Lanier 6725 service code A4
Can you tell me how I can get rid of this code to use this machine?
  • 87 Answers
You have a problem with your sorter. Unplug it, and it will go away. The sorter has an initialization problem, but A$ is a very vague code.
Posted on Feb 23, 2008
Hi have a lanier copier model 6725. When I make copies it makes the copy and then also prints grey across the entire copy. Looks like it is printing old ghost can I fix this
If you say that you see old ghodt copies the problem is with the Fuser Roller in the Fusing Unit.
If this is right i advise you to call a Tech (if you do not have the skills to change it)
See you!
Sep 02, 2011 | Lanier 1205 Copier
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Describe your lanier sc 542 Problem Machine turns on and then gives this code.
This is a hot section problem, can be reset by entering service mode (pushing in sequence clear modes 1-0-7 hold stop button down for 5 seconds) but this is a bad code...service call? -Carl
Nov 13, 2010 | Lanier 1205 Copier
Lanier 5635 error code displaying a SC320
sc320 on the Lanier 5635 is a laser unit error code. Often if you power cycle the machine (turn it off with the orange power switch on the left side of the copier, wait a few seconds, then turn it back on) the code will clear and the copier will resume normal operation. If the error code comes back or doesn't clear, you'll probably need to replace either the entire laser assembly or the polygon mirror motor inside the laser unit. These are best done by a professional -- contact your local Lanier service company if the problem persists.
Oct 15, 2010 | Lanier 5222/27 Laser Printer
Lanier 6725 copier: Paper is always jamming and
I have worked for Lanier for 20 years, the 6725 was a great machine, but getting parts, spending $$$ and still having an old copier. Lanier is owned by Ricoh and all machines are Ricoh with a Lanier sticker on it. Its time.
-Carl, please let me know if this helps.
Jun 26, 2009 | Office Equipment & Supplies
Lanier LD245 error code SC542 appears
Fuser warm up error. Code can only be reset in service mode after the problem is fixed
Jun 06, 2009 | Office Equipment & Supplies
Lanier 6725 need pm code or manual
A2 means something is wrong in the duplexer. Check all parts of the duplexer for jammed paper.
May 28, 2009 | Lanier Office Equipment & Supplies
Lanier LW324 waste toner bottle full
Open the machine and to the right under the drum you should see the the black powder (toner) going down into container the right lower side  cover must come off. probably a service call will be needed
Apr 20, 2009 | Lanier Office Equipment & Supplies
Lanier 6725
If you open the duplexer cover, you will see a photo interupt sensor on the right. Stick a piece of paper in it. Take the waste bottle out, so you can see the inside of the duplexer. Turn the machine on. A minimal amount of waste toner will fall, and can be easily cleaned up. There are two stacker guides in the duplexer. One stacks lengthwise, the other widthwise. If memory serves me correctly, the horizontal guide not moving, or the sensor not sensing movement causes that error. If the guide moves, the sensor is probably dirty or bad.
Mar 18, 2008 | Office Equipment & Supplies
