Question about Whirlpool Duet GHW9150P Front Load Washer
Washer will not leave the drain cycle
I've cleaned out the drain trap & cleared the drain hoses. I have unplugged the washer, opened the door, done everything the manual says. The water pump works, I poured water into the washer are I cleared the trap, and the pump drained the tub. The problem is the washer will not leave the spin/drain cycle. Pump runs for about 4 minutes then displays the F21 error code.
  • TBALL25 Jan 15, 2008
    We use HE detergent. I've tried everything in the owners manual plus all of the items in the tech manual in the front panel of the washer. Pump is working. Hoses are clear & unobstructed. It will pump water out if I pour water into the tub. Shuts down at 4 minutes and displays F21. Seems like a sensor is bad. Pump thinks there is still water in the tub, but tub is empty.
  • robert samples May 11, 2010
    what kind of detergent are you using
    President:
  • 1,314 Answers
Ok let me pull up the servic manuel and ill get back to you ok we are all trying to help but takes time ok
Posted on Jan 15, 2008
  • robert samples Jan 16, 2008
    i cant find f21 are you sure its not f02
    any way remove the top panel and test the pressure switch if you have the service sheet it will give details blow through the hose to make sure its clear but ill bet the switch is the culprit its what tells the ccu if there is still water in the tub
    Scholar:
  • 146 Answers
Press PAUSE/CANCEL twice to clear the display then
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
It's because of a Long Drain condition. If the drain time exceeds 8 minutes, the water valves are turned off the code is flashed.
But Note: After 4 minutes the "Sud" error is usually displayed, then 4 minutes later the error code is displayed.
  • Anonymous Jan 16, 2008
    Okay try running the washer through a cycle with NO detergent in it. See if that doesn't solve the problem. Just let it run completely without the detergent or clothes in it. That most likely will solve the problem.
6ya staff
SOURCE:
My LG Tromm washer does not drain all of the time. When is doesn't drain the water smells really bad. If I use a higher spin cycle setting it will usually drain, but that is beginning to not work either....
One thing LG did was install a manual drain hose located in the bottom left corner where the lint trap is, you can pull out the small hose and drain the machine that way, also, leave the door open on the washer slightly, this will allow the unit to dry better and eliminate odor, another cheap cleaning and odor elimination, pour 1/2 cup of chlorine bleach into the drum (with out clothes) put it on a short was cycle, the bleach should clean any bacterial growth; make sure to only due a white wash following this procedure to make sure that any possible bleach remaining dosen't effect color clothers....
Dec 08, 2013 | LG WM1814CW Front Load Washer
I have a Whirlpool Washer, Duet, 3 years old. I have had the washer stop withour being finished with the cycle. None of the controls would start it, the door was locked, and the error showed an F 21...
The F21 error code indicates a long drain time on this type of washer. The door will not unlock if the washer control detects that water is still in the tub. To manually unlock the washer door, take these steps:
  1. Unplug the washer to completely disconnect electrical power.
  2. Remove the bottom front service panel as shown in the first image below.
  3. Carefully reach up through the bottom opening and pull the release tab on the bottom of the door lock assembly until it clicks. NOTE: Internal metal edges in the washer can be sharp. Protective gloves are recommended for this procedure.
By pulling the manual release tab on the door lock assembly, you should be able to get the washer door open.
After opening the door and removing the clothes, I recommend emptying any remaining water in the tub with a wet/dry vacuum (or bail it out). Since you already have the bottom front service panel off and the washer unplugged, you can arrange shallow pans and towels to catch any remaining water and pull the filter out and clean it You may find a clog in this area that is preventing your washer from draining properly. Clear any clog or debris from this area and reassemble the washer. Check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
Here is a video to show you how it is done.
Oct 19, 2012 | Whirlpool Duet GHW9150P Front Load Washer
MY WASHER WHIRLPOOL LA5430XTW0 AFTER THE WASHING CYCLE IS DONE IT DRAINS OK, BUT DOESNT SPIN, AFTER THAT IT ADVANCES TO THE RINSE CYCLE BUT DOESNT DO ANYTHING AFTERWARDS, IT DOESNT FILL THE TUB, IT DOES...
hi Luis.
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump
If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Other Causes and Conditions
Clogged Pump or Hose
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt
If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly
If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose
If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap
If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
What do you do when your washing machine wont drain? Steps
  1. Consult your troubleshooting manual. Most washers come with a troubleshooting manual. ...
  2. Check your drain hose. ...
  3. Run the rinse/spin cycle on your washer. ...
  4. Clean the pump. ...
  5. Turn the handle counter-clockwise to remove the screen. ...
  6. Remove everything from the screen and rinse it off. ...
  7. Run the rinse/spin cycle again
https://www.wikihow.com/Fix-a-Washer-That-Won%27t-Drain
Dec 12, 2017 | Whirlpool Washing Machines
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Dec 04, 2011 | Maytag Washing Machines
My washer is less than 2 years old. Today it stoped running during the drain/spin cycle. Ld waon the read out. I tried to rebalance the load. No luck. I took out the laundry. No luck In order to get...
If your washer is indeed a WFL2066, than the not spinning is directly relatedto the unit not draining.
These machines by design cannot spin if the drain is inadequate.
Here is the first step in resolving the problem, you need to access the drainpump/filter to clean it.
To reach the filter and clean it...
**Unplug the washer from the dryer or wall, or turn off the 30amp breakerat the home service panel...safety first**
1) Open the small square plastic door at the right bottom of thewasher.
2) Via the small hose drain any access water from the pump...this is where awet/dry shop-vac comes in handy, or a shallow pan with a few towels works aswell.
3) Then turn the pump insert/button trap counter clock-wise and pull out.Clean the trap out thoroughly running it under hot water and mild soap or yourwasher detergent and inspect inside the pump for any other foreignobjects/obstructions.
4) Re-install the lint trap insuring it is good and snug/tight. Beforeclosing up the small access door, run a short rinse spin cycle to check forleaks.
Thanks
Sep 06, 2011 | Kenmore Oasis HE 27082 Top Load Washer
About one minute after starting machine (Whirlpool Duet WFW9600T01) the machine flashes "SUDS" for a couple minute or so, then the machine locks up with the F35 code. The only way to open the...
this is a suds lock and a very nightmare of a call....... are you using high effeciency soap and do you ever run a clean cycle ....... i prefer an affresh cleaning tablet once a month...... first things first need to drain all water out of washer threw drain hose connected to drain pump .... then check for any float obstructions at bottom of outer tub to drain pump large 4 inch ruber hose at bottom of tub with a plastic ball in it make sure there isnt any lint causing float ball not to seal in pump vacum... then reinstall and reconnect hoses then check pump filter sump trap for debris and reinstalll next open washer and install an affresh cleaning tablet and select hotest water cycle or clean cycle if washer is equipped with this feature and close door and let washer run ...m if code comes back you make have to repeat draining and pump steps a COUPLE OF TIMES TO REMOVE EXCESS SOAP BUILDUP..,. CAUSIN SUDS ERROR LOCK CODE.....
Jan 24, 2011 | Washing Machines
I hear water in the washer drum & smells. How do I get that water out?
Residual water in the drum is NORMAL. Since the drain pump and drain lines are at the lowest point of the drainage system, gravity will ALWAYS keep some water in the lines and pump. However, if you have water visibly present in the wash basket, then you may have a blockage in the drain system somewhere. Most often, the drain pump can become clogged with debris over time and need to cleaned out. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
Debris in the drain pump and/or drain lines can contribute to foul odors being present in the washer. In addition, NOT leaving the door open between washes can cause the tub to become stagnant. The manufacturer recommends leaving the door OPEN between washes to allow the tub to air out and to prevent mold and mildew from forming. The following link can give you some pointers on things to do to get rid of odors and prevent them from coming back:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
If you have any questions about these procedures, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Jul 28, 2010 | Kenmore Elite 45986 Front Load Washer
I cannot open the washer door---the cycle if off. The machine is full of clothes. HELP
Hi, welcome to fixya. If your washer is indeed a WFL2060, this is how to first get any water out which may prevent the door from opening and failing draining it manually allowing the door to open, how to open it manually. **Unplug the washer from the dryer or wall, or turn off the 30amp breaker at the home service panel...safety first** 1) Open the small square plastic door at the right bottom of the washer. You will see a small red loop with a string. That is for manually opening the door if you pull it...but you'll want to drain the water out first, so... 2) Via the small hose drain any access water from the pump...this is where a wet/dry shop-vac comes in handy, or a shallow pan with a few towels works as well. 3) Then turn the pump insert/button trap counter clock-wise and pull out. Clean the trap out thoroughly running it under hot water and mild soap or your washer detergent and inspect inside the pump for any other foreign objects/obstructions. 4) Re-install the lint trap insuring it is good and snug/tight. Before closing up the small access door, run a short rinse spin cycle to check for leaks. Let me know how you make out, or if you require further assistance. Thank you for visiting "fixya", please take a moment to rate the info provided for you here. Good luck. macmarkus :)
Jun 23, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore HE2 does not drain after first load.
  2. Remove the bottom front service panel.
By pulling the manual release tab on the door lock assembly, you should be able to get the washer door open. After opening the door and removing the clothes, I recommend emptying any remaining water in the tub with a wet/dry vacuum (or bail it out). Since you already have the bottom front service panel off and the washer unplugged, you can arrange shallow pans and towels to catch any remaining water and pull the large item filter out of the drain pump assembly as shown in the second image below. You may find a clog in this area that is preventing your washer from draining properly. Clear any clog or debris from this area and reassemble the washer. Check your drain hose for a kink or clog. Check the washer house drain for a clog or restriction. Test the washer to see if it will drain properly.
Feb 23, 2010 | Kenmore HE2 Plus Front Load Washer
Sewer smelling towels!!! Towels are the worst, other clothes are not great, but not as bad. For the past year I have endured this horrible smell. I've just had it!!! I have done the clorox washings many...
Put a cup of powdered dishwashing detergent in the barrel ie. Sunlight or Palmolive. Place 1 cup of bleach in the soap dispenser. Run on a quick cycle with HOT/HOT and run complete cycle. This does help and don't forget to clean the filter on the lower part of the unit.
Jul 10, 2009 | LG WM-2277HW Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
153 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
