they can be a pain but there is a better jack to use Manned by the same company as the factory one, Post back if you need more help!
www.ikenfixit.com
  • Ken LaDere Jan 15, 2008
    Part of the settlement is after the warranty repairs and reimbursement for 3rd party repairs. We were involved in the litigation as a consultant for the plaintiff side. If they refuse to honor contact me back.
    Ken
  • Ken LaDere Jan 24, 2008
    On the R3000 where the Audio quit working? The Headphone Interface board is not snapped in the socket correctly.. Look on the Left sida lower after the Base plastic is removed and you will see what I'm referring to. (Board under the systemboard).. Good luck all!
My compaq r4000 is powring on but nothing is coming up on the screen
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 29, 2009 | HP Compaq Presario R4000 Notebook
Compaq r4000 dark screen
press F5 in the keyboard the light should be back or check the keyboard in the computer in the top botton where you see a sun design press that one you shoul have two of those 1 for put the light dark and the other one for put the light back good luck
Oct 13, 2009 | HP Compaq Presario R4000 Notebook
I have a compaq presario x1000 that wont let me get past the logo. It was working fine one day, but then I shut it down. The next morning I booted it up it the computer never went past the Compaq logo.
It is likely that the hard drive is bad or a memory issue. I would start by removing the hard drive and see if it goes past the compaq screen. If it does then you know what is wrong. If not message me and will walk you through the next step
Jun 30, 2009 | Compaq Presario X1000 Notebook
KEYBOARD DRIVER FOR COMPAQ R4000
There is no driver from Compaq because it just uses a standard driver from the operating system.
Try removing the keyboard from the device manager.
Then restarting the computer.
Let me know what happens.
Feb 27, 2009 | HP Compaq Presario R4000 Notebook
My laptop wont boot and its makes 7 or 8 beeps
I have a a compaq armada m700 it had same issue had to remove my HDD and back it up using an external USB IDE converter then reformated the HDD. CHKDSK reveals a bad boot sector and a driver problem COMPAQ has an open source of updates and drivers you can download but my advice is get a new HDD you could always usethe old one as a back up. Hope this help
May 31, 2008 | HP Compaq Presario R4000 Notebook
Doesn't boot up
First thing to do is check your RAM. If there is more than one RAM chip, remove one of the chips, and try booting. This will allow you to rule out a RAM issue.
May 25, 2008 | Compaq Evo N1020V Notebook
Presario R4000 does not detect 2GB of memory
Hi PhotoTom,
I check you laptop specification and it really do support uptp 2 GB. So here I'm not sure your 1GB are both of them DDR 333Mhz ?? .If so what I really want you to test here is
1. 1 GB in one slot and turn it on (as you say you can boot wih it) after that move that 1 GB to the other slot and see.
2. try the same with the other 1GB and see that both work fine on both slot or not.
Incase both work fine on both slot then maybe problem with hardware what I want you to do after that is try to check your BIOS version and check on the website that they do have new BIOS version or not ?? Coz this can help incase problem are from BIOS.
Goodluck,takecare.
May 21, 2008 | HP Compaq Presario R4000 Notebook
No power in compaq presario R4000
that happens to me all the time too. it will randomly shut off and i wont be able to get it on again till a day or two later
May 15, 2008 | HP Compaq Presario R4000 Notebook
Compaq Presario R4000 boot error
Hello Joresnore,
When booting to the XP install disk you should arrive at a "Repair Install" option that will not format the HD (I am reasonably sure it has to be SP2 though). It will just overwrite Windows system files, .dll's , etc... I think this is only available when using an XP SP2 disk so if your installation disk doesn't contain SP2, I would look for one that does and give it a try. I have had multiple successes using the repair install method without loss of data.
Good luck.
Feb 28, 2008 | HP Compaq Presario R4000 Notebook
Compaq Presario R3000 Notebook Logo
1,476 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
