Question about Dell Inspiron 6400 Notebook
More than one partition
I am trying to reformat my computer, and it says there are 3 different partitions. can i just delete all of them? what do they do?
  • 22 Answers
Well i think actually there should be four partitions, but correct me if not.
two should be in [NTFS] format, and two in [FAT] format
the two that are in fat format are for media, and utilities while the ones in ntfs are for windows, and backup. i would not recommend deleting any of the partitions, except the one for windows. make sure you create an ntfs partition in the empty space immediately and reformat, just to avoid some problems down the road.
Posted on Jan 15, 2008
6ya staff
SOURCE:
Reformatting
You need to repartition that drive. Googl partition magic.
Mar 09, 2014 | Sony HDE1/B 1TB External USB Hard Drive...
My back up disc space very low
do you have multiple partitions on your hard drive if so why dont you try to reformat your laptop and just make 2 partitions but you need to back your data 1st as you will loose it
Dec 04, 2012 | Lenovo G570
Memory wipe wd3200bevt
Download MiniTool Partition Wizard Bootable CD 7.1 from Here.
Or Download Directly by Clicking here
This CD allows you to boot computer directly into MiniTool Partition Wizard to manage partitions without any limitations. You can rebuild MBR, Partition Recovery, Move/Resize Partition, Merge Partition, Change Cluster Size, Copy Partition, Create Partition, Delete Partition, Format Partition, Convert File System, Hide/Unhide Partition, Explore Partition and much more.
Burn ISO file onto a CD using any CD/DVD Burner software.
Set the CD-Drive to 1st boot device in BIOS.
Insert it into drive and reboot the system.
You will get Partition Wizard Boot Disc Menu.
What to expect from this bootable CD
Step 1: Choose boot disk
Step 2: Choose screen resolution
Step 3: Manage your partition
How Delete All Partitions?
  • There are two ways to start this function:
    1) Click on Disk in the top menu, click Delete All Partitions from the drop down menu.
    2) Click Delete All Partition under Disk Operations in the Action Panel.
  • Delete All Partitions will delete all the partitions in the present chosen disks.
    Note: May cause Windows to not start properly when used on partitions containing the boot partition or system partition.
For more information check the website Link
Hope this will be useful for you.
Best Regards
Nandu
Apr 04, 2012 | Western Digital (WD3200BEVT) 320 GB SATA...
I have a maxtor diamond 9 plus used as an external hard drive .I tried to format it .It had 3 partitions .This hdd was originaly from my descktop but with a special cable i transformed it in an external...
By deleting the windows partition, you may have deleted the windows compatibility. You can try and reformat a partition of the drive to a windows FAT32 I believe, but you may lose your other data.
May 04, 2011 | Maxtor Hard Drive
I tried to format my F: using NTFS file system. But only C: is my bootable drive and now I can not perform any operation on F: What can I do so that I can get rid of this problem?
Assuming you have Windows XP or later, do the following:
1. Click on "Start"
2. Right-click on "My Computer"
3. Select "Manage"
4. Expand "Storage" if it isn't already and click on "Disk Management"
5. You will see a list of your disk drives. Each drive will have a graphic illustration of each partition or logical drive that it contains. You must first delete the partition or logical drive in order to reformat the drive. Make absolutely sure it is the drive you want to reformat! Once you delete a partition or logical drive, you can't go back!
6. Right click on the partition in the drive you want to format (F: in this case)
7. You will see either "delete logical drive" or "delete partition".
8. Delete all partition(s) and/or the logical drive. If there is more than one partition, you must remove them all. Click on "Yes" if you are asked whether you are sure.
9. When finished, there should be one unallocated partition shown. Right click on it and select "New Partition". Follow the directions and select "Primary Partition", "OK"
10. Select the full size displayed and "OK"
11. Assign the drive letter, presumably "F:" and "OK"
12. Select "NTFS" file system, and "OK".
13. The Windows operating system will begin formatting the drive. Depending on its size, it may take 1/2 hour or more to finish.
14. After formatting is finished, you can right-click again on the partition and set it as an active partition.
15. You're done! Exit out of the Disk Management menus and the drive should show up in Windows Explorer as drive F: (or whatever you selected). If not you may have to reboot.
I hope this helps. Good luck!
Mar 11, 2011 | Computers & Internet
Please help me a step by step reformat a computer
1st:enter an operating system disc to your computer
2nd:when you're in the partitioning session,delete the partition that you wanted to format
3rd:then make a new partition
if you dont want to delete your operating system,or format C:,do this
1st:open "my computer"
2nd:right click on partition that you wanted to format
3rd:select NTFS and klik "quic format"
4th:wait the process
please vote if it works
and thanks for using fixya!
Feb 09, 2011 | Computers & Internet
I've got Aspire 6930 and the hdu's partitions have been erased. I got the factory recovery cd's. What do I need to do to restore the factory partitions?
How was the partitions erased? Did somebody reformat the whole hard drive itself or just a partition. If the hard drive was reformatted then there's no way you can recover the factory partitions. Normally ther will be a hidden partition in the hard drive in case you want to use the recovery cds that came with it. And thru this, it will restore the factory settings on your computer on the state where you first got it. There is another option you can recover deleted partitions in case when the hd was reformatted like the stellar software, etc. but you have to buy it.
Nov 05, 2010 | Acer Aspire One PC Notebook
The problem is I'm trying to reformat my hard drive. When I open the window that says "delete partition" it is not highlighted, so I can't complete the reformating.
The partitions are listed in neumeric order. Enter the number (1 or 2) the the partitin is listed as, and the partition will be deleted.
Please note, you will lose EVERYTHING in that partition and you will have to reformat the partition.
Jul 14, 2010 | MPC Computers TransPort X1000 Notebook
There's a virus in my asus eee pc 2G surf and hard to connect to the internet. is it better to reformat it? How?
Check Two Solution:
Install Antivirus - Install new Symentec Antivirus Updated copy, and scan all Internet file, folder & Computer.
If problem presists - then format your Notbook or only your Notebook 'C' Drive
To format -
Windows XP installation:
1. Restart your notebook - and immedietly click on F2 key/Del button
2. Boot your computer from CD Drive
3. save your setting
4. it Running System File.
5. Then Create partition press Enter-(Delete previous partition)-press 'L'to delete your 'C' partition, If you want delete all partition, same delete like C drive.
6. Select 'C' Drive press enter to format partition choose option NTFS or Fat32, and Enter
7. It's running automatically then enter operation system windows CD Key and press enter
8. It will take time 30 to 35 min. Depending upon your RAM speed.
9. It will complete automatically and PC restart.
Feb 01, 2010 | ASUS Eee PC 2G Surf Notebook
C:/hdd
for you able to combine again. you can use the software named partition magic.
Oct 13, 2007 | Bose Companion 3 Computer Speakers
Dell Inspiron 6400 Notebook Logo
56 people viewed this question
Ekse
Clive
Clive
Alun Cox
