Dvd player wont open or close keeps saying blocked
  • 2 more comments
  • upick Jun 10, 2008
    door wont open at all
  • Anonymous Jun 14, 2008
    WON'T OPEN OR CLOSE. KEEPS READING BLOCKED
  • lf2512 Dec 09, 2008
    I try disconnecting and reloading the system, but the error remains.
  • Anonymous Apr 06, 2009
    i too was not able to get a dvd out of the door ... and it was a rental that had to returned to the video store. if you open the door you can see a white gear. i got a small screwdriver and turned the gear to open the door. it didn't fix the problem, but it did get my DVD out for me.
First, make sure the DVD Recorder is completely disconnected from the Main Supply.
Then, if you look on the base of the unit, (just underneath the front of the Disc Insert/Eject Tray), there is a small slot, (approx 25 x 8mm), in which you can see a small, white, plastic lever probably situated near the right-hand side of the slot.
Then move this lever gently to the left, and then turn it on and the tray opens by pushing the button.
Posted on May 01, 2008
  • 1 more comment
  • salish Dec 11, 2010
    My unit did not have a slot exposing the lever. I took the top case and the face off and opened the tray by moving the wheel with my thumb. I then tore a hole in the bottom to expose the white lever. The tray will usually open if a disk is in it. Sometimes I still have to move the lever through the hole I made to make it open.
  • Nacho63 Dec 25, 2010
    I had the same problem. The technical service suggested me to disconnect completely the unit and press the buttons, On, Open/close and stop during 8 seconds or more, but this didn't work. The only thig that worked was to find the slot exactly as kokicho suggested and move the lever gently with a tooth stick and IT WORKED!
    Thanks Kokicho!
  • lourdesrici Mar 22, 2011
    gracias!! solucionado usando mi dvd !!
It's not exactly a solution, but I eventually managed to get the drawer open after continuously trying the open/close button. Once it was opened, I gave the drawer a good clean and used compressed air to blow out any debris/dust inside. I inserted a disc and worked it open/closed a few times. I still get a blocked message when there is no disc inserted, so I leave a disc in at all times and every couple of days I work the drawer open/closed a couple of times.
Posted on Mar 07, 2009
Thanks. Indeed, it works. I my case I have some thick fat on the belt.
And now I have no "Blocked" indication anymore. It opens and closes normal.
Roelof
Posted on Jan 05, 2014
  • 3 Answers
My Philips Recorder DVD/HD DVDR725H shows bloqued, i did manage to take the dvd out, but stil the door doesn´t open or close, nether plays any dvd. Help me please
Posted on Sep 28, 2009
5 Suggested Answers
  • 3 Answers
SOURCE: ge 1101 pa dvd player keeps saying no disc
Try turning the disc over.
Posted on Dec 25, 2008
SOURCE: Drawer won't open. Says "blocked".
I had the same problem with a comparable device. It turned out that the drive belt that operates the ejection mechanism wears out or breaks.
To get at it you need to do the following:
1. remove device cover
2. remove the identification cover on the front of the DVD tray. This may be tricky if you can't open the tray. You need to find a way, because otherwise you can't remove the DVD unit, at least not on my unit.
3. remove the DVD unit by detaching the cables and removing four screws.
4. remove the two top screws on the DVD unit
5. remove the front top cover of the DVD unit by pushing the two tabs on the top of the unit, near the front.
6. Now remove the tray, by pulling it out as far as it goes and then pressing two tabs on either side of the tray. These tabs look like this:
7. Now you get at the drive belt. Originally it was black; I replaced it (temporarily) with a red one in the picture below:
8. Now put everything back together.
Posted on Aug 21, 2009
SOURCE: dvd player keeps saying no disc when I try to play
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Posted on Oct 13, 2009
SOURCE: DVD player wont open says E:26:00 then shuts off
Solution #3 worked for me.
http://www.fixya.com/support/t127790-error_message_e_26_00
Posted on Oct 09, 2010
Portable dvd player says open
It thinks the tray is open. Try to reopen and close the tray. If it still says open, help it close with a finger. Don't force it enough to break the gears.
Jul 26, 2016 | Televison & Video
Every time i open my dvd player when the lids closed it says open
The door sensor is bad, or the timing gear is out of alignment.
May 19, 2012 | Televison & Video
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
Mar 13, 2009 | Sony OPEN BOX SLV-DP550P DVD/VCR Combo...
Dvd problem
Hello
You need to clean lazier in it. You need to open it.
Sep 13, 2008 | Durabrand DVD-1002 DVD Player
I can't play any DVD's. It keeps saying cannot read.
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 25, 2008 | Panasonic DMR-ES25 DVD Recorder
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Keeps opening
may have a microswitch that signals that the door is closed that may be faulty. look for a switch that is actuated when the door closes.
Nov 06, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Dvd played one day and hasn't since
the belt is broken for the carocel (the disc can not change) it is plobabely stuck b/tween discs therefore it keeps opening and closing saying error . eventually it turns off. can be fixed with a small elastic goody hair tie w/o metal clasp
Feb 11, 2007 | kawasaki SVP500 Multi-disc DVD Player
DVD message says "blocked"
some one had enterd a code into your system causeing that problem if you do not remember the code you will have to take it to a techn in order that they lift off the chip and reset it all over.
Jan 27, 2007 | Philips Magnavox MDV530R DVD VCR
Televison & Video Logo
3,016 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
