Question about Fuji FinePix V10 Digital Camera
Read error when I try to delete pictures it says "read error"....i cannot delete anything. any suggestions?
  • 423 Answers
Try using the "format" option from the set-up menu. That should wipe everything off the card, and get rid of any "bad" data that has accumulated over time. If you want to only erase selected images, try the erase option again, but make sure to wait until the green light comes on before proceeding.
Posted on Jan 15, 2008
I have a video image I am trying to review and when I scroll to it, I get an error message that reads, "This motion image cannot be played". When I try to delete it, I get an error message that...
I think the easiest thing to do is to put the memory card into a card reader on your computer, copy everything off of it that you want to keep (excluding the problem files) and then try to delete the problem files using your computer. If this does not work, I would reformat the memory card, as these file seem to be corrupted. I would also suggest getting a new memory card, because they do go bad, and could corrupt pictures and videos that are important to you.
Mar 14, 2011 | Panasonic Lumix DMC-FH22 / DMC-FS33...
When i try to do anything on my camera i.e.(take picture, delete picture, or crop picture) an error message pops up reading "card protected". How do i fix this?
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 21, 2010 | Vivitar ViviCam 8600s Digital Camera
Card Locked! Message on Samsung l313
Go into the setup menu and do a camera "reset".
Sep 07, 2009 | Samsung Digimax S500 Digital Camera
File error/polaroid camera polaroid t1031
I have the same camera and that happens to mine sometimes. That happens when something wasn't right when you took the picture. If you press the delete button while it has the "file error" on the screen, it will delete the file and then you can continue use with your camera. Sometimes when this happens it freezes the camera so you have to turn it off and back on, then try deleting it. I hope this helps you!!
May 27, 2009 | Polaroid i733LP Digital Camera
Canon A560 will not erase pictures
Two possible solutions.
1. Apple users have reported that the switch on the memory cards performs the file lock function in either extreme positions Lock/Unlock. In some cases they have achieved success in centering the Lock/Unlock switch allowing access to the read/write operation of the memory card
2. Connect to PC
Access drive via windows explorer
Right click on drive (MEMORY CARD)
Select properties
Confirm that RO (Read Only) is not selected.
Selected RO
Try reading card
Repeat properties un-select RO
Try deleting files
If not successful card is likely defective
Hope this helps?
Mar 12, 2017 | Canon PowerShot A560 Digital Camera
XD card picture error
Try to use a card reader instead. They are only a few dollars. I use one all the time, and hardly ever will use the camera on different models I have.
Never delete from the PC to the camera. It can cause corruption. Once corrupted, you may lose all pictures on the card.
Always delete from the camera, unless you will format the card anyway.
Use the camera and try to delete the bad picture from the camera. this may fix the problem, if not, try to read from another camera or a card reader...don't ever delete from another camera or the card reader.
The last is not good, and that means to format the card, and you will lose all which is on the card.
You may try to copy to internal memory.
One more thing... take out the card. reset all in the camera menu. Then reset all the things you like. Put the card in and try to read each picture in play mode only. If one picture is very slow, delete it. This may take some time as corrupted files may read slowly. then try again.
Sep 01, 2008 | AOpen Olympus 64Mb xD-Picture Card (AX4C...
Format error
just get a new card or delete some pictures
Dec 31, 2007 | Gateway DC-T50 Digital Camera
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
You may fix the memory card error and recover your files by follow this memory card recovery guide which helped me last time:
Fix memory card error and recover data from memory card
good luck!
Nov 09, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
System Error
My experience in this issue is that you should never put too much trust in an SD card :-/ It seems to me that all cards are prone to fail once in a while, and my best advice is to keep spare ones handy. A dedicated SD card reader is a good thing, too...
Sep 01, 2006 | Konica Minolta DiMAGE Z5 Digital Camera
Fuji FinePix V10 Digital Camera Logo
62 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
