Question about Cyberhome CH-DVD 300 DVD Player
Screen keeps skipping
Whenever i put the dvd player on the screen starts skipping and i cant get it back to normal. what;s wrong?
If it is progressive scan, one of three cables or inputs may not be functioning.
Posted on Jan 17, 2008
SOURCE:
My player often displays 'wrong region code' error on disks that I have played before. Also it is recently skipping when playing back all cd's. Can you help?
If you've tried a DVD Laser Cleaning Disc and get the same results then the Laser is failing.
Replacements are sometimes available but not normally costs effective.
Jun 28, 2011 | LG RHT397H DVD Recorder
When i put a disc in and play it the picture keeps shutting off and then coming back on......skipping on/ off on/off on/off
The problem with you DVD, is that the lens needs to be replace. The skipping and stopping of the picture is as a result of a faulty lens. the distortion of picture is the symptoms of bad lens.
Jun 03, 2010 | Sony DVP-NS300 DVD Player
Wrong disc?
to clean the lens you'll need to buy a lens cleaner.its a cd which cleans.so its no problem to load it.now if even the lens cleaner is not loading ,i suggest you bring it to a tech nearest you.
May 27, 2009 | Coby TF-DVD8107 Portable DVD Player with...
DVD player: all disks freeze or skip at same point.
with some models it's very sensitive to being level. try moving your dvd player to a common flat area. see if it's a little rocky or placing a single piece of paper under one of the corners...I had a dvd player that would freeze on every disc and since I moved it to the botton of the cable box it no longer locks up. Worth a try.
Jan 04, 2009 | Denon DVD-800 DVD Player
Panasonic dvd player, wont play error code HO3 keeps coming up, took it back to shop they wont help as cant find receipt
On my DVD-LV50, I was able to re-initialize and fix a different error (error code H05). It might work for you, too.
With no disk in the player, press and hold these buttons for 4 seconds:
  1. Back skip -- [ |<< ]
  2. Pause -- [ || ]
  3. Play -- [ > ]
The screen will go blank, then say "Initialized."
After that, it worked like new.
I hope that helps.
Oct 17, 2008 | Panasonic DVD-LV50 Portable DVD Player...
I NEED HELP IN STOLLING MY NEW DVD PLAYER
good day,
just make sure that the colors are matched with the jock and the socket in your dvd player and your tv. just make sure that you unplug first your dvd player and tv while attaching the wires to avoid accidents.
just follow the color coding of the wires and cables and you wont go wrong. just plug in the your tv and dvd player to the electric socket and in no time you will be watching your favorite movie.
for the player, just press the open(eject) button to insert your dvd and normally it will automatically play. just hit rewind (<<) for playback and forward (>>) to skip some scenes. use the |<< button to go back to a previous section and the >>| to skip to the nest section. use the || to pause and the button with the square symbol to stop.
i hope this would help.
Oct 09, 2008 | Televison & Video
The sreen keeps skipping
Try the 'System' or 'P/N' key on remote to switch video modes.
These units also have poor power supplies. If your handy with
PCB repair check the capacitors. Be sure to replace any 10v caps with 16v (same uF rating) as they are probably for the 12v bus and 10v caps will soon fail.
Jan 15, 2008 | Cyberhome CH-DVD 300 DVD Player
Memorex DVD player
if you cant get it to work will you be will to sell the remote let me know needs one bad cant play my mp3 on it anymore email me at josocuervo@yahoo.com
Dec 29, 2007 | Memorex MVD2042 DVD Player
Wrong disc?
for god sake, i want to talk to customer support... you guys don't even have a 1-800 number posted....disgusting.....I am very upset with your cheap product...i guess i won't be buying protron dvd players from now on.....Whenever I put a dvd, it keeps on saying wrond disc and makes a wierd sound....please solve my problem and also give me your customer support phone number
Nicky Patel
Oct 22, 2007 | Protron PD-800 DVD Player
HELP!!! My cd player just skips through all song never playing....
Sorry but this unit has a problem with the tracking servo. The problem could be an alighnment, or a bad componet such as the laser assembly, tracking motor or tracking driver IC, with all of these problems the unit will need to come out of the vehicle. Good Luck
Apr 03, 2007 | Blaupunkt Chicago IVDM-7002 Car DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
