Question about Brother MFC 210C All-In-One InkJet Printer
Help trying to get printer working again having troubles, tried many different troblshooting tips - with no luck please help
Why our printer not working? can u teching to use this brand our office printer are brther MFC-210C
Posted on Feb 20, 2008
  • 832 Answers
So plz write the exact problem you have with the mfc.
Posted on Jan 15, 2008
My printer does not print
This could happen from a variety of different reasons, but usually it is a temporary glitch between the printer and the computer.
First, try powering down the printer, then turn it back on, and try again.
Next, try rebooting your computer, then try again.
If you still have trouble, then print a test page. You can do this by following the directions in the printer's owner's manual, or from selecting Start / Control Panel from your Main Menu, then clicking on the Printers icon. Follow the directions from there. If that works, then the file you are trying to print is probably corrupted. Try to re-save it under a different file name and then attempt to print again.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Epson Printer Support
May 22, 2014 | Epson Stylus DX6050 All-In-One InkJet...
The Dell laser mouse won't track - how do I clean the mouse - or solve this problem?
You can clean the LED bulb on the bottom of the mouse with a dry Q-tip to get the dust and stuff out of there.
If that doesn't work try a new mouse pad. Sometimes even brand new mouse pads don't work well in combination with certain brands of mice. Swap it out with a different one and see if your mouse still gives you trouble.
If that fails too, make sure the cable is firmly inserted into the back of the computer.
If all else fails, try a different mouse.
Good luck, and if this was helpful, please rate by clicking on the 4 Thumbs Up icon above.
Feb 14, 2011 | Dell U0636 Mouse
Paper jams on my brother 7420
solution depends on where the paper jam occurs. Look under the "Troblshooting " section, chapter 11 page11-7 of the manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_7420_7820N_EN_1156.PDF
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 12, 2010 | Brother MFC 7420 All-In-One Laser Printer
PRINTER IS OFFLINE! I NEED A SOLUTION
So, what can you do when this happens? Luckily, you have a few options you can try when you need to get your printer back "online."
The first thing you should try is simply turning your printer off, wait a minute or so and then turn it back on. That may fix your problem right then and there. If not, try disconnecting the cable that hooks into your computer and then reconnect it. After you do that, you'll also want to restart your computer to make sure everything lines back up. If you're still having trouble after that, try sending something to your printer to print and when you see the printer icon pop up in your taskbar, double click on it. Then go to the File menu and make sure the option of "Work Offline" is unchecked.
Another thing you can try is right clicking on that printer icon and clicking the choice that says "Set printer online." Or, if all else fails, there may be an actual button on your printer that can help you get it connected again. If your printer has one, it will say something like "Online" and you can press that button to reconnect your printer so that it will print once again. Now, all printers are different, so don't hold me to that, but if your printer does have that button, it's an easy fix for this type of problem. Hopefully your printer situation can be fixed with one of these suggestions, but if not, you can always refer to your user manual or contact the manufacturer for additional help. Good luck, my printing friends!
Please rate me if this solution works for you
Thanks......Have a great time
Jun 14, 2010 | Epson POS TMT88IV Thermal Receipt Printer
Cannot print.
ITs communication problem, check the cable, and check the driver could be corrupted, reinstall the driver to make sure, and try different cable to connect.
Apr 22, 2009 | Epson Stylus Color 740 InkJet Printer
Trouble with dell inkjet printer j740 (printing)
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Dell J740 InkJet Printer
Margins not recognised
Hi lerona - I have a 5600C series HP printer. You might try these tips:
Do a Print Preview to be sure the document looks right on your screen, then in Print Setup, down in the Zoom box check the Scale to Paper Size to be sure it isn't set for the wrong paper size. There's an arrow to scroll to the size you're printing on.
Then click Properties, then the Paper Quality tab. There's an item that says "minimize margins". You could try printing with the box checked (if it's not now), or unchecked (if it IS now) and see the difference. Click the Effects tab and be sure the "normal size" box says 100%, and that there's no check mark in the "borderless printing" box.
I print documents all the time, as well as photos, smaller sized items, cards, etc., and have had no trouble with the margins printing differently than my Print Preview shows on my screen. I hope these tips help you. Good luck, and feel free to email me if you have any success with my suggestions.
Jo
JokerGirl524@aol.com
Oct 28, 2007 | HP DeskJet 5150 InkJet Printer
Can't get barcodes to scan?
have you tried different darkness settings? it sounds like you only need to turn the darkness up a little.
Apr 02, 2007 | Zebra 110XiIIIPlus Label Printer
Why won't my printer preview photos to the computer?
this is not an easy problem to trouble shoot like this, there are a number of possible reasons for not being able to use the scanner. Assuming the machine is working and is turned on I'd try reinstalling it's driver and software, although this might be a harsh solution to a small problem it is likely to work because all the settings will be set back to deafault. Good Luck
May 24, 2006 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Brother MFC 210C All-In-One InkJet Printer Logo
53 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
