Well thats another common problem with the sidekick 3. Your backlight went out. LIke lightbulbs do. Get your screen replaced, or luckily just your backlight replaced
You can test it; put probes on the backlight wires to see if it's being powered and how much, then try an independent supply on a disconnected display to see if it was the connector, backlight, or a driver circuit which failed (assuming you already got under a bright lamp and twiddle the settings to permit backlight toggling, then tried toggling it.)
Was this helpful?
Yes
No
Solution #5
posted on Oct 29, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
how do u get it repaced will t-mobile do it?
Solution #6
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Solution #7
posted on Jan 29, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
if you change the screens. like get someones sk2 screen and replace it wit yours, thats if they dont want it. thats what my sister did and it works perfectly.
i have a sidekick 2 and my screen is on but it is blank and theres is a black line or line across...
(More)
i have a sidekick 2 and my screen is on but it is blank and theres is a black line or line across the screen
