Question about Motorola Mobility RAZR V3
Motorola v3m phone constantly says no service- done basic tech support- removing battery etc. ive been on the line with sprint all day but they are clueless. and i dont want to go to a store and get charged $50 for something easy. can anyone help? ive reset the phone, reprogrammed the phone, taken the battery out and put it back in etc......
  • 1 more comment
  • Pam Stritzel Jan 26, 2008
    My new razr keeps saying I have no service. I have gone to the network settings and done the searches for a network, but still get the same No Service message. Is the internal antenna damaged??
  • PNH25 Mar 11, 2008
    I have tried changing the network settings, etc, but no luck. Is there something else to try. If it is the internal antenna, can I try to fix or could a repair shop attempt to fix. Very frustrating as I have other razr's in the house without this issue.
  • fixmyphone May 14, 2008
    Same "no service" issue here. Does anyone else have this number when you go to menu-settings-network-current network: 4294967295? This is an Alltel phone.
Same issue.. brought phone into local Verizon store. They upgraded the software and voila..... free fix took about 20 minutes.
Posted on Feb 18, 2009
Go to settings then network then set your band to automatic, thats how i fixed mine. hope this helps.
Posted on Jan 23, 2008
Try to go to setting then network and search new networks. or network setup... worth a try???
Posted on Jan 15, 2008
SOURCE:
I need to remove sim card from a motorola razor phone to retrieve info needed to reactivate
the sim card is located near the battery. you might have to remove the battery.
if the phone is a Sprint or Verizon branded phone, there is no sim card
Mar 01, 2011 | Motorola Mobility RAZR V3m Cellular Phone
Unlock a Motorola v3m from t-mobile
RAZR v3m is not compatible with T-Mobile, as it is a CDMA phone, used on services such as Verizon, Sprint, Cricket, etc. The v3m is not a GSM phone and does not have a SIM card, and therefore cannot be used on GSM services such as T-Mobile and AT&T (Cingular).
T-Mobile does have a RAZR v3, but it is not a v3m. The v3m is similar to the v3s, which is also a CDMA phone, but adds a micro SD card to store music and photos on.
Sep 20, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Razr V3m randomly/frequently is shutting off..
You need to take the phone to a mobile service center and have them flash the firmware on the phone to correct this issue.
Dec 28, 2008 | Motorola Mobility RAZR V3
Motorola RAZR V3m for Sprint
Remove the battery from the device while it is on and count to 30 then replace and power back on. This should work if not you may not have the picture messaging enabled by provider.
Sep 08, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Ield service code for v3m for sprint
Try mobile2mobile.net, unlockitnow.com or take it to a mobile service center to have it unlock there for a small fee.
May 24, 2008 | Motorola Mobility RAZR V3
How do I unlock my Motorola RAZR V3m Cellular...
you need to purchase special unlocking equipment to have the unlocks done....or take the mobiles to a professional mobile tech and have that done.
Dec 18, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Razer V3M Won't start
It may be a software problem. Similar thing happened to my LG Chocolate from Verizon. I found out that certain Verizon stores can perform an update on certain phones. Maybe Sprint has a similar software update. You can call your service provider and ask.
Dec 09, 2007 | Motorola Mobility RAZR V3m Cellular Phone
SD Card causing problems?
The V3m has an inherent flaw with the Sd Micro Memory Card. Installing the card, which fits extremely tight can damage the electrical contacts in the micro chip socket. This can result in low battery life due to a short to metal chassis of phone and not being able to communicate properly with memory chip. I had my first Razr V3m replaced by Sprint after only 2 days of ownership.When I got my new phone I carefully filed the tab on the Sd Micro Chip so insertion and extraction is much easier.
Nov 20, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Razr V3m - Tran flash
I have the same problem as list above. Does anyone have any clues?
Dec 01, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
860 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
